TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jan 24, 2020 at 3:39 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I'm wondering if your cooling system in that truck was properly bled of air bubbles because these trucks are known to cook you with the heater on.
  2. Jan 24, 2020 at 3:42 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    thanks! @JustDSM mentioned slight tweaks are ideal for this change. im game if i dont have to put studs back in. pulling them was a chore.
  3. Jan 24, 2020 at 3:45 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    something was weird. it never heated well. glad i totalled it and got one with a s/c.:D
  4. Jan 24, 2020 at 3:46 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Pulling them? For running the URD one?
    He has his hands full for changes on my next log. Lol.
  5. Jan 24, 2020 at 3:49 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    yeah. had to pull studs for the urd. @JustDSM can make everything quick work when all channels are open. i need to raise some fuss with hp to get all mine up and going. i really want that 3.5" intake tube to go in.
  6. Jan 24, 2020 at 3:54 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    We’ve got the channels for yours now!
    12TRDTacoma[OP] likes this.
  7. Jan 24, 2020 at 4:15 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    ??? i thought mine were still inoperable.
  8. Jan 24, 2020 at 4:22 PM
    JustDSM
    Justin
    Ogden, UT
    That last update we did, they were corrected.
  9. Jan 24, 2020 at 4:23 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    awesome! i misunderstood.
    JustDSM[QUOTED] likes this.
  10. Jan 24, 2020 at 4:50 PM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
  11. Jan 24, 2020 at 4:58 PM
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    Nvm. Read page one stupid!
  12. Jan 24, 2020 at 5:34 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    in regards to the debate of s/c coolant reservoir size for temps. ive found, with my particular routing. 1' before s/c intercooler inlet temps are almost right with ambient. i have a canton racing tank near the back passenger side firewall. unsheilded from header heat after 45min. of shitty stop and go traffic incoming temps are only 7* above ambient. so, id say resi tank size doesnt play a large hand in temps of s/c fluid. every setup may have different results. this is mine. just thought id put this out as a reference.
  13. Jan 24, 2020 at 6:06 PM
    novanut21
    novanut21 Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, Satoshi grille, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley, HID Retrofit.
    Anybody seen one of these kits on a FI vehicle? I like the concept, i wish there was more photos.
    https://www.activeinterchiller.com/
    I seen it on Fasterproms youtube channel they had one on a nasty copo colorado.
    jamesepoop likes this.
  14. Jan 24, 2020 at 6:08 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
  15. Jan 24, 2020 at 6:14 PM
    novanut21
    Brent
    North Central,WV
    2009 TRD SPORT
    Nice! Be awesome to see a before and after. Especially with some adjustments using hp tuners.
  16. Jan 24, 2020 at 6:16 PM
    novanut21
    Brent
    North Central,WV
    2009 TRD SPORT
    I looked through some google images of dyno sheets. Of course applications and vehicles differ but most seen 40hp peak @ redline.
  17. Jan 24, 2020 at 6:17 PM
    420taco
    420taco Well-Known Member
    Justin
    PA
    That’s badass, only problem is our AC isn’t sized to cool the cabin AND all that damn blower heat.
  18. Jan 24, 2020 at 6:18 PM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    I think it would work great. The one bad thing about these systems is the fact that you have to bypass your stock heat exchanger. Which then means you have to run your AC 24/7 inorder to cool your supercharger. Then when you are coming home from camping on a long road trip and your AC system decides to take a permanent nap you are screwed. You can configure it so you can bypass the killerchiller to run the stock HE though. I was close to buying one of these systems but at the time my AC system didn't work right so I didn't want to kill my in cab performance. A few visits to Toyota later they replaced my whole AC system and it still sucked, so I put a resister inline of the thermometer that reads your evap core temp and that solved the issue.
    Roostfactor likes this.
  19. Jan 24, 2020 at 6:22 PM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    I looked into it for a while but in all the research (Tundra guys who used killer chillers) it seems like this type of system is great for track runs but heat soaks quickly under repeated use.
    Murphinator[QUOTED] likes this.
  20. Jan 24, 2020 at 6:24 PM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Indeed. It also seems they have a new drag kit (more $$) but half the recovery time. I think for DD with some spirited runs every now and then would be ok, but I do wonder what would happen if you are boosting up a steep grade for a few minutes.
