TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Apr 6, 2018 at 6:30 PM
    #2701
    ThomasMore66
    Dallas/Fort Worth & Durango
    Well GD it! Why did you show it to us? Thou shalt not covet your neighbors traction bar...
  2. Apr 6, 2018 at 6:31 PM
    #2702
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    11th commandment?
    Biscuits and Roostfactor like this.
  3. Apr 6, 2018 at 6:35 PM
    #2703
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Ok now I want a traction bar.
  4. Apr 6, 2018 at 6:36 PM
    #2704
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Right? Come on one more run for us guys in here :D
  5. Apr 6, 2018 at 6:39 PM
    #2705
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    He only made two. His and mine. Sorry guys.
    If it helps at all, it really is great.
    :D
  6. Apr 6, 2018 at 6:44 PM
    #2706
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    They work ok...
    Mine is better after I switched to heims in the rear. V 3.0
    Biscuits, Roostfactor and loginfailed like this.
  7. Apr 6, 2018 at 6:49 PM
    #2707
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I’ll leave mine with you after the Rausch Trip end if Aptil.
    Actually, I guess I could do it myself. Only need you for the aluminum now ;)
    stairgod[QUOTED] likes this.
  8. Apr 6, 2018 at 7:01 PM
    #2708
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Is the budbuilt one worth a damn?
  9. Apr 6, 2018 at 7:34 PM
    #2709
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Maybe. I never really looked at it. I wanted mine for driveshaft protection as well as to control axle wrap. Plus I ended up incorporating a driveshaft loop into it so that a snapped ujoint doesn't end with me needing a new gas tank. And I preferred welding the mounts to the axle instead of relying on the studs from the third member.
    Plus I like making shit.
  10. Apr 6, 2018 at 8:16 PM
    #2710
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    Budbuilt does make a weld on one also. But not sure if it protects the drive shaft any
  11. Apr 6, 2018 at 8:18 PM
    #2711
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I noticed that. The one @stairgod made looks a lot beefier though. I wonder how hard it would be to make my own.
    jojotoo likes this.
  12. Apr 6, 2018 at 8:53 PM
    #2712
    wrmathis
    Bonaire, GA
    parts and stuff
    loginfailed[QUOTED] likes this.
  13. Apr 6, 2018 at 9:09 PM
    #2713
    ThomasMore66
    loginfailed likes this.
  14. Apr 6, 2018 at 10:12 PM
    #2714
    ThomasMore66
    I found this video fascinating and I thought some of you might too. It’s a bit long, but I view Tom Nelson as an engine building guru.
    https://youtu.be/HJN1BXXbZgw
    Roostfactor and HolyHandGrenade like this.
  15. Apr 7, 2018 at 3:50 AM
    #2715
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I think I’m going to fab up my own.
    jojotoo and HolyHandGrenade like this.
  16. Apr 7, 2018 at 5:27 AM
    #2716
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Just got this from Rob about the 70mm TB:
    “Tim,
    There's one in Georgia with only 13K on in off a 2016 4Runner. That one is $xxx plus shipping. Let me know if that interests you.
    Thanks,
    Rob”
    That will fit the URD adapter, correct?
    jojotoo likes this.
  17. Apr 7, 2018 at 5:29 AM
    #2717
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    It is beefy. The bottom tube is 1/4”
  18. Apr 7, 2018 at 5:34 AM
    #2718
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Yes it will. URD makes 2 adapters. One for 70mm and one for 76mm. Make sure you order the correct one.
    jojotoo likes this.
  19. Apr 7, 2018 at 7:26 AM
    #2719
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Thank you John. I’ll get it ordered then.
    Roostfactor[QUOTED] likes this.
  20. Apr 7, 2018 at 7:39 AM
    #2720
    ls1 prerunner
    ls1 prerunner Internet Scientist
    Andy
    El Paso, TX
    19 Golf .:R & 11 4x4 TRD LT S/C
    TRD S/C, Camburg LT, DMZ SUA, SAW Shocks in all four corners, Glassworks hood, fenders and Bedsides, 35" Toyo MT, KMC Enduros
    If that's the case I might want to try that. Anyone have an old gear they wanna send me so I can measure it and draw it up? What are the bigger benefits of running it without the UCON? TRD flash here.
    Biscuits likes this.
