TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jun 9, 2020 at 10:24 PM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    I think water/meth will alter the efficiency island in our favor though.
  2. Jun 9, 2020 at 11:36 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    i know right? I have a maggie and trd sticker for kick so no need on my end but that would be a far fetched way to try and sneak it by.
  3. Jun 10, 2020 at 8:59 AM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Hmm I always thought the green values are blower RPM.
    12TRDTacoma[OP] and JustDSM like this.
  4. Jun 10, 2020 at 9:03 AM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Can I fit an M90 blower on my Goldwing? That would be fun!
  5. Jun 10, 2020 at 9:04 AM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    WITH ENOUGH TIME AND MONEY..LOL
    loginfailed likes this.
  6. Jun 10, 2020 at 9:09 AM
    Jpiskura
    Jpiskura Well-Known Member
    Stick it to the sheets
  7. Jun 10, 2020 at 9:42 AM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    (6.5 crank / 3.0” blower) * 5600 RPM
    = 12,133 blower speed
    (6.5” crank / 2.8” blower) * 5600 RPM
    = 13,000 blower speed
    (6.5 crank / 2.7” blower) * 5600 RPM
    = 13,481 blower speed
    (6.5 crank / 2.5” blower) * 5600 RPM
    = 15,560 blower speed
    (6.5 crank / 2.3 blower) * 5600 RPM
    = 15,826 blower speed
    Where does the stock 1GR make the most power? Seems like we’d want to land blower speed in the middle of the darkest efficiency island somewhere around where the engine itself is making the most power.
  8. Jun 10, 2020 at 10:09 AM
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    In the name of bolt-on, set it and forget it power, the 2.8-2.85" pulleys are about what we can get away with. Especially since you have to snout cut to go smaller. Sounds like TRD went with 3.0" for a little extra margin of safety.
  9. Jun 10, 2020 at 10:13 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    You are right. I misread, so frago to my frago. Lol.
    This is why I hate it when I get second guessed because then I get screwed up.
    I deleted the latest post and left the original.
    Do me a favor and edit or delete your last post to exclude what you quoted me on that way nobody reads it and gets the wrong info from it.
    Roostfactor[QUOTED] likes this.
  10. Jun 10, 2020 at 10:18 AM
    Roostfactor
    TX panhandle
    Done
  11. Jun 10, 2020 at 10:26 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Thanks brother. Now I gotta go buy a brand new K050705RPM belt later. Napa here I come!
    I ran a log for Justin the other day on my way in to report and I forgot to hook up the intercooler after my base reflash so I sent him a bad log. Despite that he said the log looked so much cleaner than previous versions so that tells me that the larger pulleys while allowing the blower to breathe to get into target PSI ranges is the way to go. The chart definitely confirms that. :thumbsup:
    I may wind up coming out to TX sooner than expected so I'll keep you updated as that changes.
  12. Jun 10, 2020 at 10:36 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The 1GR is a mid to high range power maker in OE configuration. Obviously once you start making the exhaust too large or change its routing in a way where the equality of both lengths of runners into the Y do not favor the 120* it is optimized for, the powerband range will move lower (correct me if I'm wrong). Cam gears also alter the power band at 2500 RPM powerband kick in vs. the 3000- 3200 range it starts at in OE configuration.
    Let's figure this one out together my mad scientists!
  13. Jun 10, 2020 at 10:37 AM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I'm due for a pulley replacement. Mine is old and crusty.
  14. Jun 10, 2020 at 10:40 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Oh yeah, I saw that. Time to go larger, or go E85. Hahaha.
  15. Jun 10, 2020 at 10:45 AM
    EchoLake
    EchoLake Well-Known Member
    Sacramento
    '15 MGM TRD OR AC 6MT
    Magnuson Supercharger, Speedhut AFR and Boost Gauges, TRD ECU Reflash, Factory Nav Unit, TRD Skidplate, VIP alarm, 265/75R16 Cooper Discoverer ATP, 1" KSP Spacers, hub centric (hold comments lol), TRD Pro Grill, Raptor Lights on with ignition. Upcoming - purchased, not yet installed: Body matched rear bumper (rattle can), Kicker Hideaway, JL Audio 6x9 components w/80Hz Bass Blockers, Hellwig anti-roll bar, TRD Short Shifter, Knock-off TRD Shifter (non-Qball), black throwback plates. Plans: more.
    I'm finally getting around to replacing the hose.
    I noticed the coolant in the radiator is pretty brown and not opaque at all, see below.
    Truck has less than 40k on it and has had all services. Never checked the coolant color before, reservoir always had plenty in it and it was nice and clear pink.
    A couple questions. Is this normal for a truck of this age, and should the installer have done a flush?
    I am going to replace it for sure.
  16. Jun 10, 2020 at 10:50 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You're fine. Just drain as much as you can, run water through it and do it again if you want. Then once most of the water/ coolant mix has appeared to look more like water, replace with coolant and you're good to go.
    BassAckwards likes this.
  17. Jun 10, 2020 at 10:56 AM
    EchoLake
    Sacramento
    Right on man, thank you. Will do.
  18. Jun 10, 2020 at 10:57 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Updated in page 1.
    BassAckwards[QUOTED] likes this.
  19. Jun 10, 2020 at 11:08 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    :thumbsup:
  20. Jun 10, 2020 at 11:10 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    General pulley update for page 1 as well in the qwikchange section.
