TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jan 23, 2020 at 1:16 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Shit.. I hear you on adapters. But tbh I trust this way more than say wheel adapters that a lot of people run. Lol
  2. Jan 23, 2020 at 1:18 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I run wheel adapters.. well, spacers, not sure if we are talking about the same thing. Hahaha.
  3. Jan 23, 2020 at 1:20 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Same same. Fuck those things. Lol I've seen multiple fail
  4. Jan 23, 2020 at 2:16 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    See my sig pic?
    I did that on wheel spacers, and I'm still running the same set to this day. 5 years later, nearly 60,000 high speed miles later. ;)
  5. Jan 23, 2020 at 2:19 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    :notsure: what to tell ya.. you're lucky. I've personally seen em fail on just pavement out here.. twice. Spidertrax and Bora. studs sheared right off. no thanks. not worth the risk imo. to each their own tho.
  6. Jan 23, 2020 at 2:25 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Been running my spacers for years as well...
    12TRDTacoma[OP] likes this.
  7. Jan 23, 2020 at 2:40 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Did you see those fails with guys that wheel their trucks, or have wheeled them in the past and just happen to drive it on pavement during the failing incident? Or were they trucks that never see dirt?
  8. Jan 23, 2020 at 2:41 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That's really weird. Could had been user error though. Loose but behind the wheel ya know? :D
  9. Jan 23, 2020 at 2:48 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    these were my close wheeling/camping homies.. I'd tag em but they've been banned over the years. It was not user error, they were used offroad, and failed on pavement. I think both instances was while turning. We arent noobs and dont pussyfoot.. so they had some mileage. both have never ran them since.
  10. Jan 23, 2020 at 2:51 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    My curiosity was just more with how the truck is used. I don’t think I’d use them if I was as hard on my truck as you guys are.
    Roostfactor and XPOTRPR[QUOTED] like this.
  11. Jan 23, 2020 at 2:53 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It's sort of a trip how you see these trucks just ran the hell through their paces and they hold up fine and then as soon as you get on the road they break hard.
    I don't know, I've had great luck with my Boras so if it ain't broke...
  12. Jan 23, 2020 at 4:29 PM
    jamesepoop
    jamesepoop Well-Known Member
    California
    2007 Fj Cruiser
    On BORAs, 2" in the rear and on 37s. Wheel and tire are about 95lbs.
  13. Jan 23, 2020 at 4:38 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Well my clutch was slipping in the higher gears with a brand new clutch 8k miles on it about 5 months ago. I say “was” cause now it’s holding. The only thing I’ve done recently is change my idler bearings and crank pulley. And the crank pulley is my thought. Cause when I was tightening the crank bolt with my 4ft breaker bar I had it in 6 gear. And the crank turned some in both directions while tightening or loosening that crank bolt. So could that have helped better match up my pressure plate to the flywheel?!
  14. Jan 23, 2020 at 5:40 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I just got my Mishimoto t stat in and my initial observations are that it is much more stout than it's Motorad competitive counterpart. When I do my thermostat re-exchange I'll take pictures comparing the very notable differences between the two.
    Without documenting in pictures, I will say, stick to OE quality, or Mishimoto for a lower degree operating temp t stat. The Motorad one will not last very long.
  15. Jan 23, 2020 at 6:06 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    mishimoto housing and thermostat ordered...
  16. Jan 23, 2020 at 6:09 PM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    I thought the mishimoto 160 would over cool most of our non sleeved engines? Everyone just planning on retuning or turning that CEL off?
  17. Jan 23, 2020 at 6:17 PM
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    No. Thresholds will be lowered to accommodate. Then, timing thusly bumped to take advantage of the cooler temps.
    That's the idea anyway.
    12TRDTacoma[OP] and zippsub9 like this.
  18. Jan 23, 2020 at 6:20 PM
    mightytacoman
    Kel
    4.5L 1grfe
    Isn't that a yes? Thesholds lowered sounds like it's too cold and retuning is required
  19. Jan 23, 2020 at 6:23 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    I am more concerned sitting on hot trails not moving as much as opposed to running down the highway.
    mightytacoman[QUOTED] likes this.
  20. Jan 23, 2020 at 6:34 PM
    BillDaCat8
    Jake
    PHX
    We're simply moving the temperature operating window down by 20 degrees. (providing that your heat dissipation capabilities are up to the task. I.e: a bad ass radiator) The advantage to that is that you can run more timing.
    I speak of the thresholds in the ECU regarding temps. Now, certainly, an un-tuned truck will have an MIL pop with a 160 degree tstat.
    Maybe I mis-read what you were getting at. I concur. A 160 tstat is a bad idea unless you have tuning capabilities and a radiator that's capable of handling the rigors of keeping the 1GR 20 degrees cooler than stock.
