TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. May 15, 2020 at 11:38 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Haha what is this run you speak of?
    UGH, you just reminded me i NEED to do this (had cam gears sitting in my tool box since november?), and in order to do this.... i need to get me valve cover gaskets etc coming.....
    Flake Boost and Roostfactor like this.
  2. May 15, 2020 at 11:38 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I'll be there
  3. May 15, 2020 at 11:41 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    The unofficial now pretty much official Texacoma meet on the road to @Roostfactor 's house for a mod day/ my own exhaust custom build. :thumbsup:
    Sweet. I updated your pending thingamajigger on the list.
  4. May 15, 2020 at 11:53 AM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Per our guy Kiel at Kelford -yes you can run both. Per URD- you can't. Kiel said it moves the powerband lower by running them with the Kelford cams, URD doesn't offer an explanation as to why you can't do both. Personally I trust Kiel more and am willing to try it
  5. May 15, 2020 at 11:58 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Which truck???
    Flake Boost likes this.
  6. May 15, 2020 at 11:59 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Don't think I will have my exhaust rerouting completed by then. :pout:
    Despite no date yet set.
    Flake Boost and 12TRDTacoma[OP] like this.
  7. May 15, 2020 at 12:03 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Wish my grass looked that good. I’ve got 2.5 acres available at pit stop 1 for whomever wants to stop.
  8. May 15, 2020 at 12:05 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    *Thicc
  9. May 15, 2020 at 12:07 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Depends on date. I'm on a week on week off rotation. Today is my last day off so I'm on till next Friday around 17:00 or so.
  10. May 15, 2020 at 12:16 PM
    BassAckwards
    I believe @Athlaos is running the urd cam gears with his kelford cams, but he is still running his truck without the blower belt
  11. May 15, 2020 at 12:46 PM
    BassAckwards
    Probably the v6. 4 cylinder pukes coolant in the reservoir after driving for a while on the highway, not the best road trip vehicle:anonymous:
  12. May 15, 2020 at 1:17 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    That’s how I always saw it in that each cylinder would have more volume for the intake charge.
    I don’t see how these exhaust cam gears would up our boost though. @12TRDTacoma
  13. May 15, 2020 at 1:56 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I'm trying to think this through from an engineering perspective and I am no expert on the subject matter, so I could be totally off.
    Let's see, so cam gears offers a more complete burn by hanging the exhaust valves open a little bit longer. A more complete combustion event in other words. By removing the cam designed built in EGR you are allowing for cooler cylinder temps, you are also allowing for better airflow (which makes sense based on the fact that there is more air moving through the engine by allowing the exhaust valve to hang open a little bit longer.
    I used to push 11.5 psi nominal and 12 was absolute peak. Considering I am 13.3 now and the engine feels like it has more go throughout the band I am (in my non expert opinion) venturing an educated guess in saying that the boost numbers I am seeing now are normal and a byproduct of the gears retardation of the cams. Could I improve airflow by removing my topped out exhaust system flow at the headers and at the Y pipe? Absolutely... Is there a chance that boost numbers will drop off once those items are installed and in play? Absolutely... Do I think cam gears ups the boost regardless of flow whether or not there is a restriction and I ran a 2.3 with them in my own truck and ran an identical truck without them? I still do.
  14. May 15, 2020 at 1:57 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    By the way ya'll let's shoot for August on this road trip. I think that's suffice time for me to collect my money and my mods and work out hotels and such prior to the trip.
  15. May 15, 2020 at 3:13 PM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    I am.
  16. May 15, 2020 at 3:14 PM
    Roostfactor
    TX panhandle
    You making the trek or just meeting people in Flagstaff?
  17. May 15, 2020 at 3:23 PM
    Roostfactor
    TX panhandle
    That's fine but keep in mind this is Texas not Norcal so the later in the summer we plan for means hotter than HAF weather.
    The potential upside is I can have more y-pipes made so peeps could save on shipping AND possibly get an install on mod weekend.
  18. May 15, 2020 at 3:24 PM
    Roostfactor
    TX panhandle
    Blown head gasket pressurizing cooling system?
  19. May 15, 2020 at 3:28 PM
    Roostfactor
    TX panhandle
    Also, for those with tuners, we could retard VVTI 3° across its active range which would keep valve overlap the same as oem.
    I've played a bit with VVTI but no definitive testing done.
  20. May 15, 2020 at 3:34 PM
    Roostfactor
    TX panhandle
    The date is going to be set by @12TRDTacoma since it's his exhaust getting fabbed.
    I still say the sooner the better to try to beat the heat.
