TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. May 10, 2020 at 9:32 AM
    jpark4
    jpark4 Active Member
    2012 Tacoma 4x4
    Me? Nothing. The previous, a lot.
    @12TRDTacoma is making the fuel pump install sound worse than the SC install. That and I’m being super lazy.
  2. May 10, 2020 at 9:33 AM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    It's not that bad. I've done 2 (mine and @BassAckwards). Start with tank as empty as possible.
    smelly621 likes this.
  3. May 10, 2020 at 9:39 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Yeah, seriously speaking it's not as bad as I'm making it sound @jpark4 I'm just a tired modder because all of the mods I have ever done have required me to start and finish on the same day, so there is already pressure on me the moment I remove the first nut off the truck and I don't like that sort of pressure which has caused me to reel back in my modding.
    If the tank is more on the empty side, removing it is cake.
  4. May 10, 2020 at 10:05 AM
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    One tip. Have a second fuel pump module modded and ready to install. That way you just drop the tank, swap modules, then re-install. That’s how I did mine. Sold off the one I pulled to someone else on here. I forget who it was now. But, there’s at least one extra floating around on here.
    Anyone got one decorating a shelf in their garage?
    Roostfactor and 12TRDTacoma[OP] like this.
  5. May 10, 2020 at 10:11 AM
    BillDaCat8
    Jake
    PHX
    Looks like it was @BassAckwards that got it. Maybe he’s still got it laying around.
    I don’t think you really need to be worried about dropping the tank. I was able to do it in about an hour with the aforementioned pre-modded module.
  6. May 10, 2020 at 10:21 AM
    420taco
    420taco Well-Known Member
    Justin
    PA
    I got a module on my shelf lol
    12TRDTacoma[OP] and zippsub9 like this.
  7. May 10, 2020 at 10:32 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That's actually a great way to go about it if you are going to do the mod that way it's drag and drop.
    We should probably add those into our "sell" thread.
    Roostfactor likes this.
  8. May 10, 2020 at 10:59 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I used the one i got from you to replace mine as it had a hole cut in the fuel bowl during a previous install:oops:
  9. May 10, 2020 at 12:07 PM
    EchoLake
    EchoLake Well-Known Member
    Sacramento
    '15 MGM TRD OR AC 6MT
    Magnuson Supercharger, Speedhut AFR and Boost Gauges, TRD ECU Reflash, Factory Nav Unit, TRD Skidplate, VIP alarm, 265/75R16 Cooper Discoverer ATP, 1" KSP Spacers, hub centric (hold comments lol), TRD Pro Grill, Raptor Lights on with ignition. Upcoming - purchased, not yet installed: Body matched rear bumper (rattle can), Kicker Hideaway, JL Audio 6x9 components w/80Hz Bass Blockers, Hellwig anti-roll bar, TRD Short Shifter, Knock-off TRD Shifter (non-Qball), black throwback plates. Plans: more.
    The noise is more noticeable on my phone than computer speakers, you might have to turn the bass down to hear it.
    It almost sounds clakity, like a diesel. Less noticeable at higher RPM, but maybe just drowned out by other noises.
    https://youtu.be/4MJ_wVFpln4
  10. May 10, 2020 at 12:10 PM
    jpark4
    2012 Tacoma 4x4
    Just started the fuel pump and the hardest part is taking the fuel and vent lines off. It’s been caked with so much sand and mud that I’m struggling to separate the damn clamps.
    Tip: take the damn read driver tire off. So much more room for activities!!! Doesn’t help the fuel line problem though.
  11. May 10, 2020 at 12:13 PM
    EchoLake
    Sacramento
    It lugged a little when I gave it too much throttle at low RPM, kinda sounds pingy.
    Lean does not sound like a good thing, maybe I should hold off driving until I get an AFR, and probably send my ECU to @JustDSM in the mean time.
    Roostfactor[QUOTED] and 420taco like this.
  12. May 10, 2020 at 12:14 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Ahh that noise. Yeah thats normal. Lol.
    rheath08 and Darkgoatracer like this.
  13. May 10, 2020 at 12:17 PM
    EchoLake
    Sacramento
    Cool. If the offer still stand to take a listen in person that would be cool.
    I'll send the ECU to @JustDSM after that regardless.
    Oh and pickup an AFR gauge somewhere.
    Roostfactor and JustDSM like this.
  14. May 10, 2020 at 12:26 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I'll be out that way from the 15-17th. Send me your address and I'll check to see where that is in relation to where I'll be.
    Roostfactor and EchoLake[QUOTED] like this.
  15. May 10, 2020 at 1:42 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Making me excited to look forward to doing the fuel pump
    MightyMouseTom likes this.
  16. May 10, 2020 at 1:45 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Read a few posts after. There is a reason why I didn't enjoy doing my fuel pump. I'm just happy that debacle is all over with honestly.
    It's actually not all that bad, remember there is more than one way to skin a cat.
  17. May 10, 2020 at 1:47 PM
    nudavinci64
    Robert
    Anyone have an extra fuel module handy? fuel pump is next on the list. Would be fantastic to have it prepped before hand.
  18. May 10, 2020 at 1:48 PM
    nudavinci64
    Robert
    Haha I know just adding to it. You def make it sound way worse I’m sure it’s no diff just a pain to do.
  19. May 10, 2020 at 2:52 PM
    EchoLake
    Sacramento
    Damn, looking into this seems like I need a wideband? That would mean getting a sensor welded..
  20. May 10, 2020 at 3:11 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It's all about the supporting mods brother!
    You would need to get a bung welded, something a decent muffler shop can do no problem for cheap.
