TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Apr 25, 2020 at 2:49 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    ahh ok, at least I'm not the only one.. lol
    I've got the fan off, my gun wont fit, but my air ratchet will. I have my breaker bar on the crank bolt and wedged on the frame, I'm putting more tension on the belt via the tensioner with a ratchet, and trying to break the alt pulley free with my air ratchet. its also been sprayed with PB.
    lets see how she goes! lol
  2. Apr 25, 2020 at 2:50 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    and the amount of dirt that has fallen in my face from behind all the pulleys, the fan shroud, etc.. is ridiculous. what asshole let this thing get so dirty... :rolleyes:
    glad ive got my safety glasses.
  3. Apr 25, 2020 at 3:00 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    blinker fluid??
  4. Apr 25, 2020 at 3:01 PM
    Flake Boost
    Flake Boost FORCED
    Thanks for reminding me. I need to order some windshield washer fluid/ Time to switch over to the warm weather bug stufff
    12TRDTacoma[OP] likes this.
  5. Apr 25, 2020 at 3:03 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    depending on the state's ability id always opt for the colder stuff. probably has more alcohol for faster evaporation time. i just use methanol:D
  6. Apr 25, 2020 at 3:07 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    well no go. Its seized on there pretty good I guess. Tried about every combination I could think of minus grabbing it with vice grips like @TodayWasTHeDaY . It feels like the bolt wants to twist more than anything.
  7. Apr 25, 2020 at 3:20 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Me likey mucho!
  8. Apr 25, 2020 at 3:21 PM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    One thing I did notice after struggling for a while is there is a spot for a wrench on the alternator shaft that I tried loosening for a few minutes before realizing there was the larger nut that I couldn't see very well that actually holds the pulley on:facepalm:
  9. Apr 25, 2020 at 3:23 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I did that too at first.. then had to clean away all the dirt with the PB to feel the 22mm on there..
  10. Apr 25, 2020 at 3:26 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    eye drops for the vision.
  11. Apr 25, 2020 at 3:28 PM
    TodayWasTHeDaY
    Russ
    Calgary
    Maybe more PB let it sit and tap the bolt a bunch. You know how it goes...
  12. Apr 25, 2020 at 3:28 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    vise grips with duct tape or sandpaper for additional grippage?
    XPOTRPR[QUOTED] likes this.
  13. Apr 25, 2020 at 3:31 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    lol. worst case I'll grab it with vice grips. I'll let it soak for a while.. try it again. I'm not missing anything simple like its reverse thread am I? lol
    I'm holding everything as tight as I can.. and I can feel it twist more than anything. Gonna soak it more tho and let it sit for a bit..
  14. Apr 25, 2020 at 3:34 PM
    TodayWasTHeDaY
    Russ
    Calgary
    Mine was traditional threading although I thought it might be reverse for a while too.
    A small pipe wrench properly braced would also work on the pulley. I don't think I would have got the pulley off without wrecking it with the knipex pump pliers.
  15. Apr 25, 2020 at 3:35 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    The pipe wrench did cross my mind too. I'll probably just take the belt off and try that.. and hope that its the correct pulley. lol
  16. Apr 25, 2020 at 3:37 PM
    TodayWasTHeDaY
    Russ
    Calgary
    May the force (to crack that bolt loose) be with you.
  17. Apr 25, 2020 at 3:47 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    pump pliers.... sounds like a lady doctor tool.:rofl:
  18. Apr 25, 2020 at 3:54 PM
    TodayWasTHeDaY
    Russ
    Calgary
  19. Apr 25, 2020 at 3:57 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    These are the same ones I use at work for those really nasty fasteners or items which refuse to come out. They work amazing because of their sudden 45* design.
  20. Apr 25, 2020 at 4:07 PM
    Sirnick88
    Sirnick88 Well-Known Member
    Nick
    2011 TX Pro, 6spd MT, boosted
    URD mk3 s/c, Dobinsons snorkel, Ultragauge, Stoptech rotors, TRD ceramic brake pads, softopper, anytime backup camera, anzo black headlights, oh, and vehicle OCD organizers!!!
