TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jun 5, 2020 at 5:29 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    That's crazy. A bad bypass will cause rich issues. Just when you think you've seen it all. Some of the boost bypass valves have been known to be bad right out of the box on these Magnusons so you may want to check that @nudavinci64
    mr.trd[QUOTED] likes this.
  2. Jun 5, 2020 at 5:31 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    sounds correct. wont open when under load, over rich, compensating, running poor. worth looking at.
  3. Jun 5, 2020 at 5:35 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Check your PM's for toons!
    When you can, get me a log of aproximately 2-3 min of idle (at operating temp) and a little cruise action. Want to verify your trims.
    Use the latest channels file (attached here)
    mr.trd and DocME like this.
  4. Jun 5, 2020 at 5:37 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah the fact they are white indicates the porcelain is either brand new, or in stellar condition. Nothing to worry about.
    Right, because power enrichment (PE) is occurring based off of pedal input, not supercharger boost valve engagement.
    That's the only problem with these blowers being an add on entirely. The fact that the boost valve is not electronic makes the whole supercharger "dumb" so to speak vs everything else which is PCM controlled.
    mr.trd and EchoLake[QUOTED] like this.
  5. Jun 5, 2020 at 5:41 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    but..as much as that is a PITA we have fellas like @JustDSM .
  6. Jun 5, 2020 at 5:47 PM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    10-4 will do on Monday!!
  7. Jun 5, 2020 at 5:47 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    We still have to do our own investigating from our end regardless though. He is far away so it's not like he can check out stuff for us, only give suggestions.
    He is good man.
  8. Jun 5, 2020 at 5:49 PM
    JustDSM
    Justin
    Ogden, UT
    I couldn't agree with you more here!
    And thank you for the kind words man! That means a lot.
  9. Jun 5, 2020 at 6:02 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Guess I can't complain about my combined mileage of...
    - ~18 MPG on stock N/A tune
    - ~17 MPG on TRD S/C tune
    - ~15 MPG on OVTune S/C 1
    - ~16 MPG on OVTune S/C 2
    - ~15 MPG on OVTune S/C 2 + 2.7" Pulley
    - ~16 MPG on JustDSM S/C + 2.7" Pulley
    - ~16 MPG on JustDSM S/C + Rev Hang Delete + 2.7" Pulley
    - ~17 MPG on JustDSM S/C + Rev Hang Delete + 2.5" Pulley
  10. Jun 5, 2020 at 6:02 PM
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    You mean god? He is more then a man.
  11. Jun 5, 2020 at 6:12 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    possibly if so that works just need to know what it is.
  12. Jun 5, 2020 at 6:19 PM
    nudavinci64
    Robert
    how could I check that? I did adjust the bypass valve prior think it may not be adjusted enough? any sign to look for besides bad mpg?
  13. Jun 5, 2020 at 6:19 PM
    JustDSM
    Justin
    Ogden, UT
    I can't take THAT much credit! But I really do mean it, that I am humbled by the appreciation. I really do try hard for you guys and I truly do hope you all know that.
  14. Jun 5, 2020 at 6:25 PM
    nudavinci64
    Robert
    Ok makes sense. should also be able to tell in my boost gauge? Goes from vacuum to boost easily.
    Roostfactor[QUOTED] likes this.
  15. Jun 5, 2020 at 6:30 PM
    nudavinci64
    Robert
    that would be interesting considering it a bit that old for taco years. Would give me a reason to put my fuel rails in.
    rheath08[QUOTED] likes this.
  16. Jun 5, 2020 at 6:53 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    You tune Tundras? :D
    The Tundra forum is...behind on the times. There’s maybe 1 guy that used HP Tuners and he has maybe 5 posts. Everyone else is still buying bully dog or OVTune.
  17. Jun 5, 2020 at 7:19 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    He did the wife’s 4Runner. I’m sure a tundra could be in his wheel house
    Kelvin[QUOTED] likes this.
  18. Jun 5, 2020 at 7:38 PM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Hard side first.
    Because... I’m just a sucker for pain
    mr.trd, Roostfactor, SUMOTNK and 3 others like this.
  19. Jun 5, 2020 at 7:44 PM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    I felt like I had carpel tunnel for a month after I did that.
  20. Jun 5, 2020 at 7:45 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    some folks eat crayons until they buy steak too.
