TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jul 17, 2020 at 2:32 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    I'm assuming they are the SD's URD sells. I have data for them.
  2. Jul 17, 2020 at 2:49 PM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Good point, those are the ones we were working with in the beginning.
    JustDSM[QUOTED] likes this.
  3. Jul 17, 2020 at 6:10 PM
    JustDSM
    Justin
    Ogden, UT
    Hmm, upgrades..
    rheath08, BillDaCat8, RyanL and 12 others like this.
  4. Jul 17, 2020 at 6:36 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    I mean the crowds need to have some audible warning...
  5. Jul 17, 2020 at 6:50 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    You wouldn’t have to remove the 7th. Disconnecting it electrically will keep that injector in the closed position. I think hptuners is a much better experience for drivability.
  6. Jul 17, 2020 at 7:01 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Corsa is a DAMN fine exhaust for American V8s if I do say so myself! You have a good taste in sound good sir!
  7. Jul 17, 2020 at 7:11 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    carbon fiber:)
  8. Jul 17, 2020 at 7:18 PM
    FL_05Taco
    FL_05Taco Active Member
    Alex
    2005 Silver Tacoma TRD
    He hasn't responded to me yet but I will let you guys know as soon as I do. I'm looking forward to knowing some more about my truck.
    henryp[QUOTED] likes this.
  9. Jul 17, 2020 at 7:26 PM
    FL_05Taco
    Alex
    Then I will install it this weekend. Thank you for all the help!
  10. Jul 17, 2020 at 7:39 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Got my cam gears today. :anonymous:
  11. Jul 17, 2020 at 8:07 PM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    How long did it take to get your headers? I might have impulse bought a set.
  12. Jul 17, 2020 at 8:09 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I purchased them new unused from another member........he perhaps bought them impulsively then turned around and sold them.
    jamesepoop and henryp like this.
  13. Jul 17, 2020 at 8:21 PM
    420taco
    420taco Well-Known Member
    Justin
    PA
    Started the header install tonight... :bananadead:
  14. Jul 17, 2020 at 8:24 PM
    JustDSM
    Justin
    Ogden, UT
    Which side did you start on?! :D One of them goes about 3x faster than the other..
    3pooches and TodayWasTHeDaY like this.
  15. Jul 17, 2020 at 8:30 PM
    420taco
    Justin
    PA
    Started driver, got frustrated and went passenger for a change of scenery :boom:
  16. Jul 17, 2020 at 8:50 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  17. Jul 18, 2020 at 9:46 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    buy the urd long tubes. i think they are the best
  18. Jul 18, 2020 at 9:48 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    dude. i had an experienced tech help with mine. it was a motherf-&=r of a time. dont give up.
  19. Jul 18, 2020 at 10:20 AM
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    Thats what i did buy :) The URD Spec-U long tube
  20. Jul 18, 2020 at 9:10 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I found a free BIG change power adder today after work. I also dropped boost as well by about 1.2- 1.3 psi bringing me down to 6 psi. ;)
    @JustDSM got a new log ready to go for you. I'll be sending it your way very shortly.
