TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Feb 2, 2020 at 4:00 PM
    jamesepoop
    jamesepoop Well-Known Member
    California
    2007 Fj Cruiser
    Good point. Deleted. Finally a day off and I get to play with my S/C goodies. Finally installed a new aeromotive fuel pump to prep and slowly installing the Maggy bolt on parts. Whoever said running a new fuel pump makes it feel like a new car (might be no one, but internet hearsay) was a huge disappointment :rolleyes:.
  2. Feb 2, 2020 at 4:33 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Cease and desist all oil debating! This is NOT the mod thread (and no mod does not stand for moderators, lol). If we blow up our engines due to lack of maintenance then that sucks, but then it is all the more reason to do a LS swap.
    jamesepoop likes this.
  3. Feb 2, 2020 at 4:35 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    do you have an ultra gauge to monitor engine temps?
    BassAckwards[QUOTED] likes this.
  4. Feb 2, 2020 at 4:42 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    youll notice a difference when you push it hard. i had a 2.7 on for a couple weeks before doing mine. even with a meth spray i noticed an immediate change after.
    jamesepoop[QUOTED] likes this.
  5. Feb 2, 2020 at 4:53 PM
    jamesepoop
    California
    2007 Fj Cruiser
    That's what I like to hear. Jumping directly to 2.7 when I install but no meth spray or 7th inj. I'll install a wideband to see if it's breaking up on WOT but it seems general consensus that 2.7 and 455cc injectors were holding up. Wish I had a way to check inj duty cycle... I asked U R D what numbers were like but he skirted past the answer. Any neg experiences? Or am I doomed?
  6. Feb 2, 2020 at 5:34 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Ordered a tester, doing some more research but hope to do this next weekend
    Yes sir i do, they have been looking solid. Hovering around 180-185* and never getting hotter than that. I do assume if i ran it long enough with this problem that it would cause overheating since the coolant isnt returning to the radiator. Just lucky i caught it early i guess. Hope to learn more in the next few days.
  7. Feb 2, 2020 at 6:14 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    also why i thought t-stat. could a malfunction cause this?
  8. Feb 2, 2020 at 6:16 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    my meth gauge shows idc. youll be fine. stock injectors, trd tune, and a 2.5 at sea level were fine on mine.
  9. Feb 2, 2020 at 7:26 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    +1. Wondered the same thing.
    I realize that's an UG, but what display is that or how did you configure it to display the info in that format?
  10. Feb 2, 2020 at 8:16 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    The only thing I had to program was for the trans temp which I think I got from @12TRDTacoma in a random thread. Other than that you just select which gauges you want, you cab make like 6 or 8 pages, each page can have up to 8 readings.
  11. Feb 2, 2020 at 8:27 PM
    Norton
    I've customized some pages but, IIRC, they're all laid out like this
    I don't recall any setup with side-by-side columns of 4 gauges each.
  12. Feb 2, 2020 at 8:29 PM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    What UG do you have? You should be able to select 8 gauges and it should automatically format the page. If not I think in page settings you can change it to 8 gauges.
    Norton[QUOTED] likes this.
  13. Feb 2, 2020 at 8:36 PM
    Norton
    That's a good question! I've had it a while, so I'm not sure, but I THINK it's an UltraGauge EM. I'll have to try configuring 8 gauges on a page... Thanks!
  14. Feb 2, 2020 at 9:06 PM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    No problem! I have the MX 1.3 I think. It may be a 1.2 not sure, I got it with my first taco many years ago now as you can see by the screen not being in the best condition. Now that I think about it I do think you have to go to the page settings and change it to 8 in order for it to show all 8 gauges.
  15. Feb 2, 2020 at 10:34 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I don't have an Ultra or a Scangauge so I wouldn't know how to program for trans temp. Are you sure you got it from me? I don't recall mentioning anything regarding programming.
    nudavinci64 likes this.
  16. Feb 3, 2020 at 4:49 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I can admit to that, quite a few times. It all depends on the various pumps and contaminants that were transferred from those to tanks into the owners' tanks. I changed them, they came back with a surprised and happy demeanor of clear and obvious improvement. Vocalizing such.
  17. Feb 3, 2020 at 4:51 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Quite curious myself.
  18. Feb 3, 2020 at 6:16 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    the scan gauge i briefly had picked up trans temp. on a stock motor with mild temps mine stayed a consistent 192*.
  19. Feb 3, 2020 at 6:19 AM
    BassAckwards
    Im not sure but it seems like if the tstat was causing an issue it wouldnt open up and thatd cause overheating or it would stay open and then that wouldnt allow it to get up to operating temps. Thats just me thinking through it though, im not sure that is 100% correct
  20. Feb 3, 2020 at 6:22 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    im not sure at all. just thought id suggest it as its an inline component. i was thinking a possible blockage.
