TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jan 17, 2020 at 4:29 PM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Got my flex a lite fan. Looks nice. Nice set up looks easy to wire. Can’t wait to put it all together.
    Side note. My buddy at work got all my exhaust studs outta one head. What a pain.
  2. Jan 17, 2020 at 4:36 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    When do go with the new fan? You guys replace the current one or this is in addition?
  3. Jan 17, 2020 at 4:37 PM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Looking forward to your impressions on the fan. Really would like you to update us on it after install. Its small size made me go another route.
  4. Jan 17, 2020 at 4:53 PM
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    Trying to lighten up the load on motor as much as possible.
    I won’t be able to notice power wise cu doing tons of stuff at the same time. But also never had an over heating problem before with stock radiator. Csf is going in with the fan
  5. Jan 17, 2020 at 4:58 PM
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    It was also only $270 with the controller. And will wire up a on switch also. Couldn’t pass it up.
  6. Jan 17, 2020 at 5:08 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Ive been driving around without a fan period. Definitely can tell a power difference. This spring I need to look into efan setups.
    I thought the flex a lite fan shroud didn’t even come close to fully covering our stock radiator. Did they finally change designs? Or did you just only get the closest fan diameter for the stock shroud
  7. Jan 17, 2020 at 5:14 PM
    mightytacoman
    Kel
    4.5L 1grfe
    That was my thoughts. Lots of surface area uncovered by the shroud in the install directions and just a single 12" fan. Maybe they changed the design.
  8. Jan 17, 2020 at 5:36 PM
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    No it’s still the same one. We will see. I know a lot of people say u get no gain and just keep the mechanical fan. But i usually go against what ever one says
    Roostfactor, jamesepoop and JustDSM like this.
  9. Jan 17, 2020 at 5:39 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    oil pressure, fuel pressure to list a couple i value for data.
  10. Jan 17, 2020 at 5:44 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    I’m running those two in the lotek pillar mount
  11. Jan 17, 2020 at 5:44 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    wouldnt electrical load be a factor if using an e-fan? its taxing the alternator. load in voltage is drag. i at some point want an e-fan. im considering a lexus unit from ebay. an oem toyota for 1. second build quality for longevity.
  12. Jan 17, 2020 at 5:46 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    definately on my to do list.:thumbsup:
  13. Jan 17, 2020 at 5:47 PM
    mightytacoman
    Kel
    4.5L 1grfe
    It definitely is a factor. Upgrading to a bigger alternator might be needed pending your current electrical set up and other aftermarket add ons
  14. Jan 17, 2020 at 5:53 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    do you think the offroad model has an acceptable output? should i compare it to the alternator output of the potential donor lexus? so if the lexus of choice has a similar or less output on the alternator would i be in good shape?
  15. Jan 17, 2020 at 6:05 PM
    mightytacoman
    Kel
    4.5L 1grfe
    It does if you're not running other high output options at the same time, such as a big air compressor, lots of offroad lights, winch etc. The flex a lite only draws ~18amps
  16. Jan 17, 2020 at 6:41 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i agree. i personally dont have high draw accessories. maybe the oem option may be my thing.
  17. Jan 17, 2020 at 7:16 PM
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    I found some posts at #15070. Ill check the PCV hose but I havnt noticed anything other than right at the snout in the pics previously posted. Tomorrow Ill report back what I find. Thanks for the suggestion (glad ya got that resi topped off with coolant haha!)
  18. Jan 17, 2020 at 7:31 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    It’s fine....not nearly as obstructive as you’d think. It’s worth putting them there.
    12TRDTacoma[OP] likes this.
  19. Jan 17, 2020 at 8:30 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    my only wonder is airbag function.
  20. Jan 17, 2020 at 8:42 PM
    nudavinci64
    Robert
    yah I am still second guessing that. Has to be a way to work around it.
