TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. May 14, 2020 at 10:57 AM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    I shaved down the sides, moved my switches to the right, cut out the support between two switches then set it in there.
    It's worked flawless for like 4 years now.
  2. May 14, 2020 at 10:58 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Hey guys, just off the top of your head, does anyone know if the nst alternator pulley with the step near the end is for tow package trucks?
    Flake Boost and Athlaos like this.
  3. May 14, 2020 at 11:01 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Did you mount it in with screws or anything or some sort of adhesive?
    Flake Boost likes this.
  4. May 14, 2020 at 11:04 AM
    Roostfactor
    TX panhandle
    Wont work for my plans either as my intake will eventually be where the battery currently sits.
  5. May 14, 2020 at 11:05 AM
    Roostfactor
    TX panhandle
    Nope, it just sits in there snug. No fasteners or anything.
  6. May 14, 2020 at 11:07 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Whoa. 60* temp differential. That's nuts!!
    Now that my system is restored back to working order, I'm really happy with the way the setup pulls now, and those power levels are bound to rise again later today after I get my tune back from Justin, so I can really see what this intake is capable of putting down.
    Boost is down from 17.1 psi to 13.3 psi at WOT so that just goes to show me how bad the engine was suffering from the hotter intake air temperature charges inside the blower. It's wild how much these blowers benefit from the supplied IC setup.
  7. May 14, 2020 at 11:07 AM
    Roostfactor
    TX panhandle
    I dont have answer to your question but you know your welcome for mod day!
    Just throwing the offer out there.
  8. May 14, 2020 at 11:08 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Hey @BassAckwards there is no way of knowing until you pull out the pulley apparently. Supposedly ours come with the stepped but I believe there were two different manufacturer versions of our alternator so that ups the question mark factor a little more.
    Flake Boost and BassAckwards like this.
  9. May 14, 2020 at 11:11 AM
    Roostfactor
    TX panhandle
    The video I shot was going East on I10 a bit past lake Havasu in the summer going uphill.
    You can see the temp differential in action.
  10. May 14, 2020 at 11:16 AM
    BassAckwards
    Thanks man!! Im definitely gonna try to make it once yall get all the details sorted out. Should be one for the books based on what ive read in here. Folks coming from all over it sounds like
  11. May 14, 2020 at 11:16 AM
    BassAckwards
    Ahhh i see, alright thanks for the heads up
  12. May 14, 2020 at 11:16 AM
    Roostfactor
    TX panhandle
    I also want to say publicly that @12TRDTacoma's y-pipe will be a one off custom unit so he will not be getting a standard JFR Y-pipe.
    I say this because I feel it's of great importance to keep everyone's order in line.
    Because his will be custom, everyone still keeps their spot in line and I can sleep at night knowing I'm not cheating anyone out of their spot in line.
  13. May 14, 2020 at 11:17 AM
    BassAckwards
    So im assuming here, as heat increases pressure increases?
  14. May 14, 2020 at 11:18 AM
    BassAckwards
    We need some deets! What kinda custom touches you putting on his? Im curious more than anything:D
    Flake Boost and BillDaCat8 like this.
  15. May 14, 2020 at 11:18 AM
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    Those are wild boost numbers. I have yet to see anything over 10.5 psi of boost with mine on the 2.5 pulley. I suspect boost numbers will drop even further with the Kelford cams installed. Need to get the "other car" back on the road before I tear into the truck tho.
  16. May 14, 2020 at 11:21 AM
    Roostfactor
    TX panhandle
    I hit 13 psi with 2.3 pulley and full exhaust.
    @12TRDTacoma's current exhaust is what is causing such high numbers.
  17. May 14, 2020 at 11:21 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Its a bit of a gamble but on my 2013 OR with tow package I needed the step not the flat. NST is under the impression that the flat is for all OR packages.
  18. May 14, 2020 at 11:24 AM
    Roostfactor
    TX panhandle
    Basically making a fully custom y-pipe with his stock cats so he can be fast AND legal.
  19. May 14, 2020 at 11:29 AM
    nudavinci64
    Robert
    Thats what I want to discuss with you too. =)
  20. May 14, 2020 at 11:30 AM
    Roostfactor
    TX panhandle
    In this case heat is an unwanted byproduct of the pressure rise.
    Heat doesnt cause the pressure increase.
    The pressure increase causes the heat.
