TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Apr 29, 2020 at 7:14 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Roostfactor and BassAckwards like this.
  2. Apr 29, 2020 at 7:16 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    What kinda gauge and if its on the right fuel setting
    BassAckwards[QUOTED] likes this.
  3. Apr 29, 2020 at 7:18 PM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    :rofl:20-30 hp! thats a good one.
    accel makes upgraded coils for the 1gr-fe
  4. Apr 29, 2020 at 7:20 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    AEM 30-4110. Im not sure how to change the fuel on it. It was a new gauge I bought online. The other two I bought previously I didn't have to change anything, just plugged em in and they read correctly.
    What's weird was when I first started the truck, it would idle right at 14.7 and behave normally as you would expect when hitting the gas/decelerating/etc, but then after driving it for a couple minutes it just went straight to 17:1 and stopped moving..
  5. Apr 29, 2020 at 7:23 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    maybe voltage. i even have one on my s/c hose.
  6. Apr 29, 2020 at 7:30 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Try a free air calibration. If it works, great. If it doesn't then you got a rare faulty unit.
  7. Apr 29, 2020 at 7:31 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Ok on that it Should be for gas, no eth or meth/alcohol. If needed I have a spare gauge thats the same one you can use. Truck drives fine?
  8. Apr 29, 2020 at 7:34 PM
    BassAckwards
    How do you do this?? I've never heard of such a thing..
    Truck is driving normally, pulls hard to redline, and no signs of knock or any strange noises. Just the gauge being funky. Thanks for the offer man! I actually already took one of the same afr gauges I had in my other truck to try to isolate the problem. That fixed it so all things are pointing to the gauge in my eyes..
  9. Apr 29, 2020 at 7:38 PM
    jpark4
    jpark4 Active Member
    2012 Tacoma 4x4
    Me? Nothing. The previous, a lot.
  10. Apr 29, 2020 at 7:50 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    correct, this is an external filter, just splice it into the rubber line outside of the tank. Make sure you splice the correct line though, no sense in filtering the return line.
  11. Apr 29, 2020 at 7:54 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
  12. Apr 29, 2020 at 8:48 PM
    Flake Boost
    Flake Boost FORCED
    What compression testing kit do you fine folks recommend.
  13. Apr 29, 2020 at 8:50 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    There is a mode built into the gauge but in order to free air calibrate you have to remove the sensor and let it hang in the air while doing it.
    It should be in the provided instructions AEM sent you. I got really good at it when I was using my trash Innovate MTX AFR gauge.
  14. Apr 29, 2020 at 8:54 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    I have Snap-On but I also used to be a mechanic and had an account with them. It’s nice/ terrible when the truck shows up every week at the same time.
  15. Apr 29, 2020 at 8:56 PM
    Flake Boost
    Flake Boost FORCED
    Link to the specific kit? Orr the specific accessories I need for our 4.0L engines? I was debating on gutting a spark plug. Then adding my own fittings and gauges.
  16. Apr 29, 2020 at 8:56 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I got a kit made by MAC which has been bulletproof for years now.
  17. Apr 29, 2020 at 8:58 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    I got it probably 12yrs ago lol. Compression and leakdown tester kits with hoses for the most common spark plugs. No clue what a link to it is
  18. Apr 29, 2020 at 9:00 PM
    BassAckwards
    I bought an otc one off of Amazon a while back. Works pretty good
    Flake Boost[QUOTED] likes this.
  19. Apr 29, 2020 at 9:02 PM
    Flake Boost
    Flake Boost FORCED
    Links to any of them?? @BassAckwards - I keep seeing tons of different versions
    BassAckwards likes this.
  20. Apr 29, 2020 at 9:03 PM
    BassAckwards
    I read through the instructions but looks like there is no free air calibration..
