TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jan 7, 2020 at 1:33 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    true. hense the term PITA to put it lightly.
    Torspd[QUOTED] likes this.
  2. Jan 7, 2020 at 1:40 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I personally just run an internal.
    If you want you can honestly run it anyway, but if you insist on an external, run it rhe same way an OE manufacturer would. With a sock in place before the external filter, that way the pump has less chance of getting damage by picking up and collecting sediment internally within it's body leading to eventual failure.
    jamesepoop likes this.
  3. Jan 7, 2020 at 8:30 PM
    jamesepoop
    jamesepoop Well-Known Member
    California
    2007 Fj Cruiser
    @nudavinci64 consider it a long term maintenance item. While you may never experience an issue with the stock pump for the life of the car, as Denso pumps are tough, it's still possible to clog the filter over time. Ie. I purchased my FJ used and there's no possible way that I'd know how careless the previous owner was to taking care of the motor. It's just best to not have any impeding flow.
  4. Jan 7, 2020 at 8:35 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Fuel pump upgrade is on my list of things to do, but I'm curious whether deleting the sock poses any long-term problems for the pump since it's now trying to pass any debris it might collect from the bottom of the fuel tank?
    My biggest concern is whether deleting it poses an increased risk of pump damage from tank debris, but I agree with @White lightning boosted, that servicing it is a PITA.
  5. Jan 7, 2020 at 8:47 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Somewhere down the evolution, some engineer realized that the pumps could get damaged by service station debris getting into the tank. They all came with socks henceforth. Use it.
  6. Jan 7, 2020 at 8:51 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Honestly now that I think about it. I’m not sure if I left the sock on or not cause it’s been over 10 years since I did the new fuel pump upgrade. Whatever the XRU community did at the time is how I followed suit. :cool:
  7. Jan 7, 2020 at 9:00 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    This was always my thought process as well. It only makes sense to set it up that way.
  8. Jan 7, 2020 at 9:06 PM
    Norton
    That's my concern, exactly. Thanks, guys! :cheers:
  9. Jan 7, 2020 at 11:14 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    agreed. I already have a new pump I will be tossing in. Looking at easier ways to upkeep maintenance and if there are other benefits. I do like having more convenience when doing maintenance. Lets me get quick things done when I am limited on time.
    jamesepoop[QUOTED] likes this.
  10. Jan 8, 2020 at 2:49 AM
    jamesepoop
    California
    2007 Fj Cruiser
    Can confirm fuel hose size running from the tank? 3/8? 5/16? I think I need -6AN fittings.
    I went with the deatschwerks inline 10 micron. The FST looks mighty nice and I like the water separator feature but may hang low if I rail mount it.
  11. Jan 8, 2020 at 4:34 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Factory lines are 5/16".
  12. Jan 8, 2020 at 4:43 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    @mightytacoman and anyone else curious about the Mishimoto 160°, for the 03-04 4Runner 1GR, used on an 05+ Tacoma.
    Swapped it in last night. Also swapped in an Aisin water pump. As mine was leaking from the weep hole.
    Burped it last night, but didn't get to drive it until today.
    42° ambient. Stayed about 163 peak. Fluctuating between 157 and 163°. Until I got to slow traffic near my office.
    For the first time ever that I have had the Ron Davis radiator with dual SPAL fans, once the fans kicked on at 186-188°, that they were able to cool it below 166-168 and they turned back off. Never has that happened in all these years. I am impressed and happy with that outcome.
    It will certainly run cooler in the Summer months. Mind everyone, my engine has ductile iron sleeves.
  13. Jan 8, 2020 at 4:45 AM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    I got one coming in the mail today or tomorrow actually. I had a feeling the Mishimoto was gonna out perform the 160 Motorad unit. Thank you for confirming. Still waiting on my dual electric fans to come in the mail.
    12TRDTacoma[OP] likes this.
  14. Jan 8, 2020 at 5:03 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Of course.
    Now for you, or any of the other guys running sleeved engines, and HP Tuners, you'll likely have to lower the minimum operating temp setting. It should be 168°. If it isn't reached within a certain time limit, then the CEL will set. Confirm with @JustDSM .
  15. Jan 8, 2020 at 5:51 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I am approaching 115K and will be picking up a Mishimoto T stat soon myself. Honestly I am thinking one more summer with the OE thermostat before I feel outside of the comfort zone of it being done. I am pretty sure the CEL will come on for my junker as well so I will need to make adjustments when the time comes with JustDSM so it doesn't trip on due to under temp.
    I still am waiting to see what solution he comes up with for running an 11 PCM in a 12+ 2nd gen with the whole inop coolant gauge thing. My current solution will likely involve getting one or two 30-0311 gauges from AEM so I can not only read coolant temp, but various other PID readouts from the PCM at the push of a button, but still match my current boost/ AFR gauge style setup.
    Since the gauges would use OBD info and obviously need to plug into the OBD plug beneath the dash, I was thinking of running this splitter from eBay.
    https://www.ebay.com/p/21025125069?...inMTD2H3I7yeDhx8XPZBoCatoQAvD_BwE#UserReviews
    Torspd[QUOTED] and JustDSM like this.
  16. Jan 8, 2020 at 5:59 AM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    I can help you guys with the thermostat, but the coolant temp gauge ('12+ Gauge w/ '11 is going to be a bit. Got some homework to do). Best solution right now I think is to use the AEM OBD gauges or something else pulling data from the CAN network.
  17. Jan 8, 2020 at 6:03 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    https://www.aemelectronics.com/products/gauges/digital-gauges/x-series/obdii
    Apparently I'd even be able to clear OBD2 codes without ever having to plug a scanner back in. Double win if I go this route! ;)
    I'm just waiting on my pillar pod to arrive and once it does I'll get to buying the gauges. Still not sure if I want to run one or two of them. Piggybacking off the OBD port twice over is not exactly the best idea to me.
    JustDSM[QUOTED] likes this.
  18. Jan 8, 2020 at 6:05 AM
    JustDSM
    Justin
    Ogden, UT
    When/if you flash, make sure the MPVI2 is the only thing in there! :)
  19. Jan 8, 2020 at 6:09 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I could technically just have the gauges switched off using the supplied integrated switches right? Or would it just be safer to disconnect the whole rig and then just run the MPVI2?
  20. Jan 8, 2020 at 6:12 AM
    JustDSM
    Justin
    Ogden, UT
    You could get away with that, but in all honesty, for the flashing procedure I'd just remove everything from the OBD port to minimize the risk of anything happening.
    Datalogging/normal use you can leave it all plugged in no problem.
