TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. May 12, 2020 at 6:13 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    That would be awesome man! I'll probably take you up on the OE throttle body just in case.
    Hang on... Now that I think about it I think I've seen my 2012 throwing a brake switch code before back in the day before I started tuning this thing. Could it possibly be a bad switch is engaging ever so slightly? I don't think HPTuners monitors brake pedal input activity does it?
    Flake Boost likes this.
  2. May 12, 2020 at 6:18 PM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    Soooo, I ordered Roush tensioner from LMR.
    just to confirm I now need to swap out the 76mm to a 50mm pulley, correct?
    Flake Boost and 12TRDTacoma[OP] like this.
  3. May 12, 2020 at 6:24 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    yes, pulley part number is on page 1.
  4. May 12, 2020 at 6:25 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    let me know. I still owe an alternator as well. I got new harness done, just gotta finish the fuse and distribution block.
    that would totally make sense, no power braking sucks.
  5. May 12, 2020 at 6:31 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Ok, the wife’s thought is good louvers. Anyone running them and have pictures? Anyone tested to see how well they work at dropping under hood temps? Sorry @XPOTRPR her and I both said hell no to the snorkel. And don’t want to route it into the cab either. Just looking at options to drop intake air temps a good chunk.
    12TRDTacoma[OP] likes this.
  6. May 12, 2020 at 6:40 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    Front scoop, like AFE or volant or URD CAI perhaps
  7. May 12, 2020 at 6:42 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Engine cage won’t really accept those. Started with a urd cai to get what I have lol.
  8. May 12, 2020 at 6:43 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I have this conspiracy theory that factory parts are designed with inferior parts to fail early in order to make you have to buy parts. The longer I own this truck the more I feel that way as I'm slowly watching things fail that should not be failing this soon. Lol. I'll keep you in the loop!
    I have sort of been contemplating louvers for some time as well. It would be cool to have them on a truck!
  9. May 12, 2020 at 6:47 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    I recall some company or guy (cant recall who that made a pretty nice setup. Saw it on a few FJ's.
  10. May 12, 2020 at 7:08 PM
    EchoLake
    EchoLake Well-Known Member
    Sacramento
    '15 MGM TRD OR AC 6MT
    Magnuson Supercharger, Speedhut AFR and Boost Gauges, TRD ECU Reflash, Factory Nav Unit, TRD Skidplate, VIP alarm, 265/75R16 Cooper Discoverer ATP, 1" KSP Spacers, hub centric (hold comments lol), TRD Pro Grill, Raptor Lights on with ignition. Upcoming - purchased, not yet installed: Body matched rear bumper (rattle can), Kicker Hideaway, JL Audio 6x9 components w/80Hz Bass Blockers, Hellwig anti-roll bar, TRD Short Shifter, Knock-off TRD Shifter (non-Qball), black throwback plates. Plans: more.
    I'm a big fan of analog so was checking out an AFR from Speedhut and a boost gauge from Speedhut.
    Looks like the boost gauge comes with a sensor, I've read that can be connected to the vacuum port using a T, or into the exhaust manifold. Any thoughts on that?
    It looks like the AFR gauge doesn't come with a sensor. I emailed the company and asked if it does come with a sensor, if not, will a Denso fit, if not what do they recommend. Hopefully they get back to me soon.
    You mentioned having a muffler shop weld in a bung, would this be to close the hole left by the original O2 sensor? Then would the (hopefully, if it fits) Denso sensor be installed somewhere downstream?
  11. May 12, 2020 at 7:14 PM
    Darkgoatracer
    Darkgoatracer Well-Known Member
    Nick
    Northern VA
    2012 trd sport tacoma
    Stock
    I really want to know more about this engine cage of yours.
  12. May 12, 2020 at 7:26 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    louvers it is
    snowsk8air2[QUOTED] likes this.
  13. May 12, 2020 at 7:28 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    I use both of those gauges. I may also have an extra sensor. Let me check. You will still need the extension from the gauge which I’m not sure comes with it. The sensor plugs are universal, but I am pretty sure I have two and only one bunghole.
    Norton and 12TRDTacoma[OP] like this.
  14. May 12, 2020 at 7:29 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I remain happy with my Speedhut gauges. FWIW, I went with a GL1-265 AFR (which includes a sensor and bung) and a GL-BOOST-08 boost gauge. I also liked the fact that they offer a great deal of customization (e.g., fonts, colors, logos, etc).
    Install of both is straightforward, though the AFR cable isn't long enough, so you'll need an extension cable. The boost gauge is connected via T to the boost reference port on the top rear of the S/C. (I don't understand how/why a boost gauge would connect into the exhaust manifold.)
  15. May 12, 2020 at 7:48 PM
    nudavinci64
    Robert
    depending on which one you get the AFR does come with a sensor. You can get it without as well. I have both the boost and AFR gauge from speedhut as I wanted a nice analog set.
    These are the ones I got. Still need to install. I picked up the analog out for if/when I upgrade to HP Tuner pro. The wideband came with an included sensor.
    GR1-236
    2-1/16" Standalone Air/Fuel Wideband with Analog Out, O2 gauge 8.5-18 (w/ warning)
    GR-BOOST-01
    2-1/16" Boost/Vac Gauge 30inhg-0-20psi (w/ warning)
    Flake Boost and zippsub9 like this.
  16. May 12, 2020 at 7:51 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Well braking activity is still fine and as far as I know all brakes still illuminate, but I wonder if the brake lights are flashing for an ever so brief moment as the truck takes off before they finally turn off.
    Flake Boost and zippsub9[QUOTED] like this.
  17. May 12, 2020 at 7:51 PM
    EchoLake
    Sacramento
    Thanks for the info, very helpful. Let me know if you want to get rid of it and for how much. Can an extension just be made from wire and terminals?
    So it sounds like the AFR sensor goes into the factor O2 sensor hole?
  18. May 12, 2020 at 7:53 PM
    nudavinci64
    Robert
    Any thoughts it could be the new MAF sensor? Were still figuring mine out but I have had a few instances of stepping on the gas and nothing then it kicks in.
  19. May 12, 2020 at 7:54 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    you don’t replace a factory sensor. I don’t think there is an extra spot on a factory y-pipe. You can replace one downstream if you HP delete them or use a sim. However, getting a bung put on is not a big deal.
  20. May 12, 2020 at 7:55 PM
    nudavinci64
    Robert
    You need to add another bung for it. If you want I can snap a photo of whats included. The gauge came with gauge, sensor, wiring, etc. All you needed to install it (assuming you have an extra bung.)
    You can add a no weld for quick setup:
    https://www.summitracing.com/parts/sum-690125
    Or you need to get one welded on by a shop which also is prob not too hard just more involved.
