TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jun 13, 2020 at 9:06 PM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    None, if you're this guy! :D
  2. Jun 13, 2020 at 9:24 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Does anyone know if pulling the fuel c/opn relay and cranking the truck over like you would for a compression test is a good way to prime the oil system for initial start up?
  3. Jun 13, 2020 at 9:28 PM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    Pull the spark plugs to remove the load while cranking and yes. As long as that relay kills the fuel pump.
  4. Jun 13, 2020 at 10:28 PM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    Oil will start flowing immediately when you start the engine, no need to prime it Imo. You'd just be cranking the engine over with little to no oil flow in your attempt to prime it.
    Unless I misunderstood what the purpose of priming it is, in this case.
  5. Jun 13, 2020 at 10:32 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Pull the fuel pump relay in the underhood junction block?
  6. Jun 14, 2020 at 4:59 AM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Pull plugs and disable fuel pump.
    It is true that the oil flows as soon as the engine is running
    BUT
    There are two benefits no plugs, no fuel that are often overlooked.
    1) when turning the engine with starter but no plugs or fuel, there is no stress or heat on components from combustion. So there is very little wear during this time.
    2) turning the engine with the starter and no compression actually turns the engine faster. So the oil primes quicker.
    So no combustion load and faster priming.
    As a side note, I’ve seen guys doing compression tests with fuel system still active. Big NO NO! You don’t want fuel spraying in the combustion chambers. This creates unnecessary wear because there is no lubrication on the cylinder wall due to the unburned fuel washing down the cylinder walls.
  7. Jun 14, 2020 at 7:38 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    2.5 its acually plenty. most houses are less than 1/3 acre. im due west of seattle by 30 minite ferry ride and 30 min commute.
  8. Jun 14, 2020 at 7:50 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Pull the fuel pump relay. If you have no oil pressure gauge, then crank until the tin man oil light goes out. Pop in relay. Good to go.
  9. Jun 14, 2020 at 7:51 AM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    That’s cool man. And yeah 2.5 is plenty. I’m on an acre.....I wish I had another 1.5, that’d be tits.
  10. Jun 14, 2020 at 7:54 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Going with this, we don't know if it is a used engine, or a freshly built engine with assembly lube. Freshly built will have better clearances protections. Either case will benefit from the lack of spark plugs. Less load on the battery as well, if doing extended cranking due to the system being "empty ".
    loginfailed[QUOTED] likes this.
  11. Jun 14, 2020 at 9:02 AM
    rheath08
    Russell
    Bakersfield, CA
    pulling the plugs and killing the fuel system is the proper way stated by bmw when we put in new engine for do major internal work. we crank it that way for 10 seconds and let it rest for 30 seconds, 3-4 times. that way you dont over heat the starter. but yes i know. that is the germans though. :rofl:
  12. Jun 14, 2020 at 9:34 AM
    BassAckwards
    Thanks for the info gents! This is a used motor, just wanted to make sure I do the right thing before initial start up
  13. Jun 14, 2020 at 10:36 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    On a used engine, I with possibly "dry" cylinders, I have sprayed wd-40 in each spark plug hole. Leaving the plugs out. Helps prevent dry starts. Crank with plugs out.
    BassAckwards likes this.
  14. Jun 14, 2020 at 11:49 AM
    BassAckwards
    Would PB blaster be alright in lieu of Wd-40
  15. Jun 14, 2020 at 11:52 AM
    EchoLake
    EchoLake Well-Known Member
    Sacramento
    '15 MGM TRD OR AC 6MT
    Magnuson Supercharger, Speedhut AFR and Boost Gauges, TRD ECU Reflash, Factory Nav Unit, TRD Skidplate, VIP alarm, 265/75R16 Cooper Discoverer ATP, 1" KSP Spacers, hub centric (hold comments lol), TRD Pro Grill, Raptor Lights on with ignition. Upcoming - purchased, not yet installed: Body matched rear bumper (rattle can), Kicker Hideaway, JL Audio 6x9 components w/80Hz Bass Blockers, Hellwig anti-roll bar, TRD Short Shifter, Knock-off TRD Shifter (non-Qball), black throwback plates. Plans: more.
    IMG_20200614_114548.jpg Just curious, what is this little guy?
  16. Jun 14, 2020 at 11:54 AM
    BassAckwards
    That's the stud that held on the stock v6 engine cover
  17. Jun 14, 2020 at 12:05 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    no wonder i had no idea. he who discards all stock parts.
  18. Jun 14, 2020 at 1:18 PM
    EchoLake
    Sacramento
    Ah, thank you.
  19. Jun 14, 2020 at 3:01 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Any of you fine truck wizards rebuild shocks specifically king bypass? Reworking one of the bypass tubes and need to confirm they sent all the right parts. Online is generic and the parts are not exact for each shock. I’ll try some other threads but you guys usually cut out the BS.
  20. Jun 14, 2020 at 3:07 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    I have, what are you “reworking” on the bypass valve?
    Anderson likes this.
