TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. May 23, 2020 at 9:07 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Noice!!!! I love that astonished look on their faces. Can't hide that truth of reaction.
    Traded a thumbs-up with a ZL1 owner not to long ago. Good stuff.
  2. May 23, 2020 at 9:53 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    Next X pipe I get will be 304. Don’t know about the rest of the exhaust but the X will definitely be 304.
    Aaaaaand supercharger just moved up higher on my list for the soon to be Tundra
  3. May 24, 2020 at 6:52 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    they work. reccomended for these trucks.
  4. May 24, 2020 at 8:59 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Raced one off a light. He was sitting there revving the thing and I let him hit the hammer and then jumped him by 3 cars and he never caught me. Turned off before we could line up at another light. I could hear him back there all-in, shifting gears... Sounded nice.
  5. May 24, 2020 at 9:47 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Their problem is that they are almost as heavy as our trucks. Lol. They are fat pigs.
    BassAckwards and Norton like this.
  6. May 24, 2020 at 11:12 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    I need smaller pulley and a few items to feel that. Trucks feeling nice but not quite there yet.
  7. May 24, 2020 at 11:16 AM
    420taco
    420taco Well-Known Member
    Justin
    PA
    They are heavier than a stock Tacoma.
    Torspd and 12TRDTacoma[OP] like this.
  8. May 24, 2020 at 11:31 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    They weigh what, some 5000lbs?
    What do ours weigh stock? (Before all the skid plates, Dorkels, and steel bumpers)
  9. May 24, 2020 at 11:37 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Think the sticker weight for a dcsb is about 4400
  10. May 24, 2020 at 2:25 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    According to the 2013 MY Brochure (excerpt atchd)...
    - Access Cab 4x4 V6 6MT Curb Weight = 4075 lbs
    - Access Cab 4x4 V6 AT Curb Weight = 4100 lbs
    - DCSB 4x4 V6 6MT Curb Weight = 4160 lbs
    - DCSB 4x4 V6 AT Curb Weight = 4185 lbs
    - GVWR for all of the above = 5500 lbs
  11. May 24, 2020 at 3:51 PM
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    Well I am a little disappointed in Speed Hut. Got both gauges installed and they look great. But after only 90 miles the AFR gauge stopped working. Double checked all the connections and everything is good. If I let it sit it will work for a while then just stop responding.
    LamzTaco and Athlaos like this.
  12. May 24, 2020 at 3:57 PM
    nudavinci64
    Robert
    Sounds like either a connection or the sensor. How did you hook up power? When I first hooked it up my connection was not solid. I thought I had an issue too. either way they have a lifetime warranty. They will help you out.
    JuanitoBonito and Norton like this.
  13. May 24, 2020 at 4:03 PM
    Norton
    +1 to all of this!
    Coming up on a year since I completed the install, and haven't had a single problem with mine.
  14. May 24, 2020 at 4:04 PM
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    The gauge has power Im using a dedicated relay for it.
    I was thinking sensor too, but even if I unplug the sensor it does nothing.
    When I first installed it I did not have the sensor hooked up and it would do its warm up cycle, bounce between 14 and 15. I did not drive it like this I just installed the gauge and powered it up.
    After I completed the install it did the same but only for 15-20 seconds then started reading normally.
    Now it will not do anything, I can hear it power on (sounds like the motor inside moving). When I start the vehicle the needle bounces to 9 and then moves back to 8.5 really quickly. I can adjust the warning light, but other than that I get no response from the gauge.
    This makes me think it is the gauge not the sensor, but I could be wrong.
    Norton likes this.
  15. May 24, 2020 at 4:06 PM
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    I did send an email to Speedhut for assistance. I probably won't hear back thill Tuesday though.
    Norton likes this.
  16. May 24, 2020 at 4:25 PM
    Darkgoatracer
    Darkgoatracer Well-Known Member
    Nick
    Northern VA
    2012 trd sport tacoma
    Stock
    Got the cam gears in, supercharger serviced and plugs changed. What a pain in the ass that was....
  17. May 24, 2020 at 4:32 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  18. May 24, 2020 at 4:37 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    new parts can fail. does seem odd though. swap a new relay for fun. ive learned that way.
  19. May 24, 2020 at 4:41 PM
    nudavinci64
    Robert
    I hear ya. no dedicated relay but mine does the bouncing since it’s not hooked up yet. haven’t heard much bad things about speedhut. Hopefully chalk it up to a bad unit and get a new one.
    I was thinking of ordering a couple other gauges since they are doing 15% off this weekend.
  20. May 24, 2020 at 8:03 PM
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    I have tested for power at the gauge so I know thats good.
    I really like how they look, I was going to order a second AFR gauge also.
    Im sure they will fix the issue.
