TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Mar 26, 2020 at 8:03 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    If someone is putting down money for installing forged internals then cometic head gaskets and NEW ARP head bolts is a definite for the 1gr-fe!! Cheap insurance. I think people do around .51 thickness.
    Getting a machined pulley to fit should be the easy part.
    Flake Boost[QUOTED] likes this.
  2. Mar 26, 2020 at 8:03 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    I have a 2014... so that's looking good
  3. Mar 26, 2020 at 8:07 PM
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
  4. Mar 26, 2020 at 8:21 PM
    Flake Boost
    Flake Boost FORCED
    I've been eying it for awhile. $7k is lots with the current climate and people not working. I saw 'this' creeping up on us and started budgeting more. If these contracts finalize in the next few days. I might have the room to strike a deal.
  5. Mar 26, 2020 at 8:37 PM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    most head bolts are stretch bolts. let alone use re-used stock head bolts on a performance build. (or as @Flake Boost has hinted at)
    Flake Boost likes this.
  6. Mar 26, 2020 at 9:02 PM
    Flake Boost
    Flake Boost FORCED
    I'm going to grab the ARP & Cometic. Thats a given.
    Getting the proper sized pulley was the wild card.
    @Torspd uses ARP head studs on all his engines. Didn't know if the process was replace or reuse on them. I'm told its reuse on them/
  7. Mar 26, 2020 at 9:19 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Performance build is sort of a different story, but for regular vehicles I leave them.
    I have re-used all my "stretch bolt" shit over and over as nauseum for my entire life as a mechanic and have not once ever ran into issues on any vehicle, ever because of a bolt torque spec issue, or because they somehow loosened up.
    Exhaust manifold bolts, hell yeah, replace them, especially when they are hard to get to. Everything else stays.
    Like I said, I am an unpopular opinion here on some things. Hahaha.
  8. Mar 26, 2020 at 9:27 PM
    TRON
    Well the peak torque numbers are both around 400. But I’ll take the TRD torque curve. Rotrex C39-91/92 and 80mm with Ucon vs a TRD blower 2.3 pulley and all mods on hptune?! :stirthepot:
  9. Mar 26, 2020 at 9:42 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I'll take the TRD roots blower over a turbo "centrifugal supercharger" all day long. I like my power down low and so does this truck. I'll leave that up high stuff to the race cars, rice rockets and Honda S2000s. :D
    I see someone is THOROUGHLY enjoying his new 2.3 pulley. ;)
  10. Mar 26, 2020 at 10:50 PM
    Flake Boost
    Flake Boost FORCED
    debating on 1000cc or 1200cc injectors and ditching the 7th injector and the UCON and going with an HP tune. Time will tell. I see the pros and conns to both.
  11. Mar 27, 2020 at 4:37 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I have ARP 2000 series head studs. They are of a much higher tensile strength than the OEM head bolts. They do not stretch like those do. I do not reuse OEM head bolts.
  12. Mar 27, 2020 at 8:43 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    whats a safe way to get a s/c belt off by yourself? ive always had someone to help loop it off the top pulley. i want to pull my s/c today as long as i cant work.
  13. Mar 27, 2020 at 8:48 AM
    420taco
    420taco Well-Known Member
    Justin
    PA
    I just pop the fan/shroud off and get on the tensioner with a breaker bar from the top
  14. Mar 27, 2020 at 8:49 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    ok. ive always done it from down below.
    Norton likes this.
  15. Mar 27, 2020 at 8:58 AM
    BillDaCat8
    Jake
    PHX
    I do it from below. One of my breaker bars is just the right length so that I can pull back the tensioner with it and then wedge the handle of the breaker bar onto the the top of the crossmember. That holds it while I do the belt change.
  16. Mar 27, 2020 at 9:06 AM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    #metoo
    Norton and 12TRDTacoma[OP] like this.
  17. Mar 27, 2020 at 9:45 AM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    I remove from bottom and pull the belt off the crank pulley if I’m alone
  18. Mar 27, 2020 at 10:05 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    #metoo
  19. Mar 27, 2020 at 10:12 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    thanks guys! out of laziness does anyone know the torque specs on the internal bolts? i think the intercooler bolts are 11lbs. im going to go 2.3 today.
    Athlaos and SUMOTNK like this.
  20. Mar 27, 2020 at 10:17 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Damn, some of you guys like to work extra don't you? Lol.
    I would stay away from torque spec on the soft aluminum that is on the intercooler. Do you see how many dudes stripped their shit out? Probably following torque spec at that too. Tighten until it is tight and don't go further than that.
