TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Feb 27, 2020 at 7:16 PM
    Boozng
    Boozng I don't know what I'm doing here.
    Dave
    626, 661, 323, 310, 760
    MGM DCSB TRD Sport 4x4 Supercharged
    FOX 2.5/2.0, Camburg UCAs, 33" BFGs, Pelfreybilt Armor
    ***Radiator Hose UPDATE***
    Thanks to @mr.trd , I have received the lower radiator hose that came with our fit kit. Notice the difference between the OEM (trimmed/TOP) to the Magnuson provided one (untrimmed/BOTTOM). Big difference. The current OEM hose I have installed is trimmed, but still touches the tensioner/pulley bracket, and the radiator fan has cut a chunk off the side of the hose. Luckily, no leaks....yet.
    Also, I have contacted Gerald (thanks @Murphinator ), from HPS, to replicate this hose for our application. The trimmed Magnuson hose will be dropped off on Friday. I suggested a combo (upper/lower) group buy when it is made. He didn't say no. LOL! Hopefully it gets made quickly. =)
    zerotimeouts, Torspd, SUMOTNK and 6 others like this.
  2. Feb 27, 2020 at 7:54 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    nothing in the land of hipo is (specific).
    snow does carry many options that can fill our s/c needs. if you have questions you cant find answers to pm me. ill share all i know
  3. Feb 27, 2020 at 7:56 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    could you share some pics with hps? maybe they may make a new even better design!
    Boozng[QUOTED] likes this.
  4. Feb 27, 2020 at 7:57 PM
    Boozng
    Dave
    That's a great idea! I'll forward those pics to Gerald.
  5. Feb 27, 2020 at 7:58 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    you are asking very good questions sir.
  6. Feb 27, 2020 at 8:01 PM
    Boozng
    Dave
    I'm just trying to contribute a little. The wealth of knowledge here boggles my mind and I'm still not done reading the entire thread!
    Roostfactor and Murphinator like this.
  7. Feb 27, 2020 at 8:02 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    even if it was two generic hoses clamed together for a shape to be made. a clear idea of model helps. yes, ill buy one.
  8. Feb 27, 2020 at 8:04 PM
    Boozng
    Dave
    You know what? I can stop by autozone or o'reillys tomorrow, and see if they have similar hoses. For the people who don't want to spend the dough on HPS ones.
  9. Feb 27, 2020 at 8:06 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    you arent alone. ive studied this thread for 2 years. fantastic use of time. ive made friends all over the us. we just all need to try nitrous now. all the cool kids sniff it.
  10. Feb 28, 2020 at 11:48 AM
    PeteSmashh
    PeteSmashh Well-Known Member
    Anyone get the cam gear mod done at a shop? curious how much it would run. I'm in VA.
  11. Feb 28, 2020 at 11:58 AM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    I presume you've looked over my how to/for sale thread and decided it was over your head?
    nudavinci64 likes this.
  12. Feb 28, 2020 at 12:31 PM
    PeteSmashh
    I did look it over and I think I can do it I just wasn't really sure how long it would take me (assuming everything goes right). I usually do simpler work on the truck. I'm all about eliminating hassles from my life if the price is right. How long SHOULD it take?
    Norton and 12TRDTacoma[OP] like this.
  13. Feb 28, 2020 at 12:35 PM
    mightytacoman
    Kel
    4.5L 1grfe
    Diy time seems to be 4-6 hours for most that have tackled it
  14. Feb 28, 2020 at 12:47 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Id go on the upper scale of that. Especially if you dont do internal work that often. There is a slight learning curve on Toyotas.
  15. Feb 28, 2020 at 1:09 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    It's actually pretty easy to do. First time inside my engine and it all went smoothly. I took the SC off and opened it up one evening and did the install the next morning. Didn't take too long.
  16. Feb 28, 2020 at 6:14 PM
    Georgeth1022
    Georgeth1022 Well-Known Member
    Shaun
    West Hills CA
    2013 BAJA w/ too many mods
    Too many to list
    So I need to replace my supercharger belt as it is cracking, and I don’t want to to fail on me in the middle of no where. I have a belt that I purchased a couple of years ago that I keep in my truck for the oh shit situation. Toyota part number PTR30-35110-AA. I’m going to put this on so I’ll be good. But I’m trying to buy another one to keep in my truck, and the part number is discontinued. What belt is everyone using now that the Toyota belt for our SC is no longer available?
