TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. May 9, 2020 at 6:23 PM
    420taco
    420taco Well-Known Member
    Justin
    PA
    It could be any number of things left loose during the install or, most likely, it’s nothing. I’d double check the pulleys and whatnot.
    Also, I would get an AFR gauge installed to make sure your not running lean and to verify your current tune is safe.
    EchoLake likes this.
  2. May 9, 2020 at 7:06 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Too vague to say what it is. We need a video or something that pinpoints in on the rumble you speak of. Welcome to the fold!
  3. May 9, 2020 at 7:34 PM
    EchoLake
    EchoLake Well-Known Member
    Sacramento
    '15 MGM TRD OR AC 6MT
    Magnuson Supercharger, Speedhut AFR and Boost Gauges, TRD ECU Reflash, Factory Nav Unit, TRD Skidplate, VIP alarm, 265/75R16 Cooper Discoverer ATP, 1" KSP Spacers, hub centric (hold comments lol), TRD Pro Grill, Raptor Lights on with ignition. Upcoming - purchased, not yet installed: Body matched rear bumper (rattle can), Kicker Hideaway, JL Audio 6x9 components w/80Hz Bass Blockers, Hellwig anti-roll bar, TRD Short Shifter, Knock-off TRD Shifter (non-Qball), black throwback plates. Plans: more.
    Thanks!
    Alright, I'll see if I can get it on video, I'll post it tomorrow. It's already beer o'clock.
    It might not be super audible, hopefully that's a good thing.
  4. May 9, 2020 at 7:52 PM
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    Is there a recommended bolt with part# when setting up a rousch tensioner and the 50mm pulley? I don't see how you get rid of the slop with a normal bot. Or is the bolt and washer holding the bearing tight against the tensioner arm? What am I missing?
  5. May 9, 2020 at 8:11 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    There is a built in sleeve that is on the Roush tensioner and the double bearing roller comes with a supplied billet sleeve which is meant to absorb the rest of the slack which is there. That need to be cut to length however. As far as the bolt. I believe it's either going to be a 45 or 50mm M8x1.25 length bolt needed to fit in there.
    garciav and mr.trd like this.
  6. May 9, 2020 at 8:13 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Dude you live in Sac. I'll be there next weekend. If you want I could swing by at some point and just take a look or listen to your truck to see what the heck it is you are talking about.
    FishingInSand and Roostfactor like this.
  7. May 9, 2020 at 8:21 PM
    EchoLake
    Sacramento
    That would be awesome!
    I'll buy lunch or pay part of your gas or something.
    Just let me know when you're in town.
  8. May 9, 2020 at 8:59 PM
    findingthingsout
    midwest
    So you're saying the gap between the threads and the sleeve is OK? I get the need to trim the sleeve. But the bolt is narrower than the internal diameter of the sleeve. Was thinking there may be a specialty bolt. I guess I just need to rely on the pinching of the sleeve to the tensioner.
  9. May 9, 2020 at 9:05 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yes there will be some actual wiggle so to speak.
    If you are still unsure you can snap a picture to explain to me what you are saying but I am pretty sure we are on the same page here.
  10. May 9, 2020 at 9:18 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    I just fired mine up today and noticed that too but overall it sounds solid and drives great. sounds like your good. Def a lot of new sounds to get used to
  11. May 9, 2020 at 9:24 PM
    nudavinci64
    Robert
    It’s alive! A ton of stuff all at once.
    pulley alignment looks good. Pressed it in a bit more today.
  12. May 9, 2020 at 9:37 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Congrats! That’s a lot of work there!
    Roostfactor and 12TRDTacoma[OP] like this.
  13. May 9, 2020 at 9:45 PM
    nudavinci64
    Robert
    Indeed! the HP Tuner has come in handy. Will be doing some extra tuning for the FIC and a few others things.
    Worked out well! Thank you again for those.
  14. May 10, 2020 at 1:16 AM
    jpark4
    jpark4 Active Member
    2012 Tacoma 4x4
    Me? Nothing. The previous, a lot.
    Mine has a deep V8, look at my small wiener growl at first start up/crank but I haven’t noticed anything when accelerating. I’ll check in the AM though.
    also, I can vouch for justDSM’s service; I got my ECM returned on a Friday when I shipped it Monday.
  15. May 10, 2020 at 8:46 AM
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    Send off your ecu to @JustDSM and see if those changes help with your rumble.
    While your ecu is gone, try to con @12TRDTacoma into helping you do the fuel pump.
  16. May 10, 2020 at 8:59 AM
    420taco
    Justin
    PA
    Try some 93 or Boostane in the meantime
    EchoLake and Roostfactor like this.
  17. May 10, 2020 at 8:59 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Well that is one way of describing the way it runs now. :rofl:
    I live at least an hour away from him, maybe more. I hated doing my own fuel pump as it was. It would cost approximately one award winning, Nobel prize type blowie for me to help anyone do theirs because of the amount of suck it is to drop the tank (in my case, one man lift the bed then figure out how to hold it up safely) then make the annoying modifications needed to make it fit in there and work.
    If I could describe doing the fuel pump retrofit off a lift in one emoji on here, I would post a dumpster fire emoji for the sort of work involved to do it. :laugh:
    MightyMouseTom likes this.
  18. May 10, 2020 at 9:28 AM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    I know past people with Bully Dog tune were running very lean part throttle so do you think the sound is pinging?
    Very hard to tell if you dont have an afr gauge.
    I absolutely 100% recommend @JustDSM's service!
    He WILL get your truck running waaaay better than any other option out there!
    Most of us here use him including myself.
    Roost
  19. May 10, 2020 at 9:29 AM
    jpark4
    2012 Tacoma 4x4
    And I’m about to start my fuel pump right meow... maybe I’ll just return everything, including the SC; I’ve been putting off this fuel pump and filter replacement all week too.
  20. May 10, 2020 at 9:30 AM
    Roostfactor
    TX panhandle
