TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Apr 12, 2018 at 6:29 PM
    #2941
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    I agree my friend. Certain parts are now engineered to last the length of the warranty period. It's all about profits and staying in business. I still have a belief that most Japanese are better than others though.
    Who do you work for if you dont mind me asking?
  2. Apr 12, 2018 at 6:30 PM
    #2942
    Roostfactor
    TX panhandle
    Not for you! You have your own TIG! :fistbump: :D
  3. Apr 12, 2018 at 6:32 PM
    #2943
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Just finished TIG'ing up a portion of my aluminum axle back exhaust. :D
    Made the downpipe Tuesday evening too. :spy:
  4. Apr 12, 2018 at 6:43 PM
    #2944
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I don’t have a TIG. Make me things :D
    I already have a reservoir being modified to fit in the factory location. It’s being made by someone who only wants to make two.
    I can come up with something though.
    You know? If you get bored.
  5. Apr 12, 2018 at 6:45 PM
    #2945
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    That’s just silly. Superchargers don’t have downpipes :boink:
  6. Apr 12, 2018 at 6:46 PM
    #2946
    ThomasMore66
    Dallas/Fort Worth & Durango
    Was I supposed to call you today or were you going to call me? We talked late from the airport yesterday.
  7. Apr 12, 2018 at 6:49 PM
    #2947
    ThomasMore66
    Thank you. I’m certain I’m not the only one or they wouldn’t make them. It is Al. Bolts right in. Plastic sucks.
  8. Apr 12, 2018 at 6:49 PM
    #2948
    Roostfactor
    TX panhandle
    Reservoir for what? What you want made?
  9. Apr 12, 2018 at 6:52 PM
    #2949
    Roostfactor
    TX panhandle
    You know I'm just giving you :crapstorm:right TM?
  10. Apr 12, 2018 at 6:53 PM
    #2950
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Supercharger Coolant reservoir.
    Hmmm...
    What DO I want made?
    Let me ponder this :D
    Roostfactor[QUOTED] likes this.
  11. Apr 12, 2018 at 6:53 PM
    #2951
    ThomasMore66
    I know. And it was stupid expensive. And it was the best answer I had. I tried to get @Coupe to make one but he’s out of that business now.
  12. Apr 12, 2018 at 6:54 PM
    #2952
    ThomasMore66
    A big strap on?
  13. Apr 12, 2018 at 6:54 PM
    #2953
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    EDIT:
    I’ll put that on the short list.
    Roostfactor likes this.
  14. Apr 12, 2018 at 7:04 PM
    #2954
    ThomasMore66
    Lol.
  15. Apr 12, 2018 at 7:18 PM
    #2955
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Ones working in concert with a turbo do. :boink::smokertransformer:
  16. Apr 12, 2018 at 7:19 PM
    #2956
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    A sweet symphony, I’m sure.
  17. Apr 12, 2018 at 8:24 PM
    #2957
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
  18. Apr 12, 2018 at 9:05 PM
    #2958
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Back in the business then?
    oni06 and Roostfactor like this.
  19. Apr 12, 2018 at 10:32 PM
    #2959
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    This is exactly what I tell a lot of people when I am talking to them about their cars. There is also the pressing problem that people want more, more, more out of a vehicle (they expect it really) for the same price as standard. If you add tons of bells and whistles, something will break. The more computers and sensors you got, the easier something will break.
    I do agree, Japanese cars are still the better, of course there is still the throwaway Japanese brand (Nissan) which are definitely designed to last just past the warranty period before they leak and get full of electrical quirks and bugs.
    I work at an independent automotive repair shop. Nothing special, but we do take pride in the work we do and do everything we can to ensure the quality of the parts and the level of repairs exceed ours and the customers expectations.
    Roostfactor[QUOTED] and GT7 like this.
  20. Apr 13, 2018 at 4:09 AM
    #2960
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    I like the temperature sending unit....damn good idea
