TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jun 11, 2020 at 9:42 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    agree there based on this thread I am all in on going to a 2.5 out of the gate but on vacation with a 2.8 at the moment.
    Athlaos[QUOTED] likes this.
  2. Jun 11, 2020 at 9:49 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Wait, warning limits?
  3. Jun 11, 2020 at 10:46 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Don't be mad when I blow the doors off you with my 2.8 pulley with your loud non meth injected 2.3 pulley on the track.
    It's all about efficiency boys. I want you guys to understand that, as funny as the jokes are about the larger pulleys, it's all about staying in the proper zone and the smaller pulleys take you out of that zone.
    Torspd likes this.
  4. Jun 11, 2020 at 11:25 PM
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    Mmm kayyyy
  5. Jun 11, 2020 at 11:27 PM
    BillDaCat8
    Jake
    PHX
    Just had to
  6. Jun 12, 2020 at 4:01 AM
    Darkgoatracer
    Darkgoatracer Well-Known Member
    Nick
    Northern VA
    2012 trd sport tacoma
    Stock
    @loginfailed i emailed nate at smoothflow and he knew exactly what to send. I believe their is a hub unique to our truck that he makes with the correct offset.
    Roostfactor and Torspd like this.
  7. Jun 12, 2020 at 5:09 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    On the ultragauge, there are warning limits for all sorts of readings, and sensors. They are also adjustable and silenceable.
    For example, I have my coolant temp warning set to 216°F if it alarms, then I start monitoring it. My IAT is set to 160°F.
    Speed can be set to whatever as well, but comes preset I think.
    Roostfactor likes this.
  8. Jun 12, 2020 at 5:11 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Ready, set, :fistbump: :burp:
  9. Jun 12, 2020 at 5:14 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    This is pretty cool. Watch the sidewall.
    https://youtu.be/zoHcr7dj-bI
  10. Jun 12, 2020 at 5:40 AM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    who is non meth injected hahaha go big or go home!!
    Athlaos likes this.
  11. Jun 12, 2020 at 7:12 AM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    I have watched motorcycles get dyno'd, it it scary to think the rear tire is growing like that under you.
    Torspd[QUOTED] likes this.
  12. Jun 12, 2020 at 7:20 AM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I ordered one, but didn’t know the offset is different. I’ll have to call/email and confirm.
  13. Jun 12, 2020 at 7:21 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That sidewall ripple. Imagine that while going down the road, and changing lanes. Better yet, don't think about it. Lol.
    If you want to do the speed calculations, 35" KO2, with OEM gearing. 4th gear pull to redline.
    I miss being lifted some times. :pout:
    mr.trd likes this.
  14. Jun 12, 2020 at 7:45 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    I don’t like being low to the ground. I hit things.
    mr.trd likes this.
  15. Jun 12, 2020 at 7:53 AM
    Darkgoatracer
    Nick
    Northern VA
    Stock
    Cool. He's super helpful. When i ordered mine he told me he changed the offset per the guidance of someone off the forum. He'll get you squared away.
  16. Jun 12, 2020 at 8:04 AM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    This is how I have felt all along. Whether you want to call it efficiency or reliability. I obviously didn’t have the knowledge on paper to back it up. However, knowing mechanically how things work in that the smaller you go creates more heat, presumably shortens the lifespan due to wear, and overall just leaves you vulnerable to more issues. I have believed going a little smaller was/is safe due to the rich TRD tune and now hp/ovtune but over doing it would just be skating on thin ice so to speak. 2.7 has felt great. It does everything I need, is efficient I believe and definitely keeps it reliable.
  17. Jun 12, 2020 at 8:09 AM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Dam, I can't ever keep up with ya'll on this page. I will say that I swapped back to a 2.6 from the 2.3. Might have lost some responsiveness but feels the same when stepping on it to redline. Datalogs seemed to show a little less air being moved but maybe it being colder air negates that there is less of it. Need to comb over the data logs if I ever find the time.
  18. Jun 12, 2020 at 8:23 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It takes me approximately 10 seconds to get from 50-90 mph with the 2.8 pulley.
    It takes me 10 seconds to make it from 60-90 mph with the 2.3 pulley.
    For those who don't believe me you can check my recent prior video postings, but 10 mph gained and lost is quite a bit of a difference.
  19. Jun 12, 2020 at 8:52 AM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    That would be me. I sent him pics and measurements so the hub will be flush and aligned with the idler pulleys. :thumbsup:
  20. Jun 12, 2020 at 8:53 AM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    I think we all need to calm the larger pulley talk down for a minute. There is a huge difference between someone running full cats and someone running catless. Also, you need to consider the operating range in relation to the efficiency chart. How much driving do you do at above 5,500 rpm?
    Once @12TRDTacoma figures out how to add them long tube equal lengths into the equation we're going to be back down in 2.3 town. If you're going keep the stock manifolds, then I think you're on the right track for you.
    For everyone, design how you're going to use and operate the vehicle. Keep in mind the RPM band you use regularly and target that. Don't get caught up in peak HP figures.