  17. Feb 28, 2020 at 6:21 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Page 1 provides quite a few options. I think I have a Gatorback belt, but constantly changing to keep up with smaller pulleys.
    Belt sizes and options:
    - 70.5" length OE 3.0 pulley 5PK1790
    5050705
    Available in Dayco, Bando, Goodyear Gatorback, or Continental
    - 69.5 for smaller pullies (2.5") 5PK1765 5050695
    Available in Dayco brand, Bando, Goodyear Gatorback, or Continental
    For sizes 2.8-2.7" pullies a 70" belt is what I recommend, though I have no good source for a belt of that length in 5 rib. Any belt which is 5 ribs or more will fit, however, anything further than 5 rib will require cutting ofthe belt with razor blade. Place the number of ribs [X]PK1778 in the brand you desire in the search bar and you may be able to find it.
    UPDATED:
    I have further researched belt part numbers for those wanting to run Gates FleetRunner green belts for increased longevity and increased pulley traction and have a small compiled list of near lengths close to what is required to run certain size pulley's on our superchargers. Below is a list of what size will be most compatible based on the size pulley you are running. All will require modification to fit our 5 rib pulleys.
    - For engine (NOT the blower!) serpentine belt setup: K070835HD is a direct OE replacement fit
    - For OE 3.0 pulleys (70.5"): K070705HD will require slicing off 2 ribs
    - For 2.8-2.7 pulleys (70.2"): K080702HD will require slicing off 3 ribs ORK120702HD will require slicing 7 ribs (you get 2 belts for the price of one!)
    - For 2.5-2.6 pulleys (69.56"): K060696HD will require slicing off 1 rib
    Gates RPM series:
    These belts are claimed superior to all other belt options for Superchargers. Running it will require the lowest configuration of 2.7, ideally OE sized 3.0 pulleys as the belts are designed to retain their length for the life of the belt with zero stretch factor premeditated on them due to their construction. Due to their inherent build nature which factors in zero stretch, sizing is critical otherwise snapping will occur. Be aware as well that those with the solid poly coupler installed in place of the OE spring loaded coupler will experience increased supercharger rotor noise at idle. This is NORMAL. Sizes are as as follows..
    For pulley configurations 3.0-2.8 (ideally kept at 3.0) (70.57"): K050705RPM
    If you do decide to play with these sizes with sizes below 3.0 be aware you may snap the belt. Belt sizing is THAT critical!
    Belt sizes for 2.5-2.7 currently do not exist in the RPM series at the time of this writing (69.5"-70"). HOWEVER, by running @Roostfactor belt wrap mod for pulley sizes 2.7-2.9 it should regain you the belt sizing you need to reclaim that lost half inch belt loss you would otherwise have if you did not run it, therefore please refer to the previous belt size for OE sized pulleys. It should put you back into the OE length sweet spot.
    For those running 2.5-2.6 pulleys I would strongly recommend running @BillDaCat8 belt wrap mod, as it reclaims lost spacing otherwise. If you are able to perform his belt wrap this would allow you to reclaim the belt length otherwise lost by stepping down sizes and it will allow you to run the OE length 70.5" size without further issues.
    For pulley configurations below 2.4 ideally 2.3-2.2 (69.01" length): K060690RPM will require slicing off 1 rib
    For pulley configurations below 2.2 ideally 2.1-2.0 (68.57" length): K060685RPM will require slicing off 1 rib
  18. Feb 28, 2020 at 6:37 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    youve come to the right thread sir. welcome.
    12TRDTacoma[OP] and zippsub9 like this.
  19. Feb 28, 2020 at 6:38 PM
    Georgeth1022
    Shaun
    West Hills CA
    Too many to list
    Thanks so much for the info, appreciate it!!
    zippsub9[QUOTED] likes this.
  20. Feb 28, 2020 at 6:42 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Id run the gates RPM belt if you're running the stock pulley. Very nice quality
