TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jun 6, 2020 at 4:57 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    this was not a blind test. It was something I had thought about prior to the S/C after I installed the front brakes. Bypass valve seems fine. I get vacuum and boost etc at least seems to doing its job.
  2. Jun 6, 2020 at 5:05 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    im betting its a mechanical issue. if the computer could sense it wouldnt it be simple for @JustDSM to see?
  3. Jun 6, 2020 at 5:05 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    sexy!
    JuanitoBonito[QUOTED] likes this.
  4. Jun 6, 2020 at 5:07 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    get a thermal laser tester. find a local fella with a truck. follow each other for 5min and pull over to compare caliper temps. just an idea.
    12TRDTacoma[OP] and Torspd like this.
  5. Jun 6, 2020 at 5:13 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    His logs don’t show anything outside the norm.
    He’s got the same baseline tune that @Murphinator And others rocks with success. The injectors are scaled in line with @TRON values, as he was the one who proofed the 2D mapping values for the strategy used in our ECU. The intake data is OEM Toyota FJ.
    Long story short, there’s nothing in the tune. My suggestion as it is for most folks is to go back to as close to stock as reasonably possible and eliminate as many variables as possible to aide in troubleshooting and isolation of the “problem”. @12TRDTacoma knows my method ;)
  6. Jun 6, 2020 at 5:24 PM
    nudavinci64
    Robert
    I agree with the method. after driving @SUMOTNK truck aside from other things it seemed to have less drag so was looking into brakes which I had some ideas before. I’ll dig out those injectors and we can start from there.
    SUMOTNK and JustDSM[QUOTED] like this.
  7. Jun 6, 2020 at 5:36 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    get side by side with a tacoma going the same speed. let off the gas and see if there is noticable difference in deceleration.
  8. Jun 6, 2020 at 6:27 PM
    nudavinci64
    Robert
    Good point. figured would be easy to rule out brakes.
  9. Jun 6, 2020 at 7:01 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    unless, same gear ratio and tires then not a good measure. Traditionally wilwoods require adjustments, ut not sure of the aero models.
  10. Jun 6, 2020 at 7:37 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i was just spitballin'. see if a similar truck does much better.
  11. Jun 6, 2020 at 7:40 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    my thought was if something was drastcally wrong a somewhat similar measure would work for feedback.
  12. Jun 6, 2020 at 8:14 PM
    nudavinci64
    Robert
    What type of adjustments have you seen?
  13. Jun 6, 2020 at 8:22 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Not necessarily. He has A LOT of information available, but it's not always going to tell him if something is immediately wrong. Even me when diagnosing, often computer data is immediately great reference, but it serves only as a starting reference point and physical testing still is required.
    @nudavinci64 before you go pulling stuff off those tests I mentioned earlier re quick and dirty.
    https://youtu.be/cHghZfrfEbQ
  14. Jun 6, 2020 at 8:56 PM
    nudavinci64
    Robert
    Is there a way to do that test without pulling the blower off? thanks for the video. def an easy test with it off. How much boost should I expect on the 2.8 in general not considering all the other stuff?
  15. Jun 6, 2020 at 9:07 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Expecting to see boost doesn't tell the whole story sometimes. You could be hitting 8.5 or you may see an average of about 6.8- 7.3 like I am, but if you are leaking it out under boost you may not see that.
    You can check it when you start up the truck. You will see the arm move once it gets into idle. Have someone start the truck while you are hanging over the blower physically looking at it. If it doesn't do that you got an issue going on in the valve. If you have someone rev it up to intentionally make it boost while at idle you should be able to see the valve move as well. A vacuum test like what you saw in the video should be the next test if it looks okay with those tests.
    You can do it by pulling the hose off and sucking on it while you check what you need to. That boost valve is typical to GM and Ford but ours only has one nipple as to theirs has two. The method is similar in testing in theory though.. so.
  16. Jun 6, 2020 at 10:15 PM
    nudavinci64
    Robert
    Ok just wanted to get an idea. I am hitting a solid 8 at peak boost right now. ill see if the wife will help me run that test.
  17. Jun 7, 2020 at 6:07 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    pushrod, pedal, proportioning valve. But you may not have messed with any of that. There is an adjusting tips section on their website IIRC
  18. Jun 7, 2020 at 8:23 AM
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    Keep me posted as to what you like and don't like about the Kenda's. They are 1 of 2 tires that come in 35x10.50R17. And I don't want a 12.50 wide. But do want 35's.
  19. Jun 7, 2020 at 8:25 AM
    nudavinci64
    Robert
    @SUMOTNK also has them. only drove it for a short time yesterday but the truck felt good.
    mr.trd[QUOTED] likes this.
  20. Jun 7, 2020 at 8:44 AM
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Thanks, also when you test the bypass. We only have one nipple, but you will see that even with the old one he says is good on the one side, I would say it is not. Watch how far the rod goes before it does stop and hold. That is the difference mine had. The old one let out a long ways and then did hold about 5mm from the end of the stroke. The new one let out about 5mm and then held. Not knowing how it is built on the inside but I feel like there are layers of the diaphragm and the old one would hold just a bit after the layers sealed themselves or something. But the new one held at a much higher level. I can go take a video or pictures to show you as well. Except I don't have the new one to show the difference.
    12TRDTacoma[OP] and SUMOTNK like this.
