TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Apr 2, 2020 at 10:10 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Flake Boost likes this.
  2. Apr 2, 2020 at 10:37 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Yup! I really want a 69.5 RPM since my overdrive pulley is lil larger but they don’t make one. Closest is a 8 rib 69.8 which would be pretty good. But like any belt they are always a little off on the tenths.
  3. Apr 3, 2020 at 1:58 AM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    I searched and can't seem to find these. Hope this is right place to post.
    1. S/C removal instructions? I need to do cam gears at some point but can't find minimal removal instructions with S/C.
    2. What gaskets/seals Will I need to replace if I pull and reinstall the S/C? I'm ok buying a new gasket or seal if there is a part #. Maybe it is the same as the valve cover gasket - L&R valve cover gasket 11213-AD010 & 11214-AD010
    3. Was gonna polish down the ridges in the lower IM while it's off. To replace gaskets on lower IM do I buy upper and lower IM seals? or does the S/c take the place of the upper IM and I only need one?
    12TRDTacoma[OP] and Flake Boost like this.
  4. Apr 3, 2020 at 7:34 AM
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    Good info on that tube. I’m already running that intake. So, the 4r tube will be a piece of cake to adapt. I’ll order one up today.
    As for your suspension interference, I suggest a heat gun inside and out on that lower housing. Work slow and soften that whole corner without distorting the upper areas.
    You also might consider slipping an appropriately sized piece of pvc pipe onto that tube temporarily. That way you’ll have some clearance after you re-mould that lower box.
  5. Apr 3, 2020 at 7:38 AM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    I have been running a FJ, K&N tube into the cowl with an inline 4" filter to the Tundra TB. I looked forever to piece together something like this, but was concerned about tubbing the inner fender and clearance. Good deal with the heat gun and softening the box up.
    12TRDTacoma[OP] likes this.
  6. Apr 3, 2020 at 7:42 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Excellent idea! I love it!
    PVC pipe? I'm not necessarily understanding the use for that part of the slight mod that's needed though.
  7. Apr 3, 2020 at 7:45 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    This is just a great solution for California people who want their cake with smog and want to eat it too by not having to switch from tune to tune with HPT when having to get the test done every two years. You can keep your current tune and not have to reflash over and over and it's one less hassle you have to deal with. I refused to be told that nothing but the OE intake will work. :thumbsup:
  8. Apr 3, 2020 at 11:57 AM
    BillDaCat8
    Jake
    PHX
    Cut up a piece of PVC pipe to lay over that tube while you're re-shaping that box. Just to fatten it up a bit. It'll buy you a bit of clearance so that things aren't rubbing when you're done.
  9. Apr 3, 2020 at 12:39 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Ah that could work. I suggested a slight trimming but the big issue is one of the clamps for the box sits there. Roberto @12TRDTacoma you think there’s enough to shape without messing up the clip?
  10. Apr 3, 2020 at 12:42 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Ahh. Noted. Great idea man. Thank you! I am going to hit this thing again today and see what I can do with it.
    I trimmed off some of the gusseting that's there but ultimately I don't think that will be the issue. It'll be the box itself.
  11. Apr 3, 2020 at 1:21 PM
    nudavinci64
    Robert
    Makes sense. Forming with the pipe sounds promising.
  12. Apr 3, 2020 at 1:53 PM
    BillDaCat8
    Jake
    PHX
    OE MAF# 22204-0V010
    Connector:
  13. Apr 3, 2020 at 1:54 PM
    smelly621
    smelly621 Well-Known Member
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    Just did this for the first time myself.
    1. There are some good S/C install threads on here - find them and you can skim until you get to the parts about the blower itself, but at a high level:
    -Some will you don't need to, but working alone I found it easier to start by removing the fan and rad shroud
    -Remove air filter housing like normal
    -Remove throttle body, can leave coolant lines attached
    -Remove S/C belt from blower snout
    -Remove bunch of bolts from the intercooler portion of the blower assembly and coolant hose clamp so you can flop it out of the way, careful not to damage the nipple on the coolant tank
    -remove bolts that go down into the intake manifold on inside of blower housing
    -remove two bolts attached to brackets on driver side of blower and couple of vac/pcv hoses
    -Lift blower off
    2. I just replaced the valve cover gaskets and throttle body o-ring since I had them and was already in there
    3. Not sure this is worth it TBH
  14. Apr 3, 2020 at 1:55 PM
    Flake Boost
    Flake Boost FORCED
    @zerotimeouts did you get your answer? Here are the INSTALL instructions. Follow in reverse?
    1. see attached file
    2. not 100% on part numbers
    3. personally never reuse gaskets and seals.
    zerotimeouts and nudavinci64 like this.
  15. Apr 3, 2020 at 1:57 PM
    Flake Boost
    Flake Boost FORCED
    @BillDaCat8 What program are you using? You've come to the rescue a few times.
    Toyota & Lexus EWD? I only have Europe if anyone wants that one.
  16. Apr 3, 2020 at 3:02 PM
    BillDaCat8
    Jake
    PHX
    :spy:
  17. Apr 3, 2020 at 3:44 PM
    nudavinci64
    Robert
    Boost winch heads? I assume most of you had to cut the brace sticking out off since we need to relocate it?
  18. Apr 3, 2020 at 4:15 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    Yeah. I basically don’t have much of that brace left
  19. Apr 3, 2020 at 4:33 PM
    nudavinci64
    Robert
    figured. I hacked the stock one off wanted to make sure that applies here too before I get cutting.
  20. Apr 3, 2020 at 4:41 PM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
