TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Apr 28, 2020 at 6:45 PM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    like i said to zipsub9 check your critical shaft speed. you dont want to have to buy 2 driveshafts.
  2. Apr 28, 2020 at 7:10 PM
    rheath08
    Russell
    Bakersfield, CA
    https://spicerparts.com/calculators/driveshaft-safe-operating-rpm-calculator
    for everyone thinking about driveshafts.
    if i recall correctly, you want the shaft rpms to be at or less than half critical speed.
    shaft rpm= trans ratio / max safe engine speed.
    e.g. 5500 / (auto 5th gear) .716 = 7681.xxx
    so a one piece can hit half critical speed quite quickly.
    the two piece has two short driveshafts raising the limit higher.
    this may not be the best, but it should get you going in the right direction for what you need.
  3. Apr 28, 2020 at 7:38 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    i was under the impression a 1 pc is ok with a sbdc.
    Flake Boost likes this.
  4. Apr 28, 2020 at 7:54 PM
    rheath08
    Russell
    Bakersfield, CA
    tire size and axle gearing all play into it. it will change your driveshaft speed.
  5. Apr 28, 2020 at 8:02 PM
    Flake Boost
    Flake Boost FORCED
    Do I smell a ROOST Y-Pipe sticker in the works?1?!
  6. Apr 28, 2020 at 8:14 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Hmmmmmm I do love hitting critical speed with my shaft.
  7. Apr 28, 2020 at 8:40 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Just be careful to avoid burns.
  8. Apr 28, 2020 at 8:59 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    If the tech looked up the eo number they would know it’s false. I dont think they will put the truck on a lift to look down there anyway so I am gonna risk that one lol
  9. Apr 28, 2020 at 9:06 PM
    Flake Boost
    Flake Boost FORCED
    @Roostfactor ? lol
    Roostfactor and henryp like this.
  10. Apr 28, 2020 at 9:26 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Needs a prop 65 warning for CA. Literally everything has that warning. Even the sticker that’s giving the warning has the warning.
  11. Apr 28, 2020 at 10:09 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    The lady I talked to was super helpful and said have the dealer call and they will walk them through it.
  12. Apr 28, 2020 at 10:31 PM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Their phone lines are currently off because of covid. I had my dealer guy email them but I am just gonna have the stickers made as I don't know if they are even gonna give him the sticker
  13. Apr 28, 2020 at 11:37 PM
    nudavinci64
    Robert
    I talked to a guy and said he’s going to check and get back to me. if you get some made let me know.
    Murphinator[QUOTED] likes this.
  14. Apr 28, 2020 at 11:40 PM
    nudavinci64
    Robert
    how bad would it be to drive on on a 2.5 pulley before upgrading the fuel pump and valve body? I have both even with SIP im limited on time. I do have a 2.8 I can put on in the meantime but figure ill see how bad it would be to have the 2.5 on minus the 2 mods for a period of time.
  15. Apr 29, 2020 at 4:21 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Fuel pump absolutely.
  16. Apr 29, 2020 at 4:22 AM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    the length of time is directly inverse to your right foot discipline. I don’t think a couple weeks or a month would hurt bad. But once you get a taste remind yourself not to burn out anything else.
  17. Apr 29, 2020 at 6:01 AM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Will do!
  18. Apr 29, 2020 at 7:49 AM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    :popcorn:
  19. Apr 29, 2020 at 9:35 AM
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    That sucker is gonna be spinning way too fast, even at low RPMs the demand is way higher than the stock fuel system was intended for.
  20. Apr 29, 2020 at 10:07 AM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    It all comes down to how seriously the tech doing the inspection take his job. I had my Rav4 sniffed hard this year. Dude said he will check numbers on CATs if they are aftermarket. And stickers are a must.
    12TRDTacoma[OP] likes this.
