TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Apr 4, 2018 at 5:39 AM
    #2601
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I bought boost juice. Dont. Blue washer fluid with 2- 12oz bottles of heet gas dryer is the same. DONT USE ANY OTHER COLOR WASHER FLUID. This makes 50/50 like boost juice. Straight blue is 30/70, totally fine as well. Just slightly less octane.
    GT7 likes this.
  2. Apr 4, 2018 at 6:34 AM
    #2602
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    I'm not the only one @Torspd
  3. Apr 4, 2018 at 6:42 AM
    #2603
    Roostfactor
    TX panhandle
    Mainly throttle response also more wot powah. For you NOOB if you rock crawl and or do slow/technical stuff it might not be what you want. On/off throttle is more sensitive to input. A 70mm may be perfect for your needs.
    I got mine cheap and may have other plans to enlarge the rest of the intake so I can take full advantage of the larger tb.
  4. Apr 4, 2018 at 6:43 AM
    #2604
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Ah, that makes sense. Well, if you sell your 70, let me know :thumbsup:
  5. Apr 4, 2018 at 6:46 AM
    #2605
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    "May" have other plans...
    I like where this is going :)
  6. Apr 4, 2018 at 6:48 AM
    #2606
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Shhh. They'll hear you.....
  7. Apr 4, 2018 at 6:55 AM
    #2607
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Im going to a metal warehouse today. I want to look at big pipe:rofl:
    GT7 likes this.
  8. Apr 4, 2018 at 7:36 AM
    #2608
    Roostfactor
    TX panhandle
    I only have stock and 76mm.
  9. Apr 4, 2018 at 7:37 AM
    #2609
    Roostfactor
    TX panhandle
    I've been in a mental warehouse forever!
  10. Apr 4, 2018 at 7:38 AM
    #2610
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Well, THAT’s inconvenient.
  11. Apr 4, 2018 at 8:49 AM
    #2611
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Question- whats the point of a fuel pressure gauge? You either have stock (insufficient) or aftermarket (plenty). It seems like a needless expense. Thanks
    loginfailed likes this.
  12. Apr 4, 2018 at 8:57 AM
    #2612
    Roostfactor
    TX panhandle
    I think you are talking stock or aftermarket fuel pump. Both will supply the same pressure because it's the fpr that determines fp, not the pump. BUT, if the fuel demand (injectors) exceed the output of the stock pump then fp will drop. When that happens less fuel is injected and you run lean.
    Even with a higher capacity pump over time the filter can start getting clogged restricting flow. Fuel pressure gauge is just insurance to make sure you can see what's going on with fp and you can catch it if it starts to drop under high fuel demand situations.
    Biscuits and HolyHandGrenade like this.
  13. Apr 4, 2018 at 9:07 AM
    #2613
    Roostfactor
    TX panhandle
    Every gauge is useful in some way. Look at this engine instrument cluster from a C-130. Each engine has it's own set of gauges. 4 engines wither each engines gauge set displayed vertically.
    I know its comparing apples to oranges but the point is you can never have too many data points to troubleshoot potential problems.
  14. Apr 4, 2018 at 9:08 AM
    #2614
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Yes, i meant pump. I see, a check on the fuel filter and injectors. I thought having an afr gauge would do the same info. Fuel gauge is more specific. Thanks
  15. Apr 4, 2018 at 9:10 AM
    #2615
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Point well made on gauges sir. If only my cockpit had that kinda room.
    Roostfactor likes this.
  16. Apr 4, 2018 at 9:15 AM
    #2616
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    This is why military avionics guys/gals hate life
  17. Apr 4, 2018 at 12:35 PM
    #2617
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    I got fuel pressure gauge because I did the fpr mod and it’s running boost reference now. And I wanna keep track of it at wot.
  18. Apr 4, 2018 at 12:40 PM
    #2618
    Roostfactor
    TX panhandle
    That makes sense.
    Also if someone got an adjustable fpr it would come in real handy.
  19. Apr 4, 2018 at 1:08 PM
    #2619
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I literally do not know of anyone else with an adjustable fpr, besides myself.
  20. Apr 4, 2018 at 1:16 PM
    #2620
    Roostfactor
    TX panhandle
    Maybe not here, but what about in XRU?
