TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Dec 31, 2019 at 6:18 AM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Deep cells, non-dual purpose deep cell batteries don’t handle the sharp demand of starters well. They are hard to kill from slower drains but four years ain’t bad.
  2. Dec 31, 2019 at 6:18 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    northstar, 5 year warranty.
    Norton, nudavinci64 and zippsub9 like this.
  3. Dec 31, 2019 at 6:20 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    Northstar, X2 and Odyssey make dual purpose group 31 deep cells. Optima has no such product on the market in any group size.
  4. Dec 31, 2019 at 6:23 AM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Northstar 27f next purchase. been eyeing then a while anyways. Thanks guys
    Norton and zippsub9 like this.
  5. Dec 31, 2019 at 6:23 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    watch for group buys
  6. Dec 31, 2019 at 6:25 AM
    mightytacoman
    Kel
    4.5L 1grfe
    Don't want to risk bricking ecm because I was trying to save a few bucks. I'll spend the coin.
    Norton, BassAckwards, Torspd and 2 others like this.
  7. Dec 31, 2019 at 6:26 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    I got some great deals local, but all 31s. Watch out on Marketplace as well. You would be surprised.
  8. Dec 31, 2019 at 6:27 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    wise choice
    mightytacoman[QUOTED] likes this.
  9. Dec 31, 2019 at 6:30 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    off topic- what is an ignition wire in the underhood fuse box guys? need to locate switched power.
  10. Dec 31, 2019 at 8:15 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
  11. Dec 31, 2019 at 8:17 AM
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    The intercooler pump has been annoying to me as well. Randomly turns on with the ignition off. I did replace that junky tap with a proper fuse tap, though.
    Also getting tired of intercooler system fluid loss over time. Would be nice to see a group buy on a better reservoir tank.
  12. Dec 31, 2019 at 8:25 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    I will switch the power source as well, in due time. However, I don’t get any fluid loss. Unless you have a different mix, distilled water, then I would check the seal inside the manifold. You may be leaking there, mine is sealed with RTV inside. Fairly easy to get to and check as well.
    Norton and 12TRDTacoma[OP] like this.
  13. Dec 31, 2019 at 8:29 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    just installed the booster. easy upgrade especially if you run an AGM battery.
  14. Dec 31, 2019 at 8:33 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    its supposed to do that. sitting fluid heats up. random cycles help circulate and cool things down better.
  15. Dec 31, 2019 at 8:52 AM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Cold temperatures don't really cause batteries to fail. It does cause the chemical reaction that makes batteries work to slow down significantly which makes a failing battery appear dead. The reason batteries die so quickly in areas like where I live, Alberta, is because we do see 90f-105f ambiant temperatures for 3 months of the year. That causes the internal damage to the battery that goes unnoticed until one year when, usually during the first hard cold -20f snap, the battery fails to start the truck under the conditions where it performs the worst (cold weather). At least that's how it's always been explained to me lol.
    My Toyota OEM battery died after three years. I took it in for warranty, got a pro rated rate, and passed it along the new battery to a friend. I bought a JCI manufactured Energizer AGM battery next. Installed the AGM friendly voltage booster as well. Three years later and it died as well. Costco sold it to me though and their warranty is awesome, over the counter 100%. I installed the new one in my garage as a starter battery for my snowblower. I'm using a Northstar battery in the Tacoma now (27M) and it's the first battery I can say after one summer doesn't seem to struggle to start my boosted Taco in cold weather. I will say no one should be scared to run an AGM deep cycle marine battery in a Tacoma. At that size they're designed to start small marine diesels, which are harder to start than a boosted 1GR, and will last longer when used under hotel load like a fridge overnight on a multiday trip. The only thing that sucks with the 27M is the terminals are too far away for easily swapping the battery. I had to lengthen the ground to body wire which was no big deal.
  16. Dec 31, 2019 at 8:53 AM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    I was telling a co-worker today about what I've done to my truck - he said "man, you should have just bought a Raptor or something". I've heard that before. As I'm sure a lot of us have. People just... don't... understand.
  17. Dec 31, 2019 at 8:54 AM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Just heard the raptor thing 2 days ago. Power wagon is another one I hear about a lot.
  18. Dec 31, 2019 at 9:20 AM
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Power wagons are brutal though. In general the Ram 2500 in any variant is just a plain old mess and will cost way more than a Tacoma. Especially when Ram denies your warranty because they're broke but will blame you for farting the wrong way too close to the dash.
  19. Dec 31, 2019 at 9:23 AM
    1sandytaco
    1sandytaco Well-Known Member
    SLC, UT
    2015 - Black
    Supercharged
    So, I've been lurking, reading this and a few other Supercharger related threads trying to decide if I should pull the trigger on purchasing. The consensus seams to be avoid the Bullydog unit and opt for the HP Tuners tune with 4 universal credits. I know zero about tuning. For those of you who went the HP Tuners route, did you do your own tune, or take it to a shop? My truck is getting HEAVY and I would love an extra bit of power to roam the mountains. That said, I don't want to burn $5k+ and not be satisfied with the performance.
  20. Dec 31, 2019 at 9:31 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Tell me about it. I get that every time I run my race truck and pass up sports cars in an suv. Many hurt feels. This was before I bought my skyline gtr and I didn't want my first race car purchase to not be a skyline. Altough it would've been funny if you did buy a raptor and lowered it.
