TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jun 4, 2020 at 4:01 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    sure thing. ill know for sure once I get the AFR installed. Even at 80mph which is not all the time since im barely going anywhere. 7 mpg is pretty bad.
  2. Jun 4, 2020 at 4:06 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    a fuel pump and afr gauge i believe are the most important items to install for adequate start to modding. please.....check all your parts BEFORE dropping the tank. i had my kit with me when @crashnburn80 did his. he was shorted 1 electrical connector for the in tank wiring. it was sunday iirc and had i not had one to loan we would have dropped the tank for merely practice.
  3. Jun 4, 2020 at 4:15 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Snorkle! ;)
  4. Jun 4, 2020 at 4:16 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    are you running premium fuel? i found even grocery store premium sucks here. if you have a performance vechicle tuned for it and run low grade you are doing yourself a disservice.
    Roostfactor and TheFang like this.
  5. Jun 4, 2020 at 4:19 PM
    TRON
    I’d clean my MAF sensor and make sure your new injectors are seated properly and not leaking fuel. And swap out my wrafs for new ones @nudavinci64
    Roostfactor likes this.
  6. Jun 4, 2020 at 4:30 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Yeah, that was a lifesaver. I would have just left it off at that point till I got the part rather than calling it practice and dealing with that again.
  7. Jun 4, 2020 at 4:32 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    true. dropping a tank wasnt so bad but disconnecting/reconnecting that top was less than fun.
  8. Jun 4, 2020 at 4:46 PM
    nudavinci64
    Robert
    Yah for sure. Def check parts list is a must. I won't be doing an external filter out of the gate. As long as the instructions note all the correct parts I should be good.I checked the other day and seemed to have all the required parts.
  9. Jun 4, 2020 at 4:47 PM
    nudavinci64
    Robert
    Yah I hear the connection parts i hear are the pain. I def have to go at it from the bottom and drop the tank. Going from the top is not an option.
  10. Jun 4, 2020 at 4:51 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    What's your tire pressure, and is your speedo calibrated to your tire size?
  11. Jun 4, 2020 at 4:54 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Once you get the fuel lines disconnected you’re set. The rest isn’t bad unless you’re like me the first time I did it and had a full tank. But knowing your mpg’s you don’t keep a full tank around too long huh :boink:
    But back on the mpg note, you definitely have something electro-mechanical going on that’s causing the excess fuel consumption. Dirty air filter, plugs, MAF, throttle body, brakes dragging, or a heavy ass foot and lots of hills. (I know you mentioned checking a few of these) The only time I get that bad is when I’m towing, or playing in the dunes/ desert.
  12. Jun 4, 2020 at 5:00 PM
    nudavinci64
    Robert
    30's give or take. Prob at 32 or 34 right now. Yes I have a hypertech inline which has it pretty close to GPS speed.
    I was having some MPG issues before and chalked it up to a bunch of those things. But with the new install of the S/C Air filter, plugs are new, MAF is new due to fj hybrid intake, TB got a deep cleaning during right before and during the install so was hoping for a big improvement because a few of those were toast. Also has new oil, new coolant, some new dif/transfer oil, lubed a few other things. its had a lot of maintenance.
    I have contemplated that the brakes could be dragging in the front. When I was going through this before I thought that could be an issue but was still getting better MPG. It was bad but not this bad. Late last year I swapped in wilwood Aero 6 pistons and did have some back and forth on the adapters with rr-racing. The brakes themselves are pretty much new with only a few thousand at best on them but one idea I was thinking. If the caliper is off center at all would that cause any dragging on the brakes given the pistons do not contact evenly? Not sure that is happening but taking a stab at some things.
  13. Jun 4, 2020 at 5:01 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i know, dcsb means tank drop. btw, walbro 255 is great. it ONLY has an external fuel filter choice. why have an in tank filter when you can do it externally for cheap and quick?
  14. Jun 4, 2020 at 5:02 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    i gained about 2-3 mpg with my canopy. the spare tire on the swing out is a big air brake and with the canopy it negates alot of that problem
  15. Jun 4, 2020 at 5:03 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    lift it and spin the tires to check.
    Roostfactor and Torspd like this.
  16. Jun 4, 2020 at 5:03 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Fuel filter, or injectors. Those are my guesses.
  17. Jun 4, 2020 at 5:04 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    very true. huge air obstruction like a spare may be a parachute for n/a trucks.
    12TRDTacoma[OP] likes this.
  18. Jun 4, 2020 at 5:05 PM
    wrmathis
    Bonaire, GA
    parts and stuff
    it was terrible with a supercharger too
  19. Jun 4, 2020 at 5:06 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    im betting jammed filter. even the best of petrol stations have crap in their tanks.
    Torspd[QUOTED] likes this.
  20. Jun 4, 2020 at 5:07 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i believe you. i so badly want bigger tires but know the sacrifice.
