TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. May 9, 2020 at 10:52 AM
    henryp
    henryp A member of TW
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Mine does that also. Is it just a little more or dead stop?
  2. May 9, 2020 at 10:53 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    I’d say it’s there once every other or every time prob every 2. I noticed it earlier after I bolted most things up it was smooth with engine open and plugs out. Can’t think of anything.
  3. May 9, 2020 at 10:54 AM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    sounds like you are fighting compression or the valvetrain spring tension.
  4. May 9, 2020 at 10:54 AM
    nudavinci64
    Robert
    Not dead stop I can turn it past just gives me a soft push back that I have to push through.
    henryp[QUOTED] likes this.
  5. May 9, 2020 at 10:55 AM
    nudavinci64
    Robert
    That’s what I assumed but checking the I’s and crossing the T’s before I fill her back up with coolant.
    rheath08[QUOTED] likes this.
  6. May 9, 2020 at 11:31 AM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Cam lobes peaking and then once you overcome valve spring tension it releases a little easier just turn only clockwise
  7. May 9, 2020 at 3:53 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    What everyone else said. You are fighting compression. Turn it and ensure everything moves smooth as needed and if it all looks lined up and clean crank it and go!
  8. May 9, 2020 at 4:04 PM
    nudavinci64
    Robert
    Yah that’s what I figured. Getting it filled up with coolant now and fire it up soon and check pulley alignment and all. It’s just about there.
    BassAckwards and TodayWasTHeDaY like this.
  9. May 9, 2020 at 4:07 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    With as much of an adventure as this has been for you, you might as well (or have someone with you) take a video of the engine as it fires up to life renewed to document such a triumph.
    rheath08 and 420taco like this.
  10. May 9, 2020 at 4:09 PM
    nudavinci64
    Robert
    Oh that will happen good or bad.
    this things take a ton of coolant now. S/C, CSF plus stock capacity.
    BassAckwards likes this.
  11. May 9, 2020 at 4:11 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah I know. It's nuts huh.
    Just make sure they take a few steps back in case any belts decide to go rogue during initial fire up. :D
    TodayWasTHeDaY likes this.
  12. May 9, 2020 at 4:34 PM
    nudavinci64
    Robert
    I wouldn’t put it past it.
  13. May 9, 2020 at 5:08 PM
    smelly621
    smelly621 Well-Known Member
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    If it spun easy with the plugs out you are in the clear on the cam gears. Probably just all the accessories turning plus S/C now. Maybe confirm the water pump pulley/fan are squarely bolted and it didn't get crooked if you had the fan clutch removed.
    I only say this as I removed mine while installing cam gears and missed getting it fully seated on re-install. It sounded awful on start up and I was sure I screwed up the timing somehow. Turned out it was the water pump pulley jumping around.
  14. May 9, 2020 at 5:16 PM
    EchoLake
    EchoLake Well-Known Member
    Sacramento
    '15 MGM TRD OR AC 6MT
    Magnuson Supercharger, Speedhut AFR and Boost Gauges, TRD ECU Reflash, Factory Nav Unit, TRD Skidplate, VIP alarm, 265/75R16 Cooper Discoverer ATP, 1" KSP Spacers, hub centric (hold comments lol), TRD Pro Grill, Raptor Lights on with ignition. Upcoming - purchased, not yet installed: Body matched rear bumper (rattle can), Kicker Hideaway, JL Audio 6x9 components w/80Hz Bass Blockers, Hellwig anti-roll bar, TRD Short Shifter, Knock-off TRD Shifter (non-Qball), black throwback plates. Plans: more.
    Newly installed Magnuson on 2nd gen 4.0 makes sort of a coarse rumble on light throttle, almost sounds like a V8.
    Did some searching and looks like these make a little rattle on idle coming from the rear of the unit, mine is no different from the videos I've seen on here, idle seems fine.
    Haven't heard anyone talking about a rumble on light throttle though, any thoughts?
    Dynoed before and after, STD and SAE correction are both about 23% max HP gain, 100 ft elevation, 80 degrees. 91 octane. 275/70R16s, 6spd. Installer did a Magnuson tune with Bully Dog unit.
    Is all this sounding about right or should I be concerned?
    Searched and didn't find exactly what I was looking for, and this thread is very active so that's why I asked here first.
    Any thoughts or suggestions appreciated.
  15. May 9, 2020 at 5:21 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    rattle is normal for me, the coupler typically accounts for the rattle. Welcome to the beginning of your spiral. I know you just dumped in the SC and tune but would recommend TRD over the bullydog setup. HPTuner and/or @JustDSM can get you setup.
  16. May 9, 2020 at 5:27 PM
    EchoLake
    Sacramento
    Ha ha, yeah.
    Cool, thanks for the advice, yeah from what I've read on here tune sounds important.
    I didn't think I would notice any noise or rumble on light throttle, that part normal?
  17. May 9, 2020 at 5:28 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    $50 to reflash your BD tune to TRD Spec. I would need the ECU shipped to me to perform the conversion however. Custom tuning via HPTuners will cost you $250.
    Not to turn this into any more of a sales pitch, but the TRD tune would be MUCH safer than the BD tune. I don't think you'll find anyone here to say otherwise.
    mr.trd, Norton, mightytacoman and 3 others like this.
  18. May 9, 2020 at 5:33 PM
    EchoLake
    Sacramento
    Looking into doing that at some point. Turnaround time?
    Any thoughts on the rumble at part throttle?
  19. May 9, 2020 at 5:35 PM
    JustDSM
    Justin
    Ogden, UT
    I perform ALL flashing the day I receive the ECU and ship them out the following morning to minimize downtime. I use USPS Priority Mail for 2-3 day turn around (Shipping is included in those prices too, btw). If you'd like to use a faster carrier service I'm happy to accommodate but I'd ask that you then cover the difference in shipping.
    No rush/pressure to do it now. I'm happy to do it anytime you're ready, just send me a PM and we'll work everything out.
  20. May 9, 2020 at 5:38 PM
    EchoLake
    Sacramento
    TBH that sounds pretty good. I'll do some searching and probably be getting back to you.
    Anyone have an opinion or experience any extra noise on part throttle before whine?
    I wasn't expecting that noise.
