TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Apr 11, 2018 at 7:54 PM
    #2901
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I'm under the hood so much I just check:) I could always switch and use the washer tank. I believe it does have a low level sensor.
    Roostfactor likes this.
  2. Apr 11, 2018 at 7:56 PM
    #2902
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I'm experimenting now. Meaning turning knobs and flooring the truck more so not an accurate average yet. Probably a gallon per tank of gas.
    Roostfactor[QUOTED] and oni06 like this.
  3. Apr 11, 2018 at 7:57 PM
    #2903
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I'm getting gauges next. That's another grand:/
    Konvict KROG and oni06 like this.
  4. Apr 11, 2018 at 8:38 PM
    #2904
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    What are you getting diamond laced gauges or what?
    Speedhut boost/vac gauge https://www.speedhut.com/gauge/GR-BOOST-07/1/Boost-Vac-Gauge-30inhg-0-15psi-(w--warning) $170
    Innovate Motorsports DLG-1 dual afr gauge http://www.innovatemotorsports.com/products/dlg1.php
    $340 but can be found cheaper.
    $60-$110 for gauge mount of your choice, pillar or column.
    O2 bongs and possibly welding charge $50
    $600-$650 and your in there!
    GT7 and oni06 like this.
  5. Apr 11, 2018 at 8:48 PM
    #2905
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    O2 bongs are refreshing!
    deeezy, BenMara, Biscuits and 4 others like this.
  6. Apr 11, 2018 at 8:51 PM
    #2906
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  7. Apr 11, 2018 at 9:13 PM
    #2907
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    :rasta:
  8. Apr 11, 2018 at 9:15 PM
    #2908
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Thanks for the set up advice. My guess was high. I was also including temp, fuel, and oil with related fittings. I want a boost and afr gauge 1st.
    Roostfactor[QUOTED] likes this.
  9. Apr 11, 2018 at 9:16 PM
    #2909
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Yes, two more years and I can once more!
  10. Apr 11, 2018 at 9:18 PM
    #2910
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Is a dual bong afr the way to go? I was planning on a single. Feedback welcomed.
  11. Apr 11, 2018 at 9:25 PM
    #2911
    Roostfactor
    TX panhandle
    Single works fine if you dont have cats and put it at the merge collector. A dual gauge let's you see double the resolution since you can see what each bank of cylinders are doing.
    Ideally reading each cylinder would be best but probably overkill for our application.
  12. Apr 11, 2018 at 9:32 PM
    #2912
    Roostfactor
    TX panhandle
    Oh yes, keeps you awake to enjoy the buzz!
    :thumbsup::rofl::thumbsup: Where do you find this shit? I think you have a collection of about 1,000,000,000 pics you can just pull out on command.
    :cheers:
    I retire 1 Jan 19! At least from my 1st career.
  13. Apr 11, 2018 at 9:40 PM
    #2913
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    At 30K I would check the PCV valve. It sounds like it may be faulty and allowing too much oil to get through.
    This is the tank I run on mine.
    Water/ meth injection is not an issue with the rotors. It happened to a bad batch of coated rotors once a long time ago and the horror stories continued to follow after, but the stories were no longer true, so it became more urban legend than anything.
    I mean, I really don't think it can get THAT hot though. Besides, with over 75% more capacity over stock capacity, I think if anything the amount of reserve coolant getting run through the system is more than overkill. My blower is just a happy camper no matter how hard I beat on it.
  14. Apr 11, 2018 at 9:50 PM
    #2914
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I thought about the cooling ability of using annealed aluminum tubing for the supercharger lines. Some small section(s) of silicone tube connections for removal. Less to leak, more surface area to dissipate heat. I might be overthinking things. But I have seen wear marks on the hoses in places.
  15. Apr 11, 2018 at 10:08 PM
    #2915
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It would be a lot of work, but not impossible. I have seen the hosing wearing from rubbing in certain spots as well so I have used all the looming provided with the kit in all the potential wear spots to prevent further issues, and since the hosing in the system never buipds up pressure, only provides the ability for the coolant to run through the system, bursting will never be an issue.
    If there was pressure, I would be very concerned.
  16. Apr 11, 2018 at 10:17 PM
    #2916
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Yes, I thought of the pressure not being an issue. Last I looked it's like 30 bucks and it's enough to do two trucks. I figured it to be around 350 square inches of surface area on the pipe. Rubber covered in loom can't be near the same for cooling. With some large diameter PVC or a conduit bender I figured I could make something one of a kind and functional.
  17. Apr 12, 2018 at 12:47 AM
    #2917
    Konvict KROG
    Konvict KROG Live Free or Die Trying
    Louisiana
    Old Toyota's, Power Wagon, and a Tacoma
    Traded the 2015 TRD Pro 6spd Supercharged on a PowerWagon and could not be happier. My 2011 Tacoma with the TX Baja package (Added by me) is still treating me great. My 1985 Toyota never skips a beat.
    Good to know! I would have done it a long time ago, if not for fear of the rotors.
    And I bought the catch can for the pcv loop something like 2 years ago. Truck has spent half of that time sitting while I worked.
    Anybody know what the under hood temps are like? I could see that actually recuding the efficiency of the system. On my 2013 Toyota replaced the broken A/C line (which is aluminum) heading into the cab. The one that came on the truck was insulated the whole length, and the one the put on was only half length.
    Long story short, unless at highway speeds the A/C suffered greatly, I hooked up the manifolds and checked the pressures etc but the only change was that line being non insulated vs insulated before.
    So in the intercooler loopn the LTR sees fresh air temps, and all the lines (or most) are in the engine compartment. In my biased thinking the lines could raise the temp back up, depending on how well the LTR cools. If that is not the case, how about using PEX or similar hard/formable plastic line for insulating properties and throwing a larger LTR in? If increased capacity is needed.
  18. Apr 12, 2018 at 8:26 AM
    #2918
    Roostfactor
    TX panhandle
    Anybody know what the under hood temps are like? I could see that actually reducing the efficiency of the system. On my 2013 Toyota replaced the broken A/C line (which is aluminum) heading into the cab. The one that came on the truck was insulated the whole length, and the one the put on was only half length.
    So in the intercooler loopn the LTR sees fresh air temps, and all the lines (or most) are in the engine compartment. In my biased thinking the lines could raise the temp back up, depending on how well the LTR cools. If that is not the case, how about using PEX or similar hard/formable plastic line for insulating properties and throwing a larger LTR in? If increased capacity is needed.[/QUOTE]
    This^
  19. Apr 12, 2018 at 8:33 AM
    #2919
    ThomasMore66
    Dallas/Fort Worth & Durango
    oni06, Roostfactor and JuanitoBonito like this.
  20. Apr 12, 2018 at 8:33 AM
    #2920
    ThomasMore66
