TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jan 10, 2020 at 5:24 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    its pat.
  2. Jan 10, 2020 at 6:02 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Yup! The typical worn out front wheel bearings sound can make you think of many things. But usually they go out around 100K.
    I never understood why there is so much slack between that 35mm nut and the crown and cotter pin. You can almost hand tighten the 35mm for the crown/cotter pin to fit.
  3. Jan 10, 2020 at 6:37 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    ive never had a vehicle with a bearing go bad. i have no idea how to change them. had to pay a shop so it was a 1 day thing. pricey. drives like a champ now.
    12TRDTacoma[OP] likes this.
  4. Jan 10, 2020 at 6:53 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    It’s not that bad a job for the front wheels. That’s if you get the whole hub assembly. The rears require a press, a little more involved. I’ve gone through 2 sets on the front, one in the rear. I do frequent unpaved terrain often though.
  5. Jan 10, 2020 at 6:54 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    It’s 4 bolts to actually remove the bearing once u get to it. Real easy
  6. Jan 10, 2020 at 7:59 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Mine went right at around 110K, though had been emanating noise for the last 60K easily, and here I was thinking it was due to my all terrain tires.
    That's because the cotter pin is the last line of defense on making sure the axle nut does not back off. If for whatever reason it works itself loose. It's just a backup plan it's not an integral part of the design.
    It really just is. I saved my hubs and pressed out the old ones and pressed in the new ones. It was worth it for time saving purposes, of course I would had preffered to had preffered to replace the entire thing.
  7. Jan 10, 2020 at 8:28 PM
    TRON
    My first thought was the winter tires too for some time until doing some research. But yeah I think once an axel nut gets loose the wheel bearing prematurely starts to go bad.
  8. Jan 10, 2020 at 9:27 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Well yeah, I agree, that's a good way for a wheel bearing to go bad, but if the nut is torqued down either to spec, or tight enough it should never be an issue. Like I've legitimately never seen an axle nut on ANY job where we used the impact gun come back to our shop because it came loose over time and we have done tons of axle shafts in the past.
  9. Jan 10, 2020 at 9:38 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    ive got the tech guys #. i should ask if mine was loose and part of the issue.
  10. Jan 10, 2020 at 10:13 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Did you do any front end work before? Or has it been all stock up to this point of the wheel bearing failures?
  11. Jan 11, 2020 at 12:36 AM
    Yota31
    Yota31 Well-Known Member
    Shannon
    Lifted 2006 Trd Sport Tacoma
    Led Tailights, OEM roofrack, 3 inch lift, Halo light bar and Black Wheels
    Okay need some advice. I am getting rid of my bully dog tuner may use just as a gauge. So I contacted two Toyota dealerships and they have no clue what I'm talking about when I say I want a trd tune installed. One said they can try and alter the bully dog tune on the ecu and the other said they could order the calibration kit. Is either correct or is there actually just a trd flash. They both said there's no such thing but according to everyone on here there is. I'm new to to this.
  12. Jan 11, 2020 at 1:10 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    There is actually a TRD S/C flash. In my experience experience, however, Toyota will be unable to install it until/unless your ECU is returned to its stock (NA) calibration. (TechStream confirms the NA calibration ID before flashing. If it's not found, which I don't think it will be once the BullyDog tune is installed, TechStream won't flash the ECU.) Pretty sure your best option is to invest in an HP Tune setup.
  13. Jan 11, 2020 at 5:06 AM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    As @Norton mentioned. HPTuners is really the only way to turn a Bullydog flashed ECU into a TRD tune.
    The dealers use software that does not have the flexability of the aftermarket flashing tools/software. I can explain why if you’re that interested, but the fact is, HPTuners can do what you’re trying to do (and much more).
    If you’re looking to simply go to the native TRD tune, you have a few options. You can buy the HPTuners MPVI2 (~$299) and four universal credits (~$200) and you can do this yourself or give me a shout and I can walk you through the process.
    Or, you can send me the ECU and I’ll use my MPVI2 to flash it for you. This way you can save the expense of the MPVI2 and only be out ($250 + a few bucks for priority mail shipping)
    Either way, happy to help!
  14. Jan 11, 2020 at 7:15 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    all stock.
  15. Jan 11, 2020 at 7:18 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    @JustDSM is the most efficient route to success on this in my opinion.
    Norton and JustDSM like this.
  16. Jan 11, 2020 at 7:38 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It was all tight.
  17. Jan 11, 2020 at 8:41 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    is our traction control fully off when we push the button and the indicator light with the skid marks appears? seemed the truck held back timing or something. was in a controlled course experimenting with breaking traction. i had a hemi charger that even when you pushed the button it still managed some form of computer control. if thats our case too can hp tune correct that?
    henryp likes this.
  18. Jan 11, 2020 at 9:05 AM
    JustDSM
    Justin
    Ogden, UT
    It doesn’t turn off just pushing the button, much like your Charger. I believe holding it down for a few seconds disables it, but I’ve never really tested.
    Yes the traction control can be tuned.
  19. Jan 11, 2020 at 9:08 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Traction control can be tuned?!
    12TRDTacoma[OP] and Norton like this.
  20. Jan 11, 2020 at 9:14 AM
    Norton
    @David K assembled the best tutorial I've seen on the system... TRACTION GUIDE (TRAC, AUTO LSD, TRAC OFF, VSC OFF, A-TRAC, RR LOCKER.
    +1
    I know it's got multiple modes/settings, but I didn't think it was as advanced as what you find in new sports/muscle cars like @White lightning boosted's Charger, or my GT500 and C7Z. I look forward to learning more...
