TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jun 11, 2020 at 10:32 AM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Just out of curiosity in what type of area did you go to get the smog done? I have had some luck going to say a rougher area, they are a bit more forgiving when it comes to their visual inspection.
    SUMOTNK likes this.
  2. Jun 11, 2020 at 10:33 AM
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    SW Bakersfield. Smog tech row essentially off of White Lane.
    rheath08 likes this.
  3. Jun 11, 2020 at 10:34 AM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    LMAO!! NEIGHBOR!
  4. Jun 11, 2020 at 10:44 AM
    Voodoo Rufus
    Bakersfield, CA
    Yes indeed!
  5. Jun 11, 2020 at 11:16 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    All these posts above...
    My point put to rest. California is incredibly strict on their state inspections therefore it is critical to be compliant to the T when you roll in to their shop if you want to pass.
  6. Jun 11, 2020 at 11:24 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Thanks for adding this to the OP, but it wasn't me that dug up this part number. I believe it was @mr.trd and @BillDaCat8 that posted this info.
  7. Jun 11, 2020 at 2:45 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Join the Club! For header JBA with stock cats is the only options for later 2nd gen or early you also have Dough T shorties.
    For Y pipe no good options but opening it up in places or what has been the common is have a catless Y pipe and swap the stock back on every 2 years when you need to smog it.
    - Robert
  8. Jun 11, 2020 at 4:57 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Have you cruised at 100+? Ultragauge says I’m doing bad things.
    loginfailed[QUOTED] likes this.
  9. Jun 11, 2020 at 5:08 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Got to increase those warnings limits. ;)
    Lucario Runner likes this.
  10. Jun 11, 2020 at 5:11 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Yes.
    Just not in the Tacoma.
    mr.trd, Roostfactor, henryp and 5 others like this.
  11. Jun 11, 2020 at 5:14 PM
    ThomasMore66
    In the Tacoma silly.
    Norton[QUOTED] likes this.
  12. Jun 11, 2020 at 5:15 PM
    ThomasMore66
    Had a guy in a 3rd gen want to hang a couple days ago. I still wonder what he was thinking as I drove out of his life.
    rj_taco, mr.trd, Roostfactor and 5 others like this.
  13. Jun 11, 2020 at 5:18 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    I been at texas speeds in my taco. Love the hptuners support. ;)
    Roostfactor and nudavinci64 like this.
  14. Jun 11, 2020 at 5:19 PM
    Norton
    LOL! I figured, but I'm enjoying the C7Z PDR, especially now that I'm past the break-in miles and have use of the full RPM range, and I never drive the Tacoma that hard.
    mr.trd and Lucario Runner like this.
  15. Jun 11, 2020 at 5:27 PM
    ThomasMore66
    Drive what you have. I do drive the Tacoma hard sometimes. Speed limiter delete... KO2’s hum loudly.
  16. Jun 11, 2020 at 6:34 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    They get even taller and skinnier!
    Anderson likes this.
  17. Jun 11, 2020 at 7:20 PM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    km/h
    Roostfactor and BassAckwards like this.
  18. Jun 11, 2020 at 8:21 PM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    I agree. We shouldn't be encouraging the people new to this thread to be going UP in pulley size under the pretense that they'll get more out of their truck.
    That line of thinking is frankly dangerous, and will start us on a very dark path.
  19. Jun 11, 2020 at 9:24 PM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Is this the correct product from smoothflow?
  20. Jun 11, 2020 at 9:40 PM
    nudavinci64
    Robert
    n
    what app is that?
