TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jan 20, 2020 at 4:52 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    If they only knew that catch cans are dually beneficial to engines and the environment.......
  2. Jan 20, 2020 at 5:03 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    yeah unfortunately that sounds like a lower-end issue.
    I wouldn't even bother doing a leak down if the rings test it out bad after getting more compression by soaking them. It's a bottom end issue and to pursue upper-end work is a fruitless venture at this point for him unfortunately.
    See below.
    Yeah a lot of smog shops have no freaking clue what they are doing, which is why they are overnight businesses, one day they are here, the next they are gone, BAR usually traps them and they have no clue what the hell they are doing, so they screwed themselves.
    I got a hold of my sticker through the dealer earlier this last year, buddy was awesome about getting it.
    I stay away from anything that is not either a dark gray color or black under the hood because I want a chance nothing when it comes time for smog. The more incognito everything is the better.
    If it is making noise, I would replace it for sure. It is only a matter of time before it craps out on you.
    It's the stupidest rule ever. Even if it improves emissions or does the engine better than the current OE setup they will not pass it because it is not OE equipment or does not have a CARB EO number.
  3. Jan 20, 2020 at 5:28 PM
    Lucifer29
    Lucifer29 Well-Known Member
    Red
    Cold air intake with our superchargers? Which do you recommend? 2.5 pulley ued equal headers shift kit urd y pipe pedal commander fpr mod. Lookin at volant with the scoop. Lemme know input?
  4. Jan 20, 2020 at 6:10 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It's a pick your evil thing to be honest with you but the intakes which have been found to make the most power that I know of at least are the AFE stage 2, the AFE Momentum GT, and the URD ram air intake. All will require minor modifications to be able to retrofit parts of it on to our trucks specifically.
    I am in no position to speak for the volant intakes as not many members that I know of own them and have given raving reviews about it.
  5. Jan 20, 2020 at 6:13 PM
    oni06
    oni06 Well-Known Member
    Its hit or miss but I think maybe more miss.
    Mine leaks and once it got low enough the power from the charger dropped of dramatically.
    Leaves a messy of dried up coolant in the engine bay as well.
    I haven't fixed it yet. Just keep checking it every few months and adding as needed.
  6. Jan 20, 2020 at 6:48 PM
    jamesepoop
    jamesepoop Well-Known Member
    California
    2007 Fj Cruiser
    Thank you for the heads up. Sure will be checking.
    This sounds really half assed on Magnuson's part.
    Does adding a surge/overflow help it? Or replace with an aluminum type coolant can that may hold pressure consistently? Doesn't sound like a cheap fix
  7. Jan 20, 2020 at 7:15 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    not a terrible price. no exhaust shop would touch mine. had to find a private shop. hope it turns out smiles.
  8. Jan 20, 2020 at 7:18 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    on this note i accidentally switched my lines when i changed my pump mount. girgling air randomly. 5 min. line swap and all good. i have my intercooler out line to the top inlet on my overflow/resivoir. my reccomendation unless others say differently. keeps constant fluid to push at the pump.
  9. Jan 20, 2020 at 7:24 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i have had a few different intakes. my current is afe momentum gt. pricey yet very well refined. im happy....til i slice it for my 3.5" pipe.
    12TRDTacoma[OP] likes this.
  10. Jan 20, 2020 at 7:26 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Pretty much what this is. Most others wouldn't do it either. Feeling positive this go around
  11. Jan 20, 2020 at 7:30 PM
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    Im running the URD TCAI and have had no issues with it. I am conscious of water when offroading but it has not stopped me from doing anything (im not a big mud person, I prefer rock crawling or highspeed dirt)
  12. Jan 20, 2020 at 7:42 PM
    oni06
    I don't think adding a surge/overflow will help as there isn't much in the way of pressure within the system. Though if I am wrong the guys here will chime in.
    The main issue seems to be the sealing of the hose to the reservoir on the input and output barbs.
    This will fix it :D
    https://www.shopfigs.com/v3/TANK-COOL-FAB-MAG
  13. Jan 20, 2020 at 7:51 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
  14. Jan 20, 2020 at 8:26 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    So an expensive fix would be to buy a figgs... I am hoping @Roostfactor the wizard will be able to make us these maybe sometime this year eh.. ehh???
    basically the cap leaks and so does the bottom nipple, can temporarily fix it by tightening the hose clamp more but I am pretty sure if you get it too tight it will crack the wimpy plastic they use. A solid aluminum resi would be best probably.
  15. Jan 20, 2020 at 8:51 PM
    oni06
    Mine actually leaks at the upper and lower nipples
  16. Jan 20, 2020 at 8:53 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    or like me you could buy a canton, and the retarded expensive cap. and fittings, and more fittings. only to be 9$ shy of a figgs.
  17. Jan 20, 2020 at 8:54 PM
    henryp
    henryp A member of TW
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    But it’s one heck of a cap
  18. Jan 20, 2020 at 9:09 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    No one here DARE talk bad about Figgs.
    They are the best ever in the world and we are not deserving of their products.
    :D
  19. Jan 20, 2020 at 9:12 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    it is pretty sweet. billet machined fantasticness. super slick click to perfect tension. like our highly refined gas capso_O
  20. Jan 21, 2020 at 2:02 AM
    jamesepoop
    California
    2007 Fj Cruiser
    Are you still using standard worm gear clamps? Or have people noticed a difference in smooth band work clamps? Or constant tension like OE heater hose clamps? I was hoping to hold off on an aluminum tank but being stranded far out somewhere due to a overheating or lack of parts on a trail does not sound good.
