TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. May 30, 2020 at 11:15 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    There are alternative solutions which are 1000% plug and pray.
    If I do wind up needing injectors I know exactly where to get them from and they are custom units for a great price.
    710CC's ;)
  2. May 30, 2020 at 12:08 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    someone i know bought a 2nd gen for 4k.
    12TRDTacoma[OP] likes this.
  3. May 30, 2020 at 12:19 PM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Damn!!!
  4. May 30, 2020 at 12:31 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    it is an as is gamble but at that price you could buy a couple.
  5. May 30, 2020 at 12:51 PM
    Roostfactor
    TX panhandle
    Need to finance so cant have salvage title.
  6. May 30, 2020 at 12:54 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    ok. understand. ill keep an ear out.
  7. May 30, 2020 at 4:24 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I know this is a little late for most members here, but this will be added to resources and I kept forgetting to add them, but there is a large selection here from 550cc, 650cc, 710cc, 750cc 850cc and even 1000cc for heavy duty users all 100% bolt on, no pigtail adapter harness required. They even offer custom sized injectors specifically for your needs.
    https://www.fiveomotorsport.com/catalogsearch/result/?q=1zz
  8. May 30, 2020 at 4:33 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    No immediate lines on anything, Roost, but happy to keep eyes/ears open. FWIW, I've had decent luck with both AutoTrader and Craigslist. Obviously, YMMV.
  9. May 30, 2020 at 5:59 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I can't believe I'm saying this, but I may actually revert back to a larger pulley after this fueling debacle is all said and done. I swapped on @findingthingsout 's 2.8 pulley and took it for a drive. Wow. This thing pulls notably harder than the 2.3 ever has. I build up freeway speeds scary fast. I don't know if it's a collective of all of my mods I'm running (NST pulleys, cam gears, TRD hybrid intake, and all of the other little things) but oh my god this thing was pulling like a freight train all while making much less whine noise, which I'm not even mad about.
    Anyways... more to come soon after @JustDSM takes a look at the log, but AFR's seemed much happier. Even that weird pause at take off I had going on for some time now is magically gone now.
    Roostfactor likes this.
  10. May 30, 2020 at 6:12 PM
    Darkgoatracer
    Darkgoatracer Well-Known Member
    Nick
    Northern VA
    2012 trd sport tacoma
    Stock
    I feel like i missed something
  11. May 30, 2020 at 6:15 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I am quite curious what the charge air post cooler temps were with your pulley.
    Roostfactor and 12TRDTacoma[OP] like this.
  12. May 30, 2020 at 6:17 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I've been having top end fueling issues due to either mechanical issues (as in I could be potentially spinning the blower too fast for things to be capable of keeping up) or software issues. I have been methodically returning things to as near stock as I can at the current moment and I switched from the 2.3 pulley back a near OE size 2.8 and flashed in a neutered TRD base tune provided by Justin. To see if fueling issues lies due to the blower spinning too fast or if it's the PCM.
    I got an unexpectedly huge bump in power just by switching back..
    Of course that may be due to the fact that the 2.3 tune was running on near zero timing. So..
    I wish I could tell you, but I am also running water wetter and water mix in the intercooler now, so there's that as well.
  13. May 30, 2020 at 6:19 PM
    Norton
  14. May 30, 2020 at 6:26 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I KNOWWW...!
    Hey man, I can't argue with the butt dyno, but the truck has not run this smooth all around in so long, so I really think that it may actually be the way to go.
    Shrink pulleys that need to be shrunk, lighten them, install cam gears for a better burn, install Rutheniums, and open up the intake and exhaust to breathe better. Enable increased throttle values at take off and flash in Habanero Ghost Pepper Carolina Reaper tranny tune and you would be surprised how zippy this thing is now.
    It's surprising how simple the theory behind this modding is.
    I am going to have to refer back to the MP90 efficiency map and get a pulley that brings its RPM range to peak performance after this issue is all over and resolved.. I don't think 2.3 is in the cards for me anymore though. As usual, all of this is pending the word of Justin, but so far I can't argue with the MAD passing power I have right now.
    Norton[QUOTED] likes this.
  15. May 30, 2020 at 6:45 PM
    Darkgoatracer
    Nick
    Northern VA
    Stock
    So a friend of mine had a twin charged ctsv that should have made hella power and didn't. They contributed the low results to cavitation. They remove the supercharger and left the turbo and went from 1200hp to maxing out a 2000hp dyno. Maybe something similar? But like you said to, if you have no advance that could be the problem as well.
  16. May 30, 2020 at 7:05 PM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    Just playing devils advocate ..... @12TRDTacoma
    But i want to recall that one of your impressions of the truck was earlier this week. Maybe it was an update with the new plugs. I remember thinking to myself....wow, it's the hottest day of the year and Roberto said his truck is running great!
    And if its compared to today...and impressions felt today, there was easily a 15-20deg swing in ambient temp between the two days.
    I think it was mid 90s on Monday in Sunnyvale.
    It barely hit 70s today. I'm guessing Concord was similar or not a tad warmer?
    My truck feels noticeably different between that temp variation.
    I'm super curious with the possible cause..
  17. May 30, 2020 at 7:28 PM
    Norton
    That's a good point... cold air = dense air = more boost = more power.
  18. May 30, 2020 at 7:46 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    reason i posted a video. how do our trucks compare? that was rolling start to 80mph in 4th. just trying to give you refeference points.
  19. May 30, 2020 at 7:47 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Dude it was ugly out today. It was hot and raining at the same time today. By all accounts it felt like it does on a Florida day. I remember when I used to run a 2.8 pulley I was seeing boost levels of about 7.5 - 8.5 psi. I was watching my boost levels today while giving the blue turd some juice and I noticed that boost levels actually have dropped to an average of about 6.7 - 7.5 psi. That drop alone tells me that I used to be restricted and I have opened things up so much to the point now where it has made a positive impact on overall power levels.
    It's not weather related, but what may be helping some is the fact that I am also running water wetter and water on the engine coolant side and on the supercharger intercooler now also.
    It really wasn't that cold today, it was about 75 here and on the day where my truck was running awesome it was about 90 out..
    SUMOTNK[QUOTED] likes this.
  20. May 30, 2020 at 7:48 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    my reason for duel meth hoses:thumbsup:
