TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jun 2, 2020 at 10:05 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Roostfactor and Athlaos like this.
  2. Jun 2, 2020 at 10:14 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    It's the fuel pump. 100% without a doubt in my mind.
  3. Jun 2, 2020 at 10:15 PM
    Philis Blue Tacoma
    Philis Blue Tacoma Member
    Trace
    2015 BRM Tacoma Prerunner
    Prinsu roof rack + 30 inch light bar cali raised led ditch lights auxbeam leds in fogs and main custom tail lights 3inch RC Lift paintmatched grille
    Thanks! I ordered it just now.
  4. Jun 2, 2020 at 10:17 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    What you can do in the meantime to make sure fuel demand keeps up to "band aid" it per se is to boost reference the fuel pressure regulator at the fuel rail on the passenger side to the boost port at the rear of the supercharger on the driver's side.
  5. Jun 3, 2020 at 2:58 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Also @Philis Blue Tacoma if that takes care of your issue that is highly indicative of a failing fuel pump that is running out of steam up top.
  6. Jun 3, 2020 at 4:41 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I believe that @JustDSM 's comment was directed towards you. If so, then you should definitely take him up on that offer. He has the resources and knowledge to see and decipher what all is going on from to to mechanical.
  7. Jun 3, 2020 at 10:45 AM
    Philis Blue Tacoma
    Trace
    will this fuel pump install somehow fix my transmission rev spiking before shifting? And the pulling at some random parts of the rev range?
  8. Jun 3, 2020 at 11:00 AM
    Philis Blue Tacoma
    Trace
    I’m going to install the walbro fuel pump first and go from there. I’m not running any AFR or boost gauge and I have no idea how to install that, so I might pick one up and drive down there in the coming week
  9. Jun 3, 2020 at 11:03 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    No. That's a seperate issue which may be software related or transmission shift speed related.
    A lot of us used to have the spiking, but we added our shift kit in there and it went away for most of us. There is potentially a software deal which makes the transmission do that but as of right now I don't know if it was discovered what was causing it.
  10. Jun 3, 2020 at 3:27 PM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
  11. Jun 3, 2020 at 3:50 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    12TRDTacoma[OP] and Athlaos like this.
  12. Jun 3, 2020 at 4:53 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Time for skids?!
    nudavinci64 likes this.
  13. Jun 3, 2020 at 5:37 PM
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    Time for a bath. Truck is filthy. No skids for me. I don’t like buying tires.
    Torspd and loginfailed like this.
  14. Jun 3, 2020 at 7:57 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Slows down acceleration times anyway. :D
    Athlaos likes this.
  15. Jun 4, 2020 at 11:34 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    A record new 14.08 MPG mixed city driving as of before my state activation using the Ruthenium plugs.
    I have never surpassed 232 miles to the tank and these new plugs got me 245 miles to the tank, even when moving all highway (From F mark until the light turned on). I got this new mileage by moving mixed driving like I always do, some city, some highway. I was even WOT boosting every here and there too.
    I'm going to do one more tank after I get back home and report back what my average is. As of right now I'm very pleased with the new plugs. I can't wait to start driving on them some more. :)
    Here is a latest 50-90 MPH pull on the 2.8 pulley. It takes much less time to pull up to speed with it in comparison to what it did with the 2.3. I hit a road bump at the end of the pull.
    https://youtu.be/MxFbqUHXaxM
  16. Jun 4, 2020 at 11:53 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Thats awesome. I hope my Fuel Pump helps. I am getting less than 10 mpg, worse then before the SC project. I knew it could worse but shes drinking fuel like no other. Any other thoughts? I was hoping for at least 12 mpg, 14 mpg would be fantastic.
  17. Jun 4, 2020 at 11:55 AM
    nudavinci64
    Robert
    For the Fuel pump anyone have a link to approved connectors for connecting my fuel pump? I have plenty of connectors just not sure if any are resistent to fuel. AEM 320 pump will be going in. Was hoping to try and tackle it this weekend.
  18. Jun 4, 2020 at 11:58 AM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    I found a pump on marketplace if you want I can link for about $60. You could build and test on this platform then just drop in. I did mine in one night and it was miserable. I was also fabricating mounts and lifting an LRA tank to fit at the same time by myself. Let me know
  19. Jun 4, 2020 at 12:03 PM
    nudavinci64
    Robert
    sure ill check it out. i like the idea of having it all built out then dropping it in when ready rather but in the end it needs to happen.
  20. Jun 4, 2020 at 12:09 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    Here is one in Merced, CA for $50 on the Book of Faces.
    12TRDTacoma[OP] likes this.
