TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Feb 11, 2020 at 12:14 PM
    NLMOOmar
    NLMOOmar Well-Known Member
    13 DCSB TRD OFFROAD SC
    Shrockwork Sliders, ICON (C/0, Tube UCA and 2.0 Rear), Dakars, US OFFROAD winch mount bumper. 2014 Nav Radio, SOS rear bumper and shackle flip, Pelfreybilt Skids. BAMF Bar mount and CMC, SCS-F5, Magnuson SC
    PTR29-35061 - TRD Lower Engine Radiator Hose
    zippsub9, JustDSM and mightytacoman like this.
  2. Feb 11, 2020 at 5:15 PM
    Boozng
    Boozng I don't know what I'm doing here.
    Dave
    626, 661, 323, 310, 760
    MGM DCSB TRD Sport 4x4 Supercharged
    FOX 2.5/2.0, Camburg UCAs, 33" BFGs, Pelfreybilt Armor
    That's the hose I used as replacement. It was still rubbing for some reason no matter how I manipulated it. It either rubbed on the cooling fan, or it rubs up against the pulley bracket. I called Superchargers Online, who is the supplier for Magnuson, and ordered one from them. Apparently, their hose is a little different. I'll take photos of the difference once I get it in.
  3. Feb 11, 2020 at 5:49 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I wonder if you have a bent radiator support. It would cause the issue that you are talking about, since clearances once boosted become much less over OE.
  4. Feb 11, 2020 at 5:51 PM
    Boozng
    Dave
    Doubt it. Its never been in an accident, nor have I ever rammed into anything with it.
  5. Feb 11, 2020 at 7:23 PM
    Boozng
    Dave
    I wonder if my motor mounts could be worn. If my engine rocks back and forth, it could possibly contact fan. But the fan is connected to the engine. If the engine rocks back and forth, so would the fan.
    12TRDTacoma[OP] likes this.
  6. Feb 11, 2020 at 7:32 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I believe there was some kind of spacer thingy to be installed when you installed the supercharger, that was installed right?
    My fan was rubbing my LRH also, but A little bit of twist action was able to get it just enough away from the fan that it doesn't hit anymore.
  7. Feb 11, 2020 at 7:37 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    If your engine rocks back and forth I would suspect the transmission mount long before the actual engine mounts.
    The spacers were down by the T stat housing if I remember right, but those pushed all of that jazz outward more than inward and it sounds like his issue is more so that the hose is too forward which is causing the fan to strike the lower hose.
    Murphinator[QUOTED] likes this.
  8. Feb 11, 2020 at 7:57 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Even after making the appropriate cuts on the Magnuson supplied hose, I only have roughly 1/4” clearance from the fan.
  9. Feb 11, 2020 at 8:09 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Same actually. Mine is about 1/4" clearance from the fan.
  10. Feb 11, 2020 at 8:23 PM
    Boozng
    Dave
    Is your lower radiator hose contacting the pulley assembly also?
  11. Feb 11, 2020 at 8:24 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    yikes. never knew that.
  12. Feb 11, 2020 at 8:29 PM
    Boozng
    Dave
    I thought i had that much clearance initially, but once the coolant started to flow, i started hearing scraping noises from the fan.
    I definitely installed the spacer that pushed everything out a little.
  13. Feb 12, 2020 at 6:21 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    time for electric fans.
  14. Feb 12, 2020 at 7:27 AM
    Boozng
    Dave
    Lol! That would be the next option. :)
  15. Feb 12, 2020 at 8:18 AM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    I only have 3 inches or so of clearance after going to electric. Before I had the 1/4" everyone else had. I do love my electric now. Been running it a month now and dont know if i would every go back.
  16. Feb 12, 2020 at 12:56 PM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
  17. Feb 12, 2020 at 1:11 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    I’m using the Australian one forgot the name HKB or similar and it’s bee good
  18. Feb 12, 2020 at 1:26 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I ran a voltage booster on mine for a month or so until the battery light came on bc of it. Took out the voltage booster, reinstalled the 7.5amp Alt-s fuse and its been good ever since. Kinda has me curious what happened though
    Athlaos likes this.
  19. Feb 12, 2020 at 2:19 PM
    Waited many moons
    Waited many moons Well-Known Member
    Pat
    Honolulu, Hawaii
    2014 Alaska Edition
    What model number NGK Iridium spark plugs are you guys using? I want to possibly order online, for my 2nd Gen Tacoma with SC.
  20. Feb 12, 2020 at 2:27 PM
    henryp
    henryp A member of TW
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    OP has the best list. Unless you’re heavily moded, most people run the supercharger stock ones and not the colder ones available.
