TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jan 11, 2020 at 9:16 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    its a computer controlling a mechanical function. i figured anything except the airbags was possible.
  2. Jan 11, 2020 at 9:20 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    with power to both tires and a tracbar this truck drives completely different. we're about to get snow and im looking forward to some tests. thanks for the link @Norton and input @JustDSM
    mr.trd, JustDSM and Norton like this.
  3. Jan 11, 2020 at 9:33 AM
    Yota31
    Yota31 Well-Known Member
    Shannon
    Lifted 2006 Trd Sport Tacoma
    Led Tailights, OEM roofrack, 3 inch lift, Halo light bar and Black Wheels
    The bully dog has an option to uninstall the tune and re install the factory one. But I don't want to uninstall it unless Toyota can install the Trd flash. I really don't know who to call if Mabye someone knows a dealer that does it and see if they can call one of my dealers and explain it. Both dealers have no clue what a trd flash is
  4. Jan 11, 2020 at 9:47 AM
    henryp
    henryp A member of TW
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    It was my understanding that you can’t undo the bully dog (BD) unless you have the HP tuner. There are several in the past who had to get a NA ECU to flash since BD could not be undone until HP came along.
    Norton likes this.
  5. Jan 11, 2020 at 9:57 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    It might re-install the stock NA tune but, as I understand it, a new/updated Calibration ID remains. Assuming that's the case, HPT is the only path to the TRD S/C tune about which I'm aware. TechStream decides what it can/can't do based on the Calibration ID, not the tune "contents," so it works only with "virgin" ECUs. (Before HPT was available, I had to buy a replacement ECU when Toyota was unable to install the TRD tune on my truck because it had been previously flashed with Toyota's own ping/knock reduction TSB, changing the Calibration ID!)
    JacksonTacoma and JustDSM like this.
  6. Jan 11, 2020 at 9:59 AM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    This is correct.
    Norton[QUOTED] likes this.
  7. Jan 11, 2020 at 10:09 AM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    Line/Part# 59080 . ECU update for TRD supercharger. $155.00
    I've attached a portion of my invoice that shows the ecu update from Toyota of Sunnyvale. So you can hand-feed them numbnutz at the dealership that you're going to.
  8. Jan 11, 2020 at 10:22 AM
    Yota31
    Shannon
    So I'm looking at used ECU's will a 2015 work on 2014 and is it as simple as just unplugging the one on and plugging the new one in? I see there about 150 used
  9. Jan 11, 2020 at 10:28 AM
    henryp
    Henry
    Montana
    Look at the part number on your ECU. Then order the same part number. These are pretty specific (model year, transmission, engine, etc)
    Norton likes this.
  10. Jan 11, 2020 at 10:30 AM
    Yota31
    Shannon
    Alright thanks. Gonna wait to look at it tomorrow snowing and cold right now
  11. Jan 11, 2020 at 10:39 AM
    henryp
    Henry
    Montana
    It’s not impossible to run 2014 ECU on 2015. Just have a few more steps to go through. You can alway check with @JustDSM. He can hook you up with a tune. If you want to avoid the HP tuner, the easiest in my opinion is to get same part number ECU then install. Note that It’s not just plug and play, there are some other steps to take such as resync the immobilizer. I’m not sure if you also have to change the VIN # on the replacement ECU before Toyota will flash.
    JustDSM likes this.
  12. Jan 11, 2020 at 10:44 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    if you unhook the glovebox stick your phone up there and snap some pics. youll see it works well. takes 1 min.
    henryp likes this.
  13. Jan 11, 2020 at 10:46 AM
    JustDSM
    Justin
    Ogden, UT
    You can run other year ECU's if you wish too, but if you want to keep everything on the "up and up", just use the same year/trans type. The truck will run with the wrong VIN programmed, but you'll want to have the dealer correct that when they do the TRD Update flash.
    henryp[QUOTED] likes this.
  14. Jan 11, 2020 at 10:48 AM
    Norton
    +1 to all of this.
    Now that HPT is available, however, I wouldn't rush straight to replacing the ECU (unless you get a great deal on the specific model/calibration you need). HPT and @JustDSM should be able to get TRD's stock S/C calibration (or an even better one) onto your current ECU.
  15. Jan 11, 2020 at 10:54 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    @White lightning boosted you have to hold the traction button off for a few seconds to fully disable traction control intervention. You will typically see a light illuminated and then see the trac off light illuminate shortly after and that is your cue to roast em. Many vehicles are like this now where if you momentarily push it, it will not fully disengage nanny control.
  16. Jan 11, 2020 at 11:07 AM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    I think that was only after a certain year for Toyota. My Lexus won’t fully disable but I know newer models will. I think 4Runners also didn’t up until maybe 2008.
  17. Jan 11, 2020 at 11:08 AM
    henryp
    Henry
    Montana
    I mean, you can always pull a relay. For off road use of course. :mudding:
  18. Jan 11, 2020 at 11:19 AM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    I have a TRD sport, and if I hold the traction control button for around 5sec, at a dead stop in neutral, it will turn all the driver aids off. Its epic. The truck with the squiggles lights up as well as some other light... I cant remember what it says but it allows for a lot more slip in my LSD.
    EDIT: second light says AUTO LSD. This allows for exuberant wheel spin with no engine output limiting.
  19. Jan 11, 2020 at 11:21 AM
    Kelvin
    Kelvin Wheeeeee
    I’ve got 2 burned out cats and some CEL’s. I can burn my tires at will, in Mexico.
  20. Jan 11, 2020 at 11:27 AM
    Norton
    All explained here...
    henryp likes this.
