TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jan 6, 2020 at 6:50 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    ill get c-load next time and just not park in a jobsite driveway. always nails everywhere.
  2. Jan 6, 2020 at 6:56 AM
    Yota31
    Yota31 Well-Known Member
    Shannon
    Lifted 2006 Trd Sport Tacoma
    Led Tailights, OEM roofrack, 3 inch lift, Halo light bar and Black Wheels
    Sorry new to this whole supercharger thing. Has Bully dog fixed there tuner? I bought a truck with one on it with a Magnusson supercharger. Engine dropped a piston the first week and the a/F was reading 8. It stops at 8 so could have been lower didn't know if I need to go somewhere else and get a tune. The dealer is covering for a newer engine.
  3. Jan 6, 2020 at 7:16 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Holy crap. That's wild. Under 8 AFR. :eek:
    Bully dog has not and never will address their garbage tuner. Go TRD Tune then go HP Tuners in that order of succession.
  4. Jan 6, 2020 at 7:19 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Creative :thumbsup:
  5. Jan 6, 2020 at 8:13 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    A good compromise is the oem tow package oil cooler. It assists cooling and warming the oil without adding more difficulty to servicing.
  6. Jan 6, 2020 at 8:39 AM
    Yota31
    Shannon
    What should my AFR be or be around?
  7. Jan 6, 2020 at 9:02 AM
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    I just went from e load to D load. Great difference and good middle ground
  8. Jan 6, 2020 at 9:15 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I have been running the IPT valve body for like 5 or 6 years now. No issues. Highly recommend.
  9. Jan 6, 2020 at 9:17 AM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Theoretically, 14.699. However, open loop acceleration is around 8-9 (rich, lots of fuel, little air). In closed loop, idle and cruising (12-14). The reason for not being exactly at 14.699 is anything above this is LEAN (too much air) and can destroy the engine quickly . Extra fuel doesn’t just get burnt it cools internals as well preventing damage. It sounds like you may have a leak or sensor causing open loop fueling. The OEM wideband sensor or ECU caps out at 8 something so you wouldn’t detect anything richer than that without a monitor.
  10. Jan 6, 2020 at 9:33 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Also, for those who were interested in re-gear RPMs..
    Here's a quick shitty vid from this weekend. Keep in mind this is FULLY loaded with 3 people and all our gear. Possibly even a slight incline, can't remember.
    https://youtu.be/WSgOBr3lSeM
    Athlaos and henryp like this.
  11. Jan 6, 2020 at 9:55 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Nothing lower than 10.5... ideally around 11.5 is totally ideal.
    Anything below 10.5 under WOT or part throttle and you are just dumping fuel.
    Norton likes this.
  12. Jan 6, 2020 at 10:02 AM
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    What kind of tire and what size in D load?
  13. Jan 6, 2020 at 10:08 AM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Nice....so 2800-2900 at 85ish all weighed down
  14. Jan 6, 2020 at 10:13 AM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    can anyone point me to old posts of fuel filter options. i need to do mine before motor going back in like the frame mount
  15. Jan 6, 2020 at 10:18 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    It's right around 2700-2800 at 80. The Speedo is off by about 5mph at that speed. I showed the GPS speed in the beginning at 79.
    But at 85.. loaded down.. yeah, about that. 2900 at th most.
    JuanitoBonito[QUOTED] likes this.
  16. Jan 6, 2020 at 10:49 AM
    RyanL
    Indiana
  17. Jan 6, 2020 at 10:54 AM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Napa Gold 3296 031010k1 unless you are wanting to go with the spin on.
    12TRDTacoma[OP] likes this.
  18. Jan 6, 2020 at 11:01 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    There is no such thing as D load range tires.
  19. Jan 6, 2020 at 11:05 AM
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    ya i wanna do the spin on i dont want hose clamps on the fuel lines...
  20. Jan 6, 2020 at 11:09 AM
    GT7
    Grant
    Phoenix
    2013 DCLB
    Cooper st maxx 315/70/17 67lbs
    mr.trd likes this.
