TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. May 26, 2020 at 6:16 PM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    i have the csf tacoma version. no complaints. today on my way home from work never went over 187*
  2. May 26, 2020 at 6:20 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Fj version with the URD 170* stat.....I stay at 187-190
  3. May 26, 2020 at 6:37 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I forgot about Ice that's right. I'll be investigating this stuff tomorrow! By investigating I mean replacing coolant. Both in the engine and in the blower.. I just need to decide which one will work better.
    Oh that's real nice!
    I still consider a radiator, but the other half of me says why drop so much money if the current one still works.
  4. May 26, 2020 at 6:39 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    You can say that about every mod and upgrade we do.....
    Camby, Norton, henryp and 2 others like this.
  5. May 26, 2020 at 6:39 PM
    rheath08
    Russell
    Bakersfield, CA
    cause bling and performace bro!
  6. May 26, 2020 at 6:40 PM
    rheath08
    Russell
    Bakersfield, CA
    s add some peer pressure. :devil: :boink:
  7. May 26, 2020 at 6:57 PM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Careful with just water and wetter.
    Boiling point is likely lower.
    You can do 30% coolant 70% water and wetter to still provide the protection needed and achieve enhanced cooling.
    mr.trd, Norton and 12TRDTacoma[OP] like this.
  8. May 26, 2020 at 6:58 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You guys can stop that. :laugh:
    Hey @White lightning boosted how much water wetter did you use in the blower cooling system?
    I am going to buy two bottles later of water wetter and am trying to figure out how much of each I am going to need to dump into each cooling system. I'm thinking a full bottle for the engine along with the needed water for it and then the question mark for me is the blower cooling system.
  9. May 26, 2020 at 7:02 PM
    Roostfactor
    TX panhandle
    As @Lucario Runner stated the radiator needs both incoming and exiting airflow.
    Without both, efficiency of the system is compromised.
  10. May 26, 2020 at 7:08 PM
    Roostfactor
    TX panhandle
    Imagine a cardboard box laying down with one side open and a radiator flush mounted to the opening then put a fan in fron of the radiator.
    How much air do you tink would flow through the radiator?
    Now open the back of the box to allow air to escape.
    How much air do you think would flow through the radiator then?
  11. May 26, 2020 at 7:13 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    Oh oh oh I learned this back in my computer days too. Something about positive and negative pressure.
  12. May 26, 2020 at 7:23 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Could always go jdm with a hood riser washer spacer. cheap and easy. Also besides cleaning you could also check for air in the system from a leak like the weep hole for example.
    12TRDTacoma[OP] and BassAckwards like this.
  13. May 26, 2020 at 7:32 PM
    Darkgoatracer
    Darkgoatracer Well-Known Member
    Nick
    Northern VA
    2012 trd sport tacoma
    Stock
    I mean, not that often. But when it does the the truck runs the exact same temperature.
    Edit: there is both latent and sensible so maybe that plays a part?
  14. May 26, 2020 at 8:02 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    +1 for engine ice. It's all I use in my bikes. Never thought to put it in the truck....
  15. May 26, 2020 at 8:25 PM
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    a few ounces.
  16. May 26, 2020 at 8:59 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You know, I didn't think about this but the skid plates thing really doesn't help releasing air, especially on scorching hot days.
    I should probably pull off the rear cowl gasket.. I usually do every summer anyways, but it's going to have to be a regular thing now because of the blower and everything that's going on in there just convecting heat.
  17. May 26, 2020 at 9:07 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Heat rises, I wouldn’t worry about skids too much. It’s warming up out here this week so I’ll be testing my hood louvers to see how much that helps with my IAT’s. I can add a PID to log coolant temps as well. But from visual cues from yesterday’s wheeling adventures, the heat pours out of them quite nicely.
  18. May 26, 2020 at 9:10 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I'm eager to see/hear how your NGK 95125 Ruthenium HX plug experiment goes. :popcorn:
  19. May 26, 2020 at 9:14 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Heat rises while you are at a standstill, but if it's trapped by a crap ton of skids while the truck is moving, the cooling system is going to have a harder time shedding that heat now isn't it?
    Roostfactor likes this.
  20. May 26, 2020 at 9:48 PM
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    Do you have the voltage booster mod on your truck?
    Norton[QUOTED] likes this.
