TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jan 3, 2020 at 8:38 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Jack handle on a 2' long boxed end wrench. First time from the factory, breaking those loose, is a tough fight.
  2. Jan 3, 2020 at 8:38 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    not as dangerous as me using a fabric belt. i live on the edge.
  3. Jan 3, 2020 at 9:07 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I mean, yeah, if you're into queer eye for the straight guy. ;) :D
  4. Jan 3, 2020 at 9:34 PM
    jamesepoop
    jamesepoop Well-Known Member
    California
    2007 Fj Cruiser
    Most shops around here don't carry anything over 10" for that size. Might have to try an industrial hardware shop this weekend.
    mr.trd and 12TRDTacoma[OP] like this.
  5. Jan 3, 2020 at 10:10 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I love that movie! Frank the Tank!!!!
    mr.trd and jamesepoop[QUOTED] like this.
  6. Jan 3, 2020 at 10:34 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    not wearing one. using it to hold the breaker on the tensioner. it did snap. got lucky!
    Athlaos likes this.
  7. Jan 3, 2020 at 10:53 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Sweet Jesus man! I actually use my foot to hold the end of the bar while I wrap the belt around the upper smooth pulley. :laugh: Chess not checkers right?
  8. Jan 3, 2020 at 11:01 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    I used the cross bar from a Yakima rack as an extension if you have any arriving. Thule would work too if it fits. 40-60” bar works like a charm.
    jamesepoop[QUOTED] likes this.
  9. Jan 4, 2020 at 6:20 AM
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    Cutting that cast iron base down so it’s perfectly square will be the really important part. Also, pay close attention to where the bearing is in that sleeve. You want the belt to ride as centered on the bearing itself as possible.
  10. Jan 4, 2020 at 10:36 AM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    Setup was easy enough. Hoses go out to a tiny Earls 7 row mounted to my crash bar in my lower grille.
  11. Jan 4, 2020 at 10:42 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Greddy adapter?
    Kelvin likes this.
  12. Jan 4, 2020 at 10:44 AM
    Kelvin
    Kelvin Wheeeeee
    Yes sir. If I remember right I believe you’re the only person in here that has one.
  13. Jan 4, 2020 at 11:04 AM
    Kelvin
    Kelvin Wheeeeee
    Do you think I should drain the oil cooler during my oil changes? All I’d have to do is unscrew one of those 90* fittings. Capacity on my cooler probably isn’t even .5 qt though.
  14. Jan 4, 2020 at 11:30 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i wouldnt bother.
  15. Jan 4, 2020 at 11:41 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    I has it. Did you grind the splash gaurd?
  16. Jan 4, 2020 at 12:03 PM
    Kelvin
    Kelvin Wheeeeee
    Yea I just realized how big of a PITA it would be to do that. I’d need to take off the plastic lower cover that has 25 screws.
    Yep. Just took a step bit drill and went through all the plastic.
  17. Jan 4, 2020 at 12:12 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    He beat me to it.
    Ours are proudly large. We drain ours with every time. Have to.
  18. Jan 4, 2020 at 12:43 PM
    Tacomatty
    Tacomatty Well-Known Member
    Long Island NY
    2015 dclb sport
    Supercharger, walbro 255, 3* retard cam gears, AEM boost and AFR gauges, JustDSM tuned, ome 887, dakar leafs, bilstein 5100s, katzkin leather
    Definitely need longer wrench or pipe to slip over the box end wrench. Had a hell of a time getting those cam gear bolts loose but when you do you will know! When the bolt finally gave way, I thought it broke...I linked two wrenches together and when the bolt gave way, wrenches went flying all over the engine bay so use safety glasses or even a helmet!
  19. Jan 4, 2020 at 1:29 PM
    Kelvin
    Kelvin Wheeeeee
    Proudly tiny. Asian tiny.
    I probably won’t be hitting any tracks or drag strips like you guys so I think this should be sufficient and letting the oil sit in the cooler should be fine in my case.
    I’m even downsizing my transmission cooler because with a headwind it affects my coolant temp and it’ll start dropping to where where my thermostat closes.
  20. Jan 4, 2020 at 1:59 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    I plan on going up a size when I assemble the stroker in the race truck.
