TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jan 20, 2020 at 9:37 AM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    WTF. Very surprised by that
    Norton and 12TRDTacoma[OP] like this.
  2. Jan 20, 2020 at 9:58 AM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    36k seems really low..... what were you doing?
  3. Jan 20, 2020 at 10:09 AM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    ya lets hear the story... theres always a story
  4. Jan 20, 2020 at 11:02 AM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    If you figure out a way to do a V8 swap and keep 4x4 that’d be awesome. After a very brief search, it seems 1st gens were easier to swap to V8. If you rebuild you could join those cool kids in the stroker club. Replace would be cheapest, but you hope it’s a good engine. I’m also interested in the back story.
    TRON likes this.
  5. Jan 20, 2020 at 11:54 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    A lot of work, but rings and pistons are an easy fix. Just no stronger than before. Done that a couple of times. ;)
    Roostfactor likes this.
  6. Jan 20, 2020 at 12:02 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Id rec its time for a set of total seal piston rings.
    Roostfactor and Torspd like this.
  7. Jan 20, 2020 at 12:05 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Okay, but the question is, is that a valves issue at your mileage, or a piston issue? You are a 2014 so you can't have that much miles on it..
    Or can you?
  8. Jan 20, 2020 at 12:53 PM
    sbchero
    sbchero Wheeler
    Garrett
    Brighton CO
    14 TRD Sport 4x4
    TC L/T, King shocks/bumps, F/R ARB's, RCV Shafts, glassworks fenders/bedsides.
    we're thinking rings, 20psi dry and 60 wet on 5&6. leads to rings?
    had the misfire codes cold (and would run like garbage) warmed up it ran good (well enough to not throw codes)
    dont know what i did, had the SC installed at the dealer at about 3k miles. ran it stock till about 3k miles ago when i started to get the misfire code. did injectors (thinking it could fix the problem, but didnt). i have bad luck with vehicles, had a 7.3L tow rig that cracked a rocker arm at 100k.
    I think ill rebuild the 4L. have a line in a stroker kit with cams and stuff for a great price from a member on here. id like to have the motor built by a reputable shop so i can drop it in. any recommendations?
    12TRDTacoma[OP] likes this.
  9. Jan 20, 2020 at 12:58 PM
    420taco
    420taco Well-Known Member
    Justin
    PA
    Stock tune? I’d do a leak down and figure out where the issue is, maybe just have to pull the heads.
    Also, is the intercooler filled and pump working?
    Roostfactor and 12TRDTacoma[OP] like this.
  10. Jan 20, 2020 at 1:17 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    The amount of dudes that have found dry cooling systems has me checking mine like a crackhead
  11. Jan 20, 2020 at 1:17 PM
    sbchero
    sbchero Wheeler
    Garrett
    Brighton CO
    14 TRD Sport 4x4
    it was the stock TRD tune, now HP tuners for the injectors and pulley.
    affirmative on the intercooler filled and pump working.
  12. Jan 20, 2020 at 1:41 PM
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    Not quite. It is supposed to be a 34, but it is still only like a 33 3/4".
  13. Jan 20, 2020 at 1:58 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Agreed. I periodically check mine while the truck is on to see if I can feel activity from the inlet and outlet. It's just good to check anyways.
  14. Jan 20, 2020 at 2:17 PM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    R&L Engines out of Dover NH did an excellent job on mine with fast turn around.
  15. Jan 20, 2020 at 2:42 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I check mine often especially because it leaks. And every now and again my pump makes a strange noise, I think I am going to replace it soon just to be safe. I just switched jobs again so I should be good to go and have some free time to work on the truck finally.
  16. Jan 20, 2020 at 3:36 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    The saga continues..
    Just dropped the truck off at another exhaust shop per a recommendation. Definitely good vibes from the owner. 62 and been doing it for 41 years. Nice local old timer. Same old as far as the exhaust. 2.5" Y, no cats, into 3" collector, 3" piping into a resonator and then into the biggest Magnaflow he can stuff in there. Dumped over axle. He quoted high at 600 and said it'll most likely be under that.
    Pick it back up tomorrow.
  17. Jan 20, 2020 at 4:08 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    That sound from the pump is probably air bubbles and/or not enough coolant in the reservoir
  18. Jan 20, 2020 at 4:28 PM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    No, technically an aftermarket catch can will fail the visual portion of the CA smog check. But it was the least of my worries when it came to the bi-annual checks and I've never been dinged for it. My aftermarket catch can is anodized black in color and I keep it sort of dirty/dusty to blend into the engine bay.
    I had to smog my truck last month. First shop, the tech flat out refused the job after asking me to pop my hood. The 2nd shop wouldn't proceed with the test because I didn't have the carb eo# sticker for the trd blower. (Never came with my fitkit and toyota USA was a dead lead).
    The 3rd shop tested me without any questions and the tech/owner complimented me on my truck and it passed without a hitch.
    All 3 shops were smog only test centers and not affiliated. 1-man operations style. 3rd shop was in a less affluent part of NorCal.
    :anonymous:
  19. Jan 20, 2020 at 4:31 PM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    That's not good.. I have topped off the resi recently and it's still doing it so I guess time to upgrade lol.
  20. Jan 20, 2020 at 4:52 PM
    jamesepoop
    jamesepoop Well-Known Member
    California
    2007 Fj Cruiser
    What the heck? The stock plastic coolant bottle leaks? What leaks and what do I need to get it to stop?
