TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. May 27, 2020 at 5:57 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    As for the louvers go I was monitoring IAT’s this afternoon on my way home. In similar ambient temps and driving style pre-moving the filter and pre-louvers I was seeing 125-130* IAT’s. Today they were down to 95-100* and stuck there until speeds dropped below 35mph or so. Did reach 120* sitting idling waiting for a train but dropped right back down as soon as I started moving.
    mr.trd, SUMOTNK, Norton and 2 others like this.
  2. May 27, 2020 at 5:58 PM
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    Any reports on experience? Will be needing similar when I catless headers and y pipe show up. She gonna be stinky.
  3. May 27, 2020 at 6:54 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Norton and 12TRDTacoma[OP] like this.
  4. May 27, 2020 at 6:56 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i have (a) vibrant cat. mine stinks
  5. May 27, 2020 at 6:57 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    E85 ;)
    :rofl:
  6. May 27, 2020 at 7:00 PM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    and 103 octane to boot :drevil:
  7. May 27, 2020 at 7:00 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    I’ve got 2. Kinda stinks but better than catless.
    Vibrant no longer has the rights to those GESi cats I think but others sell them. Kooks has them marketed as “green” cats I believe.
  8. May 27, 2020 at 7:03 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i just go faster. today 75*, water temp pre intercooler 83*. moderate freeway driving (spirited) stayed that way. engine temps between 179-185, no a/c used. glycol in motor, water in s/c system. im able to get rid of heat quicker with a free exhaust, the methanol sequence isnt bad either. help you compare.
    @12TRDTacoma
  9. May 27, 2020 at 7:08 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Today I hit 407.2 grams/ sec or 53.86 lbs/ min at the MAF during gmy latest HPTuner log... The most I have ever recorded and seen coming out of (or rather into) this truck..
    Idle is absolutely glass smooth everything seems much happier. I like where I'm at with the new "coolant" and the Ruthenium plugs. I think I'll keep it and experiment longer as the truck really seems to like it as well.
  10. May 27, 2020 at 7:29 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    I prefer catless but I at least need one of my vehicles (the daily tacoma or the eventual new daily) to at least be somewhat legal. I was thinking of getting afe headers but after seeing the reports on here of blowing out the cats makes me not want to deal with that, plus I'm not sure about the material. these would be cool for two shortie header deal or one large cat in the catback.
  11. May 27, 2020 at 7:30 PM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    What rpm did you hit those maf numbers at?
  12. May 27, 2020 at 7:33 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    I’m not going to get into the details of this out in the open, but the numbers reported are not indicative of actual airflow through the motor.
    I’ll let Roberto explain if he wishes.
  13. May 27, 2020 at 7:36 PM
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    I picked up the gm diode today to test, and sure enough the gauge is working on warm starts also.
    I wanted to test before I ordered the HBK fused diode.
    I am running an AGM battery hopefully this will help keep it charged. I always thought it was because I did not drive the truck enough.
    Torspd and Norton[QUOTED] like this.
  14. May 27, 2020 at 7:40 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Yes the AFE ones are garbage. I have vibrant highflows on DT shorties and love em.
  15. May 27, 2020 at 7:47 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    I don’t know any facts on what Robert is running, but calibrating my MAF in HPTuner can basically read out whatever g/s you want according to the amount of voltage input to keep the wire heated. There would have to be a complete baseline reset back to a known baseline, could be stock or not, each time in order determine airflow variances of a different intake. This is also somewhat skewed if you adjust the MAF size or diameter inlet of the MAF housing.
  16. May 27, 2020 at 7:52 PM
    JustDSM
    Justin
    Ogden, UT
    You're absolutely right. That's why there's little point to "bench racing" MAF numbers.
    But for quick sanity check to validate if the numbers are even meaningful, is to measure the fueling error present at a given MAF voltage (g/sec value). There's more to the picture than this, but generally speaking, if you're commanded fuel value is matched by your observed value, your MAF calibration is probably on point.
  17. May 27, 2020 at 9:45 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Apparently there has been a long withstanding issue where Justin is running out of fueling and has been throwing the kitchen sink at my tune in order to try and satisfy my fueling needs. He says he cannot exceed I think it was 12.0 or 12.1 AFR for some reason.
    I just checked fueling tonight to see how well my fuel pump was pumping out fuel and at idle with the FPR mod hooked up I was seeing 34-35 PSI @ idle (normal for FPR mod) and reversing the FPR mod I am seeing 42-43 PSI @ idle. When giving the blue turd some juice under boost on WOT stabs I was seeing anywhere from 58-60 PSI. That tells me fueling is up to par and okay at this time. So Justin mentioned either it's going to be a hardware or a software issue. Technically speaking I do have my 2012 PCM still and I need to reverse all that so I can properly disable some items maybe I can do a PCM swap and reverse some other stuff I have disabled to rule out software issues. ;)
  18. May 27, 2020 at 9:50 PM
    JustDSM
    Justin
    Ogden, UT
    If the pressures are just from free revving, that’s not going to really tell much.
    You need to put the pump under sustained load. We need to verify under operating conditions.
  19. May 27, 2020 at 9:51 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Sounds like I gotta hit the shop tomorrow and take this thing on a spin.
    I was afraid you would need more than my quick check.
    Out of curiosity, when did you notice this issue start happening?
    And another thought, is COTP turned off still? Maybe I need it after all as you mentioned?
    Just blindly spitballing here.
  20. May 28, 2020 at 12:00 AM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    It's too bad there isn't a better way to provide auxiliary cooling when moving slowly. Seems like adding supplemental pusher electric fan would be another failure point and the engine bay is so cluttered who knows how much cooling you could actually do.
    FYI, I think you can get more cooling with a few more vents. Plenty of room on that hood and it already has a set of holes, what's a few more. :sawzall: (NM, pic is from an ih8mud thread)
