TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. May 12, 2020 at 7:56 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    @12TRDTacoma
    please note these instances and reference the time on the log if at all possible. I'm seeing this issue on the rise and what I'm observing is the ECU is acting as if it's still at idle, and is applying the idles ignition correction (which cuts a bunch of timing) and makes the truck feel gutless for a split second or two.
  2. May 12, 2020 at 7:57 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Will do.
  3. May 12, 2020 at 7:58 PM
    EchoLake
    EchoLake Well-Known Member
    Sacramento
    '15 MGM TRD OR AC 6MT
    Magnuson Supercharger, Speedhut AFR and Boost Gauges, TRD ECU Reflash, Factory Nav Unit, TRD Skidplate, VIP alarm, 265/75R16 Cooper Discoverer ATP, 1" KSP Spacers, hub centric (hold comments lol), TRD Pro Grill, Raptor Lights on with ignition. Upcoming - purchased, not yet installed: Body matched rear bumper (rattle can), Kicker Hideaway, JL Audio 6x9 components w/80Hz Bass Blockers, Hellwig anti-roll bar, TRD Short Shifter, Knock-off TRD Shifter (non-Qball), black throwback plates. Plans: more.
    Cool so it looks like you customized them with the TRD logo, looks nice.
    Thanks for the info re the boost gauge.
    Flake Boost and Norton[QUOTED] like this.
  4. May 12, 2020 at 8:00 PM
    EchoLake
    Sacramento
    Alright, thank you. Doesn't sound like that hard of a job, possibly within my pay scale. :fingerscrossed:
    Flake Boost and zippsub9[QUOTED] like this.
  5. May 12, 2020 at 8:01 PM
    EchoLake
    Sacramento
    Cool cool. Thanks for the link.
    Flake Boost likes this.
  6. May 12, 2020 at 8:05 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Posted a pic on the last page and there’s more in my build page. Chopped out inner fenders, built engine cage that ties to the cab cage
  7. May 12, 2020 at 8:27 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    lol... then :notsure:
  8. May 12, 2020 at 8:34 PM
    EchoLake
    Sacramento
    Also, where did you pickup that gauge pod? Looks nice.
  9. May 12, 2020 at 8:40 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Thanks! It's a Lotek "2 pod / full pillar." Note that it's designed for '05-'09 Tacomas, but works in later MYs usually with slight modification.
    Roostfactor and EchoLake[QUOTED] like this.
  10. May 12, 2020 at 8:41 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I'm going to take a dedicated log for you tomorrow specifically made to log the lags at take off exclusively tomorrow or the next day since I'll be off. Are you meaning to say that I'm not the only one who this is happening to as of lately?
    I almost wonder if this may be related to the 100% removal of throttle lag which I have had you remove on my setup for immediate throttle input.
    When I have observed data on my scanner I have noticed as it graphs on the TB that I can see a small spike up as I input throttle then as soon as the pause happens the graph drops a little then it comes right back up. Coincidentally I have also noticed the the STFTs spike to about 20% or so when this happens then they even out to normal readings.
  11. May 12, 2020 at 8:44 PM
    nudavinci64
    Robert
    I noticed a similar thing as well. Almost felt noting then back to normal.
  12. May 12, 2020 at 8:46 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You know what, did you trim your intake tube at all before installing it?
    I remember I saw a video once about the TRD intake tube butting up against the valve cover fresh air breaker hose fitting and it was causing lean issues.
    https://youtu.be/TfMpeTdseMU
  13. May 12, 2020 at 8:54 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Flake Boost and zippsub9 like this.
  14. May 12, 2020 at 8:54 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
  15. May 12, 2020 at 9:17 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Urd tcai routed to above the engine lol. Ordered some louvers that one should be able to get mounted directly above the filter. Gonna see how they look and how I like them before cutting and also probably gonna do some logging with the truck just idling for a while and see how things change if I open the hood. Not the best of tests but it’s something before chopping holes in the hood
    Posted a pic of where my intake is a page or two ago
  16. May 12, 2020 at 9:19 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Oh I see it. Its backwards to what a traditional intake does. No wonder your IATs are high!why can't you run it the traditional way outwards toward by the FMIC?
  17. May 12, 2020 at 9:21 PM
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    You got your gauges already, Im still waiting for mine. It's stuck at "in production".
  18. May 12, 2020 at 9:28 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Engine cage tubes are in the way. Anywhere else in the wheel well is just way too exposed to water ingestion.
  19. May 12, 2020 at 9:32 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Water ingestion is not as big a deal as you are making it unless you go fording rain and similar stuff of that nature does nothing.
    The tubes are in the way, fair... how about routing it the traditional way using a series of silicone tubing made by Squirrelly performance? I made my URD TCAI at the time route the intake a custom way and it required I cut portions of the curved tube to make it run the way I needed. Myself and @White lightning boosted ran ours this way for a long time with no issues. If there is no immediate solution, make one. ;)
  20. May 12, 2020 at 9:35 PM
    nudavinci64
    Robert
    Yah I ordered Them last year though. They did take forever and they also noted a delay due to all the shit going on.
