TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Feb 4, 2020 at 10:44 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Yeah it's not.
    The removal and reinstallation process of that thing is a solid "fuck that" in my book.
  2. Feb 4, 2020 at 12:23 PM
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    Who is running a higher pressure radiator cap? And can anyone give a breakdown of trade offs and how they pertain to lower temp thermostats? I get the basics of things but would like to understand their relationships as it pertains to the 4.0 with S/C.
    Lower temp T-stat will open sooner, allowing for the coolant to circulate through radiator, thus keeping engine temps down. This needs to be corrected in the ECU. I am running the 170 with UCON. I assume it takes that into consideration and adjust timing and fuel. At some point the benefits will become a hindrance to the cab heaters ability to create acceptable heat.
    High pressure radiator cap will allow for higher coolant temp before boiling... and then pushing coolant to the overflow tank. But could this cover up any issues within the coolant system? Or would it present them sooner?
    Am I close?
  3. Feb 4, 2020 at 12:27 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    From what I understand you guys have an aluminum radiator upgrade.
    I’d say run the higher pressure cap only when you upgrade radiators (if there’s any benefit). I ran a higher pressure TRD cap on my stock radiator and the additional pressure made my radiator spring a leak on a drive home. Radiator lasted maybe 2000 miles.
  4. Feb 4, 2020 at 12:42 PM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    a higher pressure cap will just let the coolant heat up more before being pushed into the overflow. on a vehicle with a overflow bottle there isnt much point imo since all youre doing is retaining more heat/you have a problem if your pushing coolant out the overflow bottle. we do it on dirtbikes to help prevent coolant being lost to the ground.
  5. Feb 4, 2020 at 12:52 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    From a performance standpoint I never saw a point in installing a higher pressure radiator cap myself. From an off-road Motorsports standpoint like dirtbikes and quads I could definitely see the benefit in doing such a "mod."
  6. Feb 4, 2020 at 1:03 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
  7. Feb 4, 2020 at 1:23 PM
    findingthingsout
    midwest
  8. Feb 4, 2020 at 4:52 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    The “TRD” cap is 1.3, I believe and the cap that comes on the nice aluminum radiator we all have is 1.4
  9. Feb 5, 2020 at 6:27 PM
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    So I have found out that if I can keep my foot out of the throttle and only drive 65mph, I can get 15mpg! Had to got to SLC monday during a snow storm so we took the truck to be protected from other drivers. Yep 15mpg. If I would have ran the tank to the E I could have gotten 240 miles on a tank. LOL And I made a crude cardboard cover for my large trans cooler and the trans got up to a whopping 122 degrees! 15 higher than without the cover. But I really just need to install the CSF and the trans thermostat so it can actually warm up. I have read that not letting a trans warm up can be as bad as getting too hot. Anyone know anything about trans temps and if it is bad to run them that cold? The thermostat is set to allow flow to the cooler at 180. Which indicates to me you want at least 180?
  10. Feb 5, 2020 at 6:54 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    im under the impression that175* is good. id be a little concerened at 120ish.
    mr.trd[QUOTED] likes this.
  11. Feb 5, 2020 at 7:44 PM
    Kelvin
    Kelvin Wheeeeee
    Draft a big rig to really see what you can get :D
  12. Feb 6, 2020 at 10:22 AM
    Lucifer29
    Lucifer29 Well-Known Member
    Red
  13. Feb 6, 2020 at 10:27 AM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    single core OEM radiator still?
  14. Feb 6, 2020 at 10:54 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Sounds like a blown HG. Time for a cylinder leakage test.
    Athlaos and mightytacoman like this.
  15. Feb 6, 2020 at 11:10 AM
    Lucifer29
    Red
    oem
    original
  16. Feb 6, 2020 at 11:23 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    the leak down will give you a good idea on rings, valve seats, seals and head gasket if nothing else.
    how long has it presented itself?
    Have you checked it on an open system, without any t-stat?
    BassAckwards and 12TRDTacoma[OP] like this.
  17. Feb 6, 2020 at 11:23 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Spark plugs, valve cover gaskets, belts. (IF the engine is not done)
  18. Feb 6, 2020 at 11:29 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    Are you sure you are full on coolant? Fresh coolant? Radiator pressure test to check it as well.
  19. Feb 6, 2020 at 11:32 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    sorry to hear that, just let us know what you know when you know and we can try to help.
  20. Feb 6, 2020 at 11:48 AM
    Lucifer29
    Red
