TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jun 30, 2020 at 5:17 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Extremely low risk ;)
  2. Jun 30, 2020 at 5:19 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    So if you take off the intake to swap the plugs, you can reuse the gaskets?
  3. Jun 30, 2020 at 5:34 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    i have.
  4. Jun 30, 2020 at 5:36 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I have for the last 122,000 miles. :) Lol.
    They are rubber Juanito (well, some form of rubber) they should usually be okay.
    JuanitoBonito[QUOTED] likes this.
  5. Jun 30, 2020 at 5:53 PM
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    I reused the ones on mine a few weeks ago when I did plugs. No leaks. I do however have a new lid gasket ready to go if I need it tho. Cheap-ish insurance.
    Upon reassembly, the orange foamy seal for the intercooler needed to be cleaned and reattached to the intercooler. I wiped it with a rag that’d been sprayed with brake cleaner until it was clean enough to be FIPG’d to the intercooler. Just smeared a thin layer and stuck it in place then bolted the lid on.
  6. Jun 30, 2020 at 5:56 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    That’s a good idea
  7. Jun 30, 2020 at 7:50 PM
    TRON
    Yes 100% I have over 10 years with the TRD SC. No problems with the intake manifold gasket or innercooler lid by any means. And I’ve taken my blower off more than most peeps. However, the innercooler foam sealer will break down eventually. Just a matter of time whether you maintenance it or not.
    12TRDTacoma[OP] likes this.
  8. Jun 30, 2020 at 8:05 PM
    TRON
    And this... Everybody should be cleaning the innercooler every 30k regardless if you got a catch can. Just sayin :cool:
  9. Jun 30, 2020 at 8:14 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    meth users too. i have a catch can but use brake cleaner annually on the i/c just to keep it at its best.
  10. Jun 30, 2020 at 8:14 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i do
  11. Jun 30, 2020 at 8:14 PM
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    Now i really need to do my Plugs... what post talks about the SCer removal?
  12. Jun 30, 2020 at 8:26 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That thing gets pretty darn oil soaked... I strongly agree with this. The lid is easy enough to take off anyways so screw it, why not?
  13. Jun 30, 2020 at 8:35 PM
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    I havent opened mine since installed 100k miles ago... :(
  14. Jun 30, 2020 at 8:41 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    How’re you gents cleaning your intercoolers? What products?
  15. Jun 30, 2020 at 9:33 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    My plugs had something like 50k. When replacing them some of the electrodes were nearly completely gone. So at 100k, yes, definitely.
    BenMara[QUOTED] and Torspd like this.
  16. Jun 30, 2020 at 10:44 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Be ready for stuff to be bad then (ie the intercooler gasket rubber that seems to always fall off when you remove your lid.
    Carb cleaner usually.
    I wouldn't be surprised if he has some misfiring going on right now at 100k on original Iridiums.
  17. Jun 30, 2020 at 10:53 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I had noticeable occasional misfiring at 50k. I'm definitely going to a far shorter change interval.
  18. Jun 30, 2020 at 10:59 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I keep mine well below 30K regardless of the pulley and tune knowing what I know now.
    It could be worse. We could be changing them at every oil change 3K like the Cobra owners. Lol.
    Camby likes this.
  19. Jul 1, 2020 at 2:16 AM
    australian hilux
    australian hilux Well-Known Member
    Justin
    2005 Toyota hilux v6 4.0L 1gr-fe
    None at this point
    I understand what your say but the issue is the squeal does start till I hit 3000revs. I have changed all the idle pulleys, I installed a new tensioner and pulley and new belt. To me it’s iust slipping under load which is weird. Never had this on my old engine.
  20. Jul 1, 2020 at 6:58 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Which belt is making the noise, engine accessory drive belt or supercharger drive belt?
    Also, here is a stupid question, but are you running your AC when this is occuring or is it an all the time thing?
    What size pulley are you running and what size belts are you running?
