TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. May 18, 2020 at 12:39 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    the pipe cutter with numerous turns and slow tightening works. I ran a sacrificial bolt through mine when I cut it to keep it from hopping around.
  2. May 18, 2020 at 12:40 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Just use some aluminum cutting oil to help and make sure your cutter is for aluminum. I was skeptical but once it scores the line it hold pretty true. It does make it a bit funk holding it. I had it in a vice. I would suggest if you can adding something on the sleeve to not mess it up. My vice did a bit since it was not "soft". I buffed it out with a dremel and cleaned up where it cut.
    Also I flipped it over when I installed it but either should work. The lip from the cut did require some cleaning up as it was just enough to not let it slide in, but overall, solid and flush with no play. I did use a bolt/washer as you noted.
  3. May 18, 2020 at 12:41 PM
    nudavinci64
    Robert
    that would have been a nice touch. Mine did not move but would prob have helped with the cleanliness of the cut at the end.
    zerotimeouts likes this.
  4. May 18, 2020 at 12:59 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    I used a copper pipe cutter. Worked just fine
  5. May 18, 2020 at 1:34 PM
    nudavinci64
    Robert
    Good to know. I had to buy one so I just made sure it handled aluminum and the size. That Rigid one works well and recommended by @12TRDTacoma as he used the same.
    zerotimeouts and 12TRDTacoma[OP] like this.
  6. May 18, 2020 at 4:06 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Yeah you really just have to go slow and understand the area of the cut will flare outward just a smidge from all the cutting you are doing. Finish it off with a nice belt sander or some 120 grit sandpaper and you are good to go!
  7. May 18, 2020 at 4:47 PM
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    I was fully catless, DTLT and custom y-pipe and Borla muffler and also URD spec.U long tubes and spec.U equal length exhaust. I can't say as if my boost numbers went down because I was DTLT's and custom y-pipe before the supercharger. I can say that when I did that without the supercharger I lost a bunch of bottom end torque but it ripped up top. I now have two MagnaFlow high flow cats welded into the spec.U to help tame the noise. did almost nothing.
  8. May 18, 2020 at 4:54 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    So down low it basically felt ball-less but up top it was a ripper huh?
    High flow cats are more like resonators more than anything, and horrible ones at that because as you mentioned they do almost nothing.
    @hx989 here is a real world example of what we were talking about earlier.
    nudavinci64 likes this.
  9. May 18, 2020 at 7:22 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    URD spec U's.. Fully catless.. into custom y pipe.. into 3" with the biggest magnaflow I could fit.
    as soon as I removed the last 2 cats.. boost dropped 1-2 lbs. pulls like a mofo now tho in the mid-higher range.. I like and dont like it.. I like low end.
    mr.trd likes this.
  10. May 18, 2020 at 8:00 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    So you removed the main two at the manifolds first and then you removed the final two at the Y pipe which helped you drop 1-2 lbs psi? Do I have that right?
    If that's the case, that implies that the rear cats are restrictive as well.
    XPOTRPR[QUOTED] and Athlaos like this.
  11. May 18, 2020 at 8:05 PM
    nudavinci64
    Robert
    Interesting. Seems like def benefit but I’d like more low end if possible.
    12TRDTacoma[OP] likes this.
  12. May 18, 2020 at 8:06 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    I cannot wait for my Roost Y-pipe... gonna fix this exhaust right up. No boost gauge... so sorry no numbers
  13. May 18, 2020 at 8:16 PM
    nudavinci64
    Robert
    Time to get them gauges..
    Camby likes this.
  14. May 18, 2020 at 8:25 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Ignorance is bliss. My truck runs amazing and there’s nothing to tell me otherwise.
  15. May 18, 2020 at 8:26 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Correct.
  16. May 18, 2020 at 8:44 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    Keep the stock cats on then get another set of stock cats and put those on too!
  17. May 18, 2020 at 8:44 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Dude... If that's the case I may just create my boost bypasses at the Y pipe cats then instead. And quit worrying so much about the main cats and just do headers to further open things up.
    XPOTRPR[QUOTED] likes this.
  18. May 18, 2020 at 8:47 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Same. I want peak power between 2000-3500rpm.
    nudavinci64 and XPOTRPR[QUOTED] like this.
  19. May 18, 2020 at 8:54 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Agreed. Powerband definitely shifted after removing the rear cats.. and I can absolutely tell while on the trail. Big change.. and honestly like it better for wheeling with the cats.
    mr.trd likes this.
  20. May 18, 2020 at 8:55 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    That’s good to know. Wanted to ditch all cats but...might not now.
