TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jan 24, 2020 at 6:39 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I'm bad about that myself... Impact. lol
    Roostfactor and 12TRDTacoma[OP] like this.
  2. Jan 24, 2020 at 6:45 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Torque wrench, red loctite and periodic checks for me. Never had an issue either. I have to run them in the rear to clear shocks until I get a wider axle. And as in your sig, my truck too is not babied off road
  3. Jan 24, 2020 at 6:48 AM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Always gotta use the torque wrench... the ugga dugga method has never sat well with me.
    snowsk8air2, 420taco and Torspd like this.
  4. Jan 24, 2020 at 7:26 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I 100% am. :)
    I just set 'em and forget 'em. I have never had an issue with loose nuts. I don't loctite anything. Hahahahaha.
    I have used the ugga ugga method forever (actually I use an impact often) and both have always served me very well. :laugh:
    When in doubt, ugga ugga.
  5. Jan 24, 2020 at 7:34 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I am a bit confused.. how does going to a 160* thermostat put more stress on the radiator? It seems like since the tstat is opening sooner that it would be less prone to heat soak and rising temps over time. Can anyone shed a little more light on this? This is assuming the tune stays the same and you dont run more timing, i could see how that or adding sleeves would tax the cooling system, but all other things the same, how is just swapping the tstat gonna tax the cooling system more if it runs cooler afterwards
  6. Jan 24, 2020 at 7:40 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    It doesn't add any more physical pressure stress. :thumbsup:
  7. Jan 24, 2020 at 9:11 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    im hesitant on getting spacers again. accidentally bought some offbrand ones and could see the runout they caused. dont really want to dump money into new wheels either. ugh.
    12TRDTacoma[OP] likes this.
  8. Jan 24, 2020 at 9:26 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Spacers will put the same amount of stress on the factory studs, bearings, etc... as if you got wheels wheels with less back spacing to achieve the same tire position. The only downside imho is you have 2 sets of studs to potentially shear instead of just one. I wouldn’t and clearly haven’t hesitated to run them so long as they are a quality pair. Probably 80% of long travel trucks out there are running spacers to clear their shocks.
  9. Jan 24, 2020 at 9:29 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    think with spidertrax brand ill be fine. those scs brushed copper are tempting.
  10. Jan 24, 2020 at 9:37 AM
    jamesepoop
    jamesepoop Well-Known Member
    California
    2007 Fj Cruiser
    Thanks for that. While I don't have issues with using a URD adapter, I would also prefer to have a 1 piece neck over an adapter.
  11. Jan 24, 2020 at 9:43 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    does the one piece unit have more clearence to the s/c belt?
  12. Jan 24, 2020 at 10:07 AM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
  13. Jan 24, 2020 at 10:23 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
  14. Jan 24, 2020 at 10:37 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    1000 bolts later. o_O
    rheath08 likes this.
  15. Jan 24, 2020 at 10:39 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    yeah. beyond my skill set.
    JuanitoBonito likes this.
  16. Jan 24, 2020 at 10:44 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Dude, the amount of bolts there especially since I'm a 12 and he to deal with that craptastic air injection setup almost got intimidating to me. Especially due to the time constraint I was working with and the general fact that daylight was dying. There is no shame in taking it to a shop if you feel it is too much for you.
  17. Jan 24, 2020 at 10:55 AM
    rheath08
    Russell
    Bakersfield, CA
    @12TRDTacoma put your big boy panties on and dig in! :rofl:
    Just teasing.
  18. Jan 24, 2020 at 11:12 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I had no choice man! It got to a point where I felt like it was feast or famine.
    That is why I said a long time ago that cam gears is as far as I'll ever take it.
  19. Jan 24, 2020 at 11:20 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Loving my scs so far. My 5th should be arriving today actually and for the first time since the truck was new I will have a full size matching spare lol
  20. Jan 24, 2020 at 11:23 AM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I got my matching spare awhile ago and it’s nice. Only problem is I want to upgrade to the flow formed wheels now... I may have a problem lol.
