TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Mar 28, 2018 at 9:05 PM
    #2321
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    That is usually the best way with iridiums.
    If you use a standard gapping tool it will scrape off the iridium (or platinum for platinum plugs) right off the plugs, effectively making them less useful than coppers since they burn less effectively than a standard copper anyways and will last you less than 30K instead of the standard 90-100K that iridiums and platinum are famous for.
  2. Mar 28, 2018 at 9:19 PM
    #2322
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    On another note, I commend your research on that upgraded intercooler pump. I did a ton of research on intercooler pumps these last few days and most people don’t realize GPM doesnt mean shit if it cant flow that through the heat exchanger. There are other good pumps that can but boy does the price start to hike up and very quick. I think I’ll stick with the one in your main post.
  3. Mar 28, 2018 at 9:28 PM
    #2323
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It requires connector modification, but it is a small price to pay for a gallon more per minute flow for an overall cost less than or equal to a replacement OE supercharger supplied pump.
    Coincidentally when I was doing the mod, I actually found that the supercharger supplied pump was actually weeping out coolant, so it worked out all for the better in my situation.
  4. Mar 28, 2018 at 9:39 PM
    #2324
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Yeah thevplug doesn’t seem too bad to do, just two wires right? I’m just glad it doesn’t cost $1000 like one I was looking at lol.. Although if CSF comes through with a larger intercooler I wonder if running two of these pumps in parallel would be worth it. Time will tell on that.
  5. Mar 28, 2018 at 9:42 PM
    #2325
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Cmon csf :spending:
  6. Mar 28, 2018 at 9:57 PM
    #2326
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    You are correct sir: URD TCAI. I believe it is 3" opening, but can verify tomorrow.
    Also, cleaning the MAF (which was insanely dirty) and knocking off some dirt/dust from the filter did not resolve the pending P0174.. . . . . . . . . .
    Murphinator[QUOTED] likes this.
  7. Mar 28, 2018 at 10:00 PM
    #2327
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    If it is 3” ID then there is the Volant 61511. 7” x 7”, should be around the same size as the urd filter just not cone shaped, it will be round.
  8. Mar 28, 2018 at 10:58 PM
    #2328
    Skootter14
    Jeremy
    Awesome. I was hoping to find something a tiny bit smaller as far as the filter diameter is concerned too since it ever so slightly touches the inter cooler radiator (LTR)
  9. Mar 29, 2018 at 12:08 AM
    #2329
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  10. Mar 29, 2018 at 12:48 AM
    #2330
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Yes if you know how to gap a plug you can do it without putting any pressure against the electrode. The scale is for measurement only, the hole is for bending the tip.
    I’ve seen people that don’t know how to use a gapping tool put the scale between the electrode and the tip prying against the electrode and I’m like WTF LOL :eek::confused::crazy:
  11. Mar 29, 2018 at 4:36 AM
    #2331
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Yeah I hear ya. In terms of length the filter is 6” long but the flange is 1” so really it should only stick out 6”, i dont know if that is good or not with the LTR.
  12. Mar 29, 2018 at 7:51 AM
    #2332
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    This. Never adjust (or even measure) the gap on iridium or platinum plugs with the circular gap tool. Feeler gauges to measure should not damage the tips.
    I've seen the same. Lots of intercooler pumps out there, but people need to find the PQ graph (pressure versus flowrate) to see how many GPM you can flow with pressure drops (tubing, heat exchangers, etc.). It's like reading a dyno graph for a pump.
  13. Mar 29, 2018 at 8:03 AM
    #2333
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
  14. Mar 29, 2018 at 12:04 PM
    #2334
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    My magnuson supercharger and other mods should be arriving next week
    Should I remove the restricter jet right away?
    Also, any recommendations for better 4.0L header gaskets besides using OEM?
    12TRDTacoma[OP] and loginfailed like this.
  15. Mar 29, 2018 at 12:08 PM
    #2335
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  16. Mar 29, 2018 at 12:34 PM
    #2336
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    Looks like they only make cylinder head gaskets for the 1GR-FE.
  17. Mar 29, 2018 at 1:19 PM
    #2337
    Skootter14
    Jeremy
    I’ve had no issues with my OEM replacement gaskets. I replaced the valve cocer gaskets, plenum, and TB. All OEM and have had no issues with them. Glad I did!
  18. Mar 29, 2018 at 3:03 PM
    #2338
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Ohhhh. I thought you said "head" gaskets. Which header gaskets are you referring to?
  19. Mar 29, 2018 at 3:07 PM
    #2339
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Ran the same ones the truck came with in 06.
    Ive been thru a few headers swaps and never got new gaskets.
    Stock/longtubes/stock/shorties/longtubes.
  20. Mar 29, 2018 at 3:08 PM
    #2340
    inwood customs
    Dave
    Get a few of the urd collector flange gaskets tho, those are primo
    Roostfactor and jojotoo like this.
