TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. May 13, 2020 at 2:11 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    True but I thought DT also had a Carb approved version? Even if thin how much would that matter for the Ti versions? Not a ton of options for us.
  2. May 13, 2020 at 2:26 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Sent!
    DT does not have a CARB approved version otherwise I would had just went with them long ago.
  3. May 13, 2020 at 2:27 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Which one of the 3 are you running currently?
  4. May 13, 2020 at 2:28 PM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    Nate actually made me a smaller hub, it's like 1.3" diameter or something, so I could get my 1.87" pulley on. Ya there might be some belt slip concerns.
  5. May 13, 2020 at 2:36 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Could you have it grinded off or covered with piece of metal welded over it? I have the DT shorties.....love em! I’m more than aware of your States issues but I’m sure you can figure out something
  6. May 13, 2020 at 2:37 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The 2011 V4.
    JustDSM[QUOTED] likes this.
  7. May 13, 2020 at 2:41 PM
    JustDSM
    Justin
    Ogden, UT
    File returned. I have a feeling it'll be a lot better. Please test and report back ASAP.
    *This isn't the fix* it's just a demonstration that the issue is with the ECU believing it's at idle. The root cause would need to be investigated to determine why, but I wanted to demonstrate that THIS is the problem. Not the MAF/FPR mod/Etc.*
  8. May 13, 2020 at 2:50 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I have to run to the store here in a little bit. I will flash before I do and report back ASAP.
  9. May 13, 2020 at 3:00 PM
    nudavinci64
    Robert
    Flake Boost and SUMOTNK like this.
  10. May 13, 2020 at 3:02 PM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    They are. The DT shorties have a carb eo # and I have never failed visual because of it.
    It's the long tubes(DTs, JBA, UR) that do not have an EO #.
    Flake Boost and Torspd like this.
  11. May 13, 2020 at 3:05 PM
    nudavinci64
    Robert
    I updated my comment but its more about the 12-15 trucks. The OE approved ones are fr 05-11 trucks so they wont fit directly on the newer trucks.
    JBA is the only one that has a 12-15 shorty in stainless, ceramic, ti options.
  12. May 13, 2020 at 3:09 PM
    SUMOTNK
    Eddie
    Crap...since it doesnt apply to me, i always forget about that secondary air tube on the newer 2ndGens. Im surprised that DT doesnt have a shorty for the 12-15.
    Flake Boost and 12TRDTacoma[OP] like this.
  13. May 13, 2020 at 3:17 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The only ones who seem to make shorties for the 2012-2015 which are also CARB legal is JBA apparently.
    Flake Boost and SUMOTNK[QUOTED] like this.
  14. May 13, 2020 at 4:29 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Sonofabitch.
    I think I may have just found the reason why the truck has been acting odd lately.
    I went to go install the new coolant tank that @mightytacoman sent out to me and flash the new tune provided by @JustDSM for the potential stumble fix.
    During my install I went to go disconnect the coolant pump and found that when I went to go plug it in I couldn't feel it working and I couldn't hear the coolant sloshing around. I went to investigate and I found that the fuse for the EFI no 2 was plugged in and everything looked okay but was making an intermittent power connection to the pump. Why I don't really know. So I just swapped over the coolant pump wire over to the other side of the fuse and everything works okay again. What a cheap afterthought crapass setup from Magnuson to run the coolant pp to run it that way. Now the actual cooling pump is working my boost pressures went down and overall coolant temperatures went down. I don't know how long I was running it like this but now I'm slightly paranoid and worried.
    Flake Boost and Roostfactor like this.
  15. May 13, 2020 at 4:43 PM
    420taco
    420taco Well-Known Member
    Justin
    PA
    Need to find a reliable way to prove flow through the intercooler... It’s the achilles heal of this setup.
  16. May 13, 2020 at 4:47 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
  17. May 13, 2020 at 5:07 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    I am gonna find a new circuit and also produce some LEDs here to show that the pump is active. I will wire it into an ignition circuit.
  18. May 13, 2020 at 5:30 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    We need to come up with a centralized, express method of turning the pump into an ignition feed powered relay activated at engine running pump.
    If we can do that, I think it would help everyone SEVERELY.
    Way this thing is set up right now is a band aid method of powering a pump. Luckily I think I saved my engine by having HPtuners and Justin really neuter my tune, because if I didn't I think I would had popped the head gasket or even bent a valve. Now that everything is running correctly again, the truck suddenly has A LOT more power even with the neutered tune.
  19. May 13, 2020 at 5:31 PM
    nudavinci64
    Robert
    what a simple issue. I do not like the t tap they use. I was debating on changing it to an add a fuse that pretty much everyone else uses and is more sturdy then that crap t-tap they use.
    The idea of a light showing its working is a great idea. That should be a pretty easy thing to tap into. Even tap into the same line that powers the pump with small diode.
  20. May 13, 2020 at 5:32 PM
    nudavinci64
    Robert
    Thats killer you stumbled onto that.
