TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jan 31, 2020 at 10:46 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I have a squeak that is originating from my accessory serpentine belt, I gotta replace that and I got a replacement Toyota belt ready to go for that. Gotta put some grease my NST crank dampner pulley while I'm in there, my Delta Joints when I get them hopefully on Monday, and then my OE headlight replacements will be here tomorrow.
    Projects.
  2. Jan 31, 2020 at 10:46 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Life will be my deciding factor in motor replacement choice when it comes. Really I don’t see a need for much more than 500whp so a sc 5.7 should be manageable to keep it Toyota. Then again for a similar price I could probably pull 800-1k hp from a LS based platform.
  3. Jan 31, 2020 at 10:48 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Come take a ride in the “race truck” and see what noises are “normal”
  4. Jan 31, 2020 at 10:49 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah but how much more retrofit and Fab will you need to do in order to fit that in? Everything will need changing from cooling system to transmission... Then again I'm sure there are adapters for the bellhousing they sell. I'm sure Hinson makes retrofit engine mounts too for engine swap LS projects too. You have many options open but yeah, life is always a huge deciding factor.
  5. Jan 31, 2020 at 10:49 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I've come to HATE noises. This truck is chock full of them so I am trying to eliminate as many of them as I can.
  6. Jan 31, 2020 at 11:03 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    $5-10k was the best damn mod I ever did to this truck and was buying a dd. It’s smooth, quiet, heated damn seats lol. That said I love my damn truck as slow as it is in comparison to one’s like yours. Whiskey is wearing off and it’s damn tomorrow where I’m at and have side jobs to pay for parts in the morning. Stay boosted my peeps
  7. Feb 1, 2020 at 1:12 AM
    australian hilux
    australian hilux Well-Known Member
    Justin
    2005 Toyota hilux v6 4.0L 1gr-fe
    None at this point
    Hey all! Hope your all well. Just having a thought, is it possible to put on a smaller crank pulley that runs the sc? I just stuck my head down for a look and wondered if it was possible. Or is it just not possible due to belt tensioner and room for where the belt runs? Your thoughts?
  8. Feb 1, 2020 at 4:12 AM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Yes, it has been discussed. We looked at a larger crank pulley but there are some immediate clearance issues. You have to go bigger not smaller if you want more boost though.
    Roostfactor and 12TRDTacoma[OP] like this.
  9. Feb 1, 2020 at 7:59 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    i respect the desire to keep toyota running gear despite it costing more. we all realize cost effective left this group long ago.
  10. Feb 1, 2020 at 7:59 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yep, this right here. ^^^
    It takes too much effort to go bigger given that we already have options available to us to do higher boost while negating slip I personally don't see a need for going with a larger crank pulley and complicating things down the road with the potential of having to go with random not often sold bearings for their respective required replacement idler pulleys.
  11. Feb 1, 2020 at 8:01 AM
    1sandytaco
    1sandytaco Well-Known Member
    SLC, UT
    2015 - Black
    Supercharged
    Alright, I'm dumb. I messed something up while attempting to wire my Boost gauge late last night. It is lit, but not functioning properly (i.e. measuring boost or dimming) I ran the red and pink to an add a fuse in the ignition spot, a ground, and the gray wire from the gauge to green wire with the white stripe for the temp control beneath the radio. IMG_0160.jpg
    The dimming is weird and isn't behaving how it should. Should I be utilizing the solid Green 12v wire somehow? The switch seems to be pulsing brighter to darker when I'm in drive (yet when in park is solid, and does not vary).
    ALSO, the boost needle isn't moving. I went straight from the Boost port on the SC to the sensor and did not utilize the supplied "T".
    Can anyone tell me where my mistake is (other than being an idiot trying to do stuff)? Before starting the project I tried to search for relevant threads and keep getting lead back here. Thanks for any help you can provide.
  12. Feb 1, 2020 at 8:01 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    sound deadening, loud audio, burly exhaust, windows half down is my solution.
  13. Feb 1, 2020 at 8:04 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i have aem. cant quite remember but i dont think i connected any fany dimming lights, or uego controller wires. just the basics. things work fine.
    12TRDTacoma[OP] likes this.
  14. Feb 1, 2020 at 8:08 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    I mean 500whp in these trucks would be amazing. And I think that is a very achievable number with the 5.7 tundra motor platform while keeping it very Toyota reliable. Plus everyone and their grandma does an LS swap. This said I hope I don’t have to deal with this decision and project for at least a few years to come.
  15. Feb 1, 2020 at 8:15 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    same here. as much of a hp whore i be i realize over 500 would turn our drivetrain into recylcing material in no time. keeping things all toyota/lexus would keep my ocd at bay.
  16. Feb 1, 2020 at 8:34 AM
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    Someone who gets my kind of mileage. I was just at 168 miles when I gassed, but I do gas up at 1/4 of a tank. Not sure what the gas light looks like as I try to never let it get below 1/4 of a tank. But doing the math, if I can get between 180 and 200 miles on a "tank" I am where I have been for the last 8 years (most of the time). Towing (6500-7500 lbs) in a heavy head wind or going up hill the whole time I get about 100 miles a tank. Towing normally, not a direct fast head wind and just running 65-70 up the mountain passes I can get 140-170 miles a tank. And I know that I have never been able to go a whole tank without some good boosting. So to know what kind of mileage I would get if I could drive like a "normal" person for a whole tank is completely unknown. And speaking of boost, Tuesday night, wow was the truck running good! Temp was in the mid 30's, half a tank of gas, no extra weight, yeah my son and I had some fun. And I hit 4.2lbs of boost! Yeah buddy. Oh to know the joy of this 8lbs and above that you speak of! LOL
  17. Feb 1, 2020 at 8:46 AM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Just to clarify, your red (constant 12v) and pink (ign switched 12v) are going to two separate tap fuses?
    Do the temp control lights dim? I honestly don't remember but if they don't that could be a reason for the light output problem.
    No idea on the sensor routing as I don't have a boost gauge.
  18. Feb 1, 2020 at 8:48 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    your mileage is on par for the duty you ask of the truck. low gears, heavy hauling, big tires. takes a certain amount of fuel to move that weight. a full size wont do much different in mileage. might be easier on the rig.
    mr.trd[QUOTED] likes this.
  19. Feb 1, 2020 at 9:00 AM
    1sandytaco
    SLC, UT
    2015 - Black
    Supercharged
    The red and pink go to the same fuse (the instructions specified that was ok, but the gauge needle would zero out upon each start prior to reading boost levels).
    I found a thread that specified the temp controls have a dimmer:
    https://www.tacomaworld.com/threads/dimmer-for-boost-gauge.483822/
    Still curious why the boost won't read though?
  20. Feb 1, 2020 at 9:22 AM
    madsand
    madsand wanderer
    sandz
    Costa Mesa, CA
    2012 DBLCB LB sports 4x4 SC
    Icon 2.5" Remote Reservoir Extended Travel CDCV Icon tubular UCA Icon add a leaf Method NV wheels Nitto trail grappler MT 285/70/17 Weather Tech floor mat All Pro rock slider
    Ok since were talking about gauges. I thinking installing AFR gauges. My question is do you need to run two gauge or one? If can can do it which side of imagine should i monitor?
